HK Clipped Wing Cub 4 stroke engine size?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> HK Clipped Wing Cub 4 stroke engine size?
Page: [1]
Login
HK Clipped Wing Cub 4 stroke engine size? - 10/4/2012 5:36 PM
skypiratescotty
Last Login: 1/26/2013
Status: offline
Hello
I have a Hobby King clipped wing cub (63" ws) I want to put a 4 stroke on. The instructions call for a 35 size brushless motor but I'm going glow. I know there is some beefing up to do and all I have on hand is a Saito 45. I just don't know if it is quite enough? Plane should come out around 5lbs so I think it would need a 61-70 4 stroke. Any ideas? I want plenty of power for big tal stall turns and short take-offs......
Scotty
http://www.hobbyking.com/hobbyking/store/__15613__Clipped_Wing_Cub_EP_1600mm_Balsa_Ply_ARF_.html
< Message edited by skypiratescotty -- 10/4/2012 5:44 PM >
Hide Signatures
       Post #: 1
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/4/2012 6:11 PM
Twin_Flyer
Last Login: 5/23/2013
Status: offline
I think the Saito 45 should do a ncie job of flying it in a scale like manner.
if you want more power, then go higher.
Bill S.
_____________________________
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to skypiratescotty)
       Post #: 2
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/26/2012 4:10 PM
skypiratescotty
Status: offline
Well, finally the busy summer season is over and am moving ahead with this project. I have aquired a Saito 56 Golden Knight and spent the morning CA-ing the forward section of the plane. Digging around in there I was really surprised how beefy this plane already is considering it is intended for e-power (eecchhh)! I have cut and shaped re-enforcing firewall and will epoxy it to original then paint with thinned epoxy, hopefully have engine mounted this afternnon.
If anyone is interested I can post pics of progress or just save pics for the end. Just let me know what u wanna see!
Scotty
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 3
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/27/2012 4:30 AM
ckreef
Last Login: 5/17/2013
Status: offline
We want to see pics of the progress as you move along with it. That way we can live vicariously through you with this project
Hide Signatures
       Post #: 4
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/27/2012 4:59 PM
skypiratescotty
Status: offline
Alrighty, here we go!!
1) I grind and sand off the e-box already built into the firewall. Then I went inside and hit every joint/seam I can reach with medium CA ( Lock-Tite Superglue).
2) Drill the glow engine mount holes in secondary firewall, then transpose those to original fire wall.
3) Seat the Tee Nuts ( Blind Nuts) in original firewall. I do this before I epoxy the secondary firewall on so that I have more access with my fingers. You could do it afterwards if there is good access to the inside of firewall once the second firewall is epoxied on.....
Got to head to work for a little while but should finish firewall this PM
Scotty
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ckreef)
       Post #: 5
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/27/2012 5:00 PM
skypiratescotty
Status: offline
This one pic per post is dumb!!
Click for fullsize
Hide Signatures
       Post #: 6
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/27/2012 5:03 PM
skypiratescotty
Status: offline
Third......Next I will epoxy both firewall together, then paint with 50/50 epoxy alcohol mix. Let dry overnight
Hide Signatures
       Post #: 7
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/27/2012 5:04 PM
skypiratescotty
Status: offline
the pic didn't attach.....
Click for fullsize
Hide Signatures
       Post #: 8
RE: HK Clipped Wing Cub 4 stroke engine size? - 10/28/2012 4:52 PM
skypiratescotty
Status: offline
epoxy the two firewalls together then paint the new firewall with epoxy/alcohol mix....
that's about it. install engine mount and engine. not much to it really. should be in the air Thursday.
Oh, I decided on a Saito 56 Golden Knight that I got dirt cheap
Scotty
I'll prolly wait on pics till after I'm done because the rest id simple ARF assembly
Click for fullsize
Hide Signatures
       Post #: 9
RE: HK Clipped Wing Cub 4 stroke engine size? - 12/10/2012 1:06 AM
skypiratescotty
Status: offline
Had to put things on hold for a little while but finally got to maiden today. I ended up putting an ASP 61 4-stroke on it and glad I did. No way is it too much engine. Take-off is scale like at around 1/2 throttle and plane chugs around at about 1/3 throttle. Full throttle vertical isn't anywhere near unlimited but more like just about enough. Granted I am running the engine rich and it is brand new so the ring isn't seated yet so power should increase over time. Today was the first three flights so it was trimming out, then basic aerobatics and touch-n-goes to get a feel for landing characteristics. Take-off run is maybe 30-40 feet at 1/2 throttle and it almost lifts off on it's own, big loops from level flight are easy, rolls are nice and stall turns look awesome!
Downside.....the stock landing gear sucks!! Even with perfect landings the weak wire gear bent each time to the point by the end of third flight it just gave out. I would recommend Sig 1/6 scale wire gear or since I'm not too concerned with scale appearance I'm just gonna bolt on DuBro 30-90 size fiberglass. Only cuz that is what is at the LHS.
Scotty
Click for fullsize
Hide Signatures
       Post #: 10
RE: HK Clipped Wing Cub 4 stroke engine size? - 12/14/2012 11:57 PM
skypiratescotty
Status: offline
So if anybody else assembles this plane, different landing gear is a must! Even with somewhat gentle landings, the stock gear, while looking awesome, just plain suck. I painted and put on DuBro Heavy Duty 30-61 size fiberglass gear and t-g's and landings are sweet & slow...... also some sponsorship stickers won't hurt. One other thing to be aware of is the stock cowling is super flimsy fiberglass that cracks if you just look at it wrong. I can foresee 1/6 scalle SuperCub cowling from FbgSpec in the near future.
A little off topic but for the critter lovers out there, my hound only gets to run around at the field when nobody else is there and gets put in the truck while any props are spinning.....also, all poo is immediately bagged and placed in the trash.
Scotty
Click for fullsize
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.265RCU1
