Bodies that fit the twister XTG Pro?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Bodies that fit the twister XTG Pro?
Page: [1]
Login
Bodies that fit the twister XTG Pro? - 10/2/2012 11:31 PM
Microz
Score: 120
Last Login: 5/3/2013
Status: offline
Hey there. I would like to know, does anyone know what bodies other than the OEM fit on the Twister XTG pro? the OEM body is not strong at all....
_____________________________
Planes:HBZ Champ, Micro T-28, Ember 2, UM Stryker
Cars: Traxxas Rustler, ECX Circuit
Hide Signatures
       Post #: 1
RE: Bodies that fit the twister XTG Pro? - 10/3/2012 12:55 AM
nitrosportsandrunner
Score: 296
Last Login: 5/25/2013
Status: online
I think the duratrax evader body would be the best bet. It uses front body posts mounts that are pretty close to what the XTG uses.
Most any stadium truck body could be MADE to fit tho. Just a matter of lining up body post holes.
Or you could get a OEM body and line the inside with tape or shoe goo to reinforce it. The body is indeed a bit weak and since the chassis is a ST style it does very little to protect the body. when the truck flips or crashes, the body takes most of the impact.
Adding washers to the body posts will also help spread the load on the body.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to Microz)
       Post #: 2
RE: Bodies that fit the twister XTG Pro? - 10/3/2012 1:19 AM
Microz
Score: 120
Status: offline
Okay cool thanks! Will look into an evader body and thanks for the recommendation on the washers.
EDIT: HMMMM....do you think i may be able to fit a rustler body?
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Bodies that fit the twister XTG Pro? - 10/3/2012 2:26 AM
Score: 296
Status: online
quote:
ORIGINAL: Microz
I think it should be possible. the major difference for both the evader and rustler bodies is that they use a single rear body post in the center of the body. The XTG uses 2 rear body posts. the trick is to have those posts not be to far out so as to end up in the "shock tower" part of the body. the part over the rear wheels that pops up.
If you convered the XTG to use a single rear body posts that would help.
Hide Signatures
       Post #: 4
RE: Bodies that fit the twister XTG Pro? - 10/3/2012 9:51 PM
Microz
Score: 120
Status: offline
Okay thanks. I dont understand what you mean by not having those posts out too far as to end up in the shock tower? Could you explain further?
Hide Signatures
       Post #: 5
RE: Bodies that fit the twister XTG Pro? - 10/4/2012 2:41 AM
Score: 296
Status: online
most stadium bodies have "humps" where the shocks fit under.
I circled the humps in the pic. If the body posts are to wide apart, they may end up in these humps and that wont work well.
Id look for a body that has a fairly flush area between the humps. The flatter the easier you can make the mounting holes.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 6
RE: Bodies that fit the twister XTG Pro? - 10/5/2012 2:06 AM
Microz
Score: 120
Status: offline
Ah okay cool thanks!
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
