akbowen -> RE: Another Eindecker build (1/27/2013 9:07 PM)
Guys, thanks for the tip on spray painting. I'll do that on the wings. I do believe the bigger problem this time was the double sticking of the tape, as I did not have that kind of paint bleed on the other painted areas. Well, I got a bit done this weekend. I have assembled the "scale" landing gear. My metal working skills lag behing my wood working skills, which are not too great themselves. There are a couple of builds that I follow where some real craftsmanship is demonstrated. I don't have that kind of skill, so I have to cover up my defeciencies. This time I did it with black paint. The wire was previously bent and I soldered everything together this weekend. It's been a while since I've done it, and while it's solid, it does not look too good. However, a couple coats of black rustoleum have it looking better. Rudder and elevator pushrods are installed. Next I mount the engine, install the fuel tank, batteries and radio. The only time consuming thing on the wing will be painting. I hope to have my EIII flying in a couple of weeks. Pics don't seem to want to upload now. I'll try again later.
