Hitec X1AC with Sky Lipo problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Hitec X1AC with Sky Lipo problem
Page: [1]
Login
Hitec X1AC with Sky Lipo problem - 10/3/2012 4:58 AM
Photea1
Score: 100
Last Login: 3/3/2013
Status: offline
  Any ideas?  I have 3 1600 Mah 11.1 volt Sky lipos and a Hitec charger.  Over the last week the charger has started erroring out voltage too high on 2 of the batteries.  Upon trying to charge again, I monitor the individual cell voltage and after a short time it starts bouncing all around on the individual cells showing 3-5 volts then errors out again.  Think this is a battery charger or Lipo problem?   Think it could be a balance board problem?  I always charge with the balance board connected and in balance charge mode.  When I put a cell meter on the battery after removing for the charger, it showed the cells fairly well balanced.  Confused. Thanks for any help.
Hide Signatures
       Post #: 1
RE: Hitec X1AC with Sky Lipo problem - 10/3/2012 10:52 AM
trax de max
Score: 114
Last Login: 5/19/2013
Status: offline
its a loose connection in the balance connectors or inside the battery.
_____________________________
Sorry officer i thought the speed limit only applied to people with driving licenses.
Hide Signatures
(in reply to Photea1)
       Post #: 2
RE: Hitec X1AC with Sky Lipo problem - 10/4/2012 12:12 AM
guver
Score: 174
Status: offline
I'd guess the trouble is in the board,wire, or charger. It's happening with all 3 cells on 2 different packs , right?
and airplanes were in
Hide Signatures
(in reply to trax de max)
       Post #: 3
RE: Hitec X1AC with Sky Lipo problem - 10/4/2012 2:40 PM
trax de max
Score: 114
Status: offline
give a gentle pull on each balance wire on its own. If its on the two packs then chances are it's not the batteries. Its the connection somewhere from battery to charger itself. But i'd say its a lead from when it's pulled apart every time.
Hide Signatures
(in reply to guver)
       Post #: 4
RE: Hitec X1AC with Sky Lipo problem - 10/4/2012 2:56 PM
nonstoprc
Score: 110
Last Login: 5/20/2013
Status: offline
You can rule out the balancer by charging without the balancer for a short duration. If the erroneous voltage message shows up again, the charger must be bad.
In general, if the balancer is in place during the charge, the voltage per cell seen by the charger will be lower, than if the balancer is disconnected.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
       Post #: 5
RE: Hitec X1AC with Sky Lipo problem - 10/6/2012 4:11 PM
Photea1
Score: 100
Status: offline
Thanks for the responses.  I plugged in one of the batteries I am having trouble with and watched the charge process.  It did fine till around 4.15 per cell then started going nuts again.  I clicked back and forth between total voltage and per cell voltage and it soon stopped and finished the charge.  I wiggled the wires without success of making it mess up.  I agree with y'all and think it is probably in the balance board so have ordered a replacement.  If that doesn't fix it I'll send it to HiTec and see if they can figure it out.  I highly doubt the batteries are all going bad the same way at the same time.  Could be the other is doing it also and it just hasn't done it bad enough to error out.  Thanks again for the responces and help.
Hide Signatures
(in reply to nonstoprc)
       Post #: 6
RE: Hitec X1AC with Sky Lipo problem - 10/7/2012 7:00 AM
trax de max
Score: 114
Status: offline
you can check for dirt on the pins too if it has been getting dirty it makes a poor contact.
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
