Help on hull and motor    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Help on hull and motor Page: [1]
Login
Help on hull and motor - 10/2/2012 2:13 PM
Chrdec
Score: 100
Last Login: 10/3/2012
Status: offline
 Hello.  New to rc boats    I'm chris.  Does anyone know what brand hull and engine this is?  Can't find any labels
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Help on hull and motor - 10/2/2012 4:36 PM
Justaddwata
Score: 217
Last Login: 6/16/2013
Status: offline
Hull looks like the 57" Aeromarine Sigmature - http://www.aeromarinerc.com/index.php?option=com_virtuemart&page=shop.browse&category_id=19&Itemid=53
Motor looks like a 23cc Zenoah
_____________________________
One of the better gas boat picture sites - http://imageevent.com/justaddwata
Hide Signatures
(in reply to Chrdec)
       Post #: 2
RE: Help on hull and motor - 10/2/2012 4:43 PM
Chrdec
Score: 100
Status: offline
Is a good hill and motor.   I got it for free.   It looked really good.
Hide Signatures
(in reply to Justaddwata)
       Post #: 3
RE: Help on hull and motor - 10/2/2012 4:47 PM
Chrdec
Score: 100
Status: offline
Is it a good hull and motor?   I got it for free.   It looked really good.
Hide Signatures
       Post #: 4
RE: Help on hull and motor - 10/2/2012 5:02 PM
Chrdec
Score: 100
Status: offline
Thanks for the info.  How can you tell what cc the engine is?   Does it say it somewhere?
Hide Signatures
       Post #: 5
RE: Help on hull and motor - 10/2/2012 6:08 PM
Justaddwata
Score: 217
Status: offline
Hull/Brand is a good one (though surprisingly unpopular design). Believe it is just a styling thing that has kept it from being more widely used. The Aeromarine 56" apache is probably 100 times more common/popular. I have never run one but good buddy purchased one - though dont believe he ever built it either. Looks like a nice paint scheme on yours. Hardware is a little on the rough side (looks like it is Aeromarine Hardware also) and Aeromarine hardware is overdue an update in styling. All looks in reasonable order though - for a free boat it is a keeper!!
Motor capacity is just me hazarding a guess. Looks like the older 2 port 23cc zenoah. I believe the 26cc version was only available as a 4 port. Either way it is still a decent motor and should move that hull to around 35-40mph without a lot of fine tuning. In the right hands it may well go faster. 35mph is a very respectable speed from a boat that size and would certainly be plenty of fun in a little choppy water!
Hide Signatures
       Post #: 6
RE: Help on hull and motor - 10/2/2012 6:21 PM
coyv10
Score: 102
Last Login: 6/17/2013
Status: offline
make shure it has plenty of flotation (pool noodles) and dont swim after it whatever you do.
Hide Signatures
       Post #: 7
RE: Help on hull and motor - 10/2/2012 6:27 PM
Chrdec
Score: 100
Status: offline
Thanks so much.   I know not to swim.   Have a little boat that got stuck.    Bought fishing pole.  Works well.   One more question so I can finish putting it together.  There's a red and black wire off the engine.  Red is hooked up but black isn't.   Where do I put that wire?  Is that a ground for a kill switch?   I don't see a switch anywhere.   Thanks for all the help
Hide Signatures
(in reply to coyv10)
       Post #: 8
RE: Help on hull and motor - 10/2/2012 6:50 PM
Justaddwata
Score: 217
Status: offline
Be sure you can access the boat anywhere on the pond with that fishing pole!! this is nearing the time of year when people die in ponds
Black is for optional kill switch 90% of RC gas boats dont use a kill switch. Majority just set the radio so throttle down will stall the motor.
If you post some more/clear pics of the motor setup we might be able to point out any other things you may want to address
Hide Signatures
       Post #: 9
RE: Help on hull and motor - 10/2/2012 7:00 PM
tapkoote
Score: 122
Last Login: 6/19/2013
Status: offline
That is Areo marine hardware
I think thats the boat pictured on his web site.
I'd guess thats a 26cc Zen
Call Remy he's great with helping out new guys
i've got his thunderboat.
tap
Hide Signatures
       Post #: 10
RE: Help on hull and motor - 10/2/2012 7:23 PM
Chrdec
Score: 100
Status: offline
Hide Signatures
(in reply to tapkoote)
       Post #: 11
RE: Help on hull and motor - 10/2/2012 7:27 PM
Chrdec
Score: 100
Status: offline
Sorry about the size.   I will post more later when I get home.   Gonna replace all water and fuel lines.   Don't want to chance it
Hide Signatures
       Post #: 12
RE: Help on hull and motor - 10/3/2012 5:17 PM
Chrdec
Score: 100
Status: offline
 Here is the engine
Click for fullsize
Hide Signatures
       Post #: 13
RE: Help on hull and motor - 10/3/2012 5:31 PM
Chrdec
Score: 100
Status: offline
There is also an electric fuel pump in it.   12v I believe.   Do I need that?   It's not hooked up to anything
Hide Signatures
       Post #: 14
RE: Help on hull and motor - 10/3/2012 5:57 PM
Justaddwata
Score: 217
Status: offline
quote:
ORIGINAL: Chrdec
Should not need an electric pump in the boat for anything. Your boat is equipped with a clutch so the boat can idle without spinning the prop. When this happens there is no water flow though the cooling system. Many will use a pulse type pump to continue the water flow. It is not essential as long as you do not idle for long without running fast enough to have water flow once more. Not sure if this is the pump you are seeing (they are usually not electric - they use the engine crank pulse pressure to operate). A pic of the pump might help
Hide Signatures
       Post #: 15
RE: Help on hull and motor - 10/3/2012 7:01 PM
Chrdec
Score: 100
Status: offline
I will just take it out and use it for my plane. Thank you all for your help.
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
