akbowen -> RE: Another Eindecker build (11/6/2012 12:39 AM)
Fin and rudder assembled, but not hinged and sanded. This is the only part of the kit that I have not been real happy with. The curved leading and trailing edges of the fin and rudder are made of 1/8 inch die cut balsa. Two identical pieces are glued together to make a 1/4 inch section of fin or rudder. These sections are then edge glued to form the leading and trailing edges. Seems to me they should have overlapped to form a stronger glue joint. Well, I havn't heard of fins or rudders coming apart, so I guess it's OK. Major Tom, thanks for the link. I've seen that technique on some other scale web site. The thing that scares me is the cowl. The SR Eindecker looks great, but they had an aluminum cowl. I don't think I can do a good job on the cowl with the aluminum tape. I came across a product that might work. I'm going to buy a can and try it on some plastic. I'm thinking of glassing the forward fuse and then painting it.
