Starting a P-40 By Brodak    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Starting a P-40 By Brodak Page: [1] 2 3   next >   >>
Login
Starting a P-40 By Brodak - 10/4/2012 9:55 PM
Don B.H.
Score: 100
Last Login: 5/3/2013
Status: offline
Just got this in.
 A .19 size P-40
Click to see fullsize image.
Click for fullsize
_____________________________
MidAtlanticCombat
Hide Signatures
       Post #: 1
RE: Starting a P-40 By Brodak - 10/5/2012 12:30 AM
BtnFlyGuy
Score: 105
Last Login: 5/21/2013
Status: offline
That workbench is way too tidy...
Once more... with gusto!
Hide Signatures
(in reply to Don B.H.)
       Post #: 2
RE: Starting a P-40 By Brodak - 10/5/2012 1:50 AM
dennis
Score: 110
Status: offline
It's on the small side and even a Brodak 15 is large for the model. A good Norvel 074 or OS10 will fly it really well without excessive speed or weight.
Dennis
Hide Signatures
(in reply to BtnFlyGuy)
       Post #: 3
RE: Starting a P-40 By Brodak - 10/5/2012 4:44 PM
Don B.H.
Score: 100
Status: offline
Yes,   BTN flyguy the work bench is neat...   But if you look at the last photo you will see the mess in the background......
Dennis the Magnum .15 XLS fits right in there and I ordered a O.S. Venturi fot it.  The Magnum .15 with a OS .25 Venturi and needle will turn 20,000 rpms and it sips fuel so 2 Oz. will run it 4 minuts or more.
I will run it rich with a 8 X 3 prop and that should get me in the  50 MPH range.
Click for fullsize
Click for fullsize
< Message edited by Don B.H. -- 10/5/2012 5:59 PM >
MidAtlanticCombat
Hide Signatures
(in reply to dennis)
       Post #: 4
RE: Starting a P-40 By Brodak - 10/6/2012 6:27 PM
paw080
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: Don B.H.
Hi Don, Dennis is right, the wing area is WAY too small for even a .15 anything. It'll fly with your
.15 Magnum. However, the performance will be less than stellar, because of the very high wing
loading of your finished model. You'll surely need to add tail weight to move the CG to optimal
performance. The Brodak model is a re-kit of the Sterling line which also featured a profile ME-109.
I eyeballed this model from a Sterling kit and estimated the wing area to be around 140 sq"s.
I fly a Ringmaster Jr (195 sq" wing) that is powered by a PAW .049 diesel, it literally flys like a combat
model on 44' X .008" lines, and it is going 54mph. It weighs 7.125 ozs ready to fly sans fuel. It flys an entire
stunt pattern with 1/2 oz of fuel.
With all that being said, I do like your model, and I'm sure it will be a lot of fun for you.
Tony
Hide Signatures
       Post #: 5
RE: Starting a P-40 By Brodak - 10/6/2012 8:42 PM
Don B.H.
Score: 100
Status: offline
quote:
ORIGINAL: paw080
Tony
Hello!   Tony,      I have the Ringmaster Jr and I have the ME109 on order.
 So do you think the .09 would be better for these models?  I don't even see .09 engines listed anywhere.
OS has a .10 LA for RC
< Message edited by Don B.H. -- 10/6/2012 11:47 PM >
MidAtlanticCombat
Hide Signatures
(in reply to paw080)
       Post #: 6
RE: Starting a P-40 By Brodak - 10/7/2012 10:09 AM
greggles47
Score: 100
Status: offline
At 50mph the poor thing will be dropping out of the air.
A smallish wing like that needs to have some airspeed around 70mph before it begins to operate in any sort of competent manner.
I build what we call 2.5 (.15) Slow combat models. At least 44" span and 8" chord. It still flies relatively fast, but will turn tight and doesnt slow down when asked to perform.
Regards
Greg
Hide Signatures
       Post #: 7
RE: Starting a P-40 By Brodak - 10/7/2012 10:44 AM
dennis
Score: 110
Status: offline
quote:
ORIGINAL: greggles47
Greg,
With wing area about the same as a jr Ringmaster it doesn't have to go 70 MPH or it will drop out of the air. I have 2 of the Jr Rings with OS10FP on them and fly with 55 ft .012 line. The both of them are quite capable of doing most anything you would want to do even a 4 leaf clover. Speed is more then adaquate. Prop is a 7/5 APC and a Rev-up 7/6 narrow respectively. Haven't used a 15 on any of the old designs as it simply isn't necessary. and weight and balance are real factors so equiped. Brodak apparently was making them for his 15 but really could have made much better choices then these 2 models. As I said a Norvel .074 will fly these models well if kept light and the 049 on an appropriately built model would probably be a nice sport model . For reference there have been several contest Ringmaster S-1 models powered with 15's. Modern engines are light years ahead of the old powerplants we had 50 years ago.
If Don has an 09 and wants to fly with it,it will be a very good sport model. an Enya 09 would be very good and they make 3 different models.All are available as C/l engines.
I build what we call 2.5 (.15) Slow combat models. At least 44'' span and 8'' chord. It still flies relatively fast, but will turn tight and doesnt slow down when asked to perform.
Regards
Greg
Hide Signatures
(in reply to greggles47)
       Post #: 8
RE: Starting a P-40 By Brodak - 10/7/2012 11:02 AM
greggles47
Score: 100
Status: offline
quote:
ORIGINAL: dennis
Greg,
Regards
Greg
Dennis,
You pays your money & you can do what you like.
I know what I like & it works for me, good luck to anyone who has different recipe for their fun.
G
Hide Signatures
       Post #: 9
RE: Starting a P-40 By Brodak - 10/7/2012 2:20 PM
Don B.H.
Score: 100
Status: offline
So it looks like I am building a GOOD YEAR RACER  class plane as this is the size I put .15 s on in 1984.
but i think they were going faster then 70 mph.... If I had an .09 I would use it............. I do have a box of .049
and I do have a Gilbert .070............................................................................
The Buster and the Shoestring racer, go fast and burn circles.....
MidAtlanticCombat
Hide Signatures
       Post #: 10
RE: Starting a P-40 By Brodak - 10/7/2012 4:09 PM
gcb
Score: 100
Status: offline
quote:
ORIGINAL: Don B.H.
First, forget the .049's and the Gilbert .07. Matt Kania designed the kit for a .15 of the mid 1950's. The .15's available during that time included the OK Cub .14, K&B .15, Cameron .15, and finally the Fox .15. They were just starting to import foreign engines.
As you have surmised a good .10 of today has more power than those, and because of the muffler, more weight. If you put a .15 on it you will probably need to add tail weight for an even higher wing loading. I would go with the .10.
Of course your plane, your choice. Good luck either way.
George
Hide Signatures
       Post #: 11
RE: Starting a P-40 By Brodak - 10/7/2012 4:48 PM
paw080
Score: 100
Status: offline
quote:
ORIGINAL: gcb
George
Hi George, Those models will fly well with a LIGHT weight .09. The Ringmaster Jr
showed a Cub .099 and a Torp .09 and a Torp .15 engine on the original plans.
My first Ring Jr was powered with a Cub .099. The Cub weighed only 1.77 ozs.
It flew very well on 35' X .012" lines. It actually was full pattern capable; but
that was in 1954, so I wasn't. A friend of mine flew a complete stunt pattern
with it in 1956. This experience prodded me(over 35 years later) to start using
smaller than suggested engines for the Jr. My first smaller displacement model
used an AM 10(1.0cc) diesel. It flew magnificently on 40' X .008" lines. The next
models used PAW .049 diesels, I did cut a bunch of pork by slimming the
fuselage, reduced stab and fin area and subsituted the empannage with "C" grain
3/32" sheet. Oh yes, I shortened the nose to accomodate CG and tank size.
The PAW .049s have more power than the AM 10 and are a bit lighter. The Paw .049
will fly a stock Jr with careful attention to weight and wood choices.
My last two Jrs weighed 7.125 and 7.25 ozs, ready to fly sans fuel. I don't remember
what my 1954 Jr weighed, but my late 1980's(stock kit) AM 10 model weighs 9.8-10.1 ozs
depending on prop used. I fly the latest Jrs on 44' X .008" lines. Yes, I agree to forget
about using his .049s and the Gilbert .07.
Tony
Hide Signatures
(in reply to gcb)
       Post #: 12
RE: Starting a P-40 By Brodak - 10/7/2012 4:59 PM
paw080
Score: 100
Status: offline
[/quote]
[/quote]
Hi Don, just consider the .09's as .10s, most .09s were really .099 cu"s. Look around for .10's from
Enya or OS 10 with control line venturis on ebay or even advertise in you local hobby shop. I do not
recommend going the diesel route, because I suspect you have no experience with them. also
consider 1.0 cc(.061cu"s) and .07 cu" engines.
Tony
Hide Signatures
       Post #: 13
RE: Starting a P-40 By Brodak - 10/7/2012 8:32 PM
Jim Thomerson
Score: 160
Status: offline
I built and flew a Ringmaster Jr with a Torp 15 back around 1960. I didn't fly the pattern then, but did lots of lazy 8's. As I recall I flew it on lines advertised as 52.5 feet. the comment about most USA 09's being like .099 is true. The exceptions, 1.5cc, are the Cox 09s and the Johnson Bulldog 09.
Hide Signatures
       Post #: 14
RE: Starting a P-40 By Brodak - 10/7/2012 10:18 PM
dennis
Score: 110
Status: offline
I flew my first Jr Ringmaster in the mid fifties with a Cub 15 which was pitiful on power as anyone my age can attest to. Next was the Fox Rocket 15 steel fin. This was no world beater but it was better then the Cub and at 3 oz was not excessively heavy. About the same as the Torp15.Todays small engines are light years ahead of 1950's technology and is reflected by the smaller better engines that are now available. I have no urge to relive the old days engine wise but it is really fun to fly the old designs with the power to make them perform like the designers would have liked them to have. Thankfully as I said this time smaller is better.
Dennis
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 15
RE: Starting a P-40 By Brodak - 10/7/2012 10:34 PM
Don B.H.
Score: 100
Status: offline
I just ordered the OS .10LA as it is half the weight of the Magnum XLS.
OS.10LA is bushing and the Mag is a bearing engine, so half the weight close to same rpm and prop.
My first plane was flowen in the late 50's but my Dad flew it as I was to little, about 8.
MidAtlanticCombat
Hide Signatures
       Post #: 16
RE: Starting a P-40 By Brodak - 10/8/2012 6:32 PM
dennis
Score: 110
Status: offline
Both of these are OS10FP powered. You will be well satisfied with your choice
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: Starting a P-40 By Brodak - 10/8/2012 8:07 PM
Don B.H.
Score: 100
Status: offline
You see what I am working on along with the P-40..
I realy like the red and white checker board ringmaster you have..............
Click for fullsize
Click for fullsize
MidAtlanticCombat
Hide Signatures
       Post #: 18
RE: Starting a P-40 By Brodak - 10/8/2012 8:15 PM
BtnFlyGuy
Score: 105
Status: offline
What guage/length lines do you use on the Ringmaster JR? I have an Enya .09 to put in mine.
Hide Signatures
       Post #: 19
RE: Starting a P-40 By Brodak - 10/8/2012 9:11 PM
paw080
Score: 100
Status: offline
quote:
ORIGINAL: BtnFlyGuy
Hi Guy, .012" will be perfect. If you are very careful, .008" lines would be even better.
The problem with .008" lines is that they are easily kinked and damaged. Line length can
be 45' to 52' for your .09 model.
My 1.0cc diesel Ring Jr model originaly flew on 35' X .012" lines because I had a lot of
1/2A Combat lines left over. Later I changed to 44' X .008" lines for this and subsequent
PAW .049 diesel powered Jrs; the models flew much better. I am referring to stranded cable
when I say lines.
Tony
Hide Signatures
       Post #: 20
RE: Starting a P-40 By Brodak - 10/9/2012 1:14 AM
BtnFlyGuy
Score: 105
Status: offline
Thanks for the input, Tony. I picked up a set of .012X35' lines at a swap meet and a RMJr as well. I hope the lines aren't too short.
Hide Signatures
       Post #: 21
RE: Starting a P-40 By Brodak - 10/9/2012 2:16 AM
paw080
Score: 100
Status: offline
quote:
ORIGINAL: dennis
Hi Dennis as a fun comparison, here is my Ringmaster Jr (much modified) that is
PAW .049 powered. It flys beautifully and handles very much like a 1/2A Combat
model flying 10-12 mph slower. I have posted some pics in the Shoestring thread,
so I'll post some different ones here.
Tony
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: Starting a P-40 By Brodak - 10/9/2012 3:41 AM
dennis
Score: 110
Status: offline
quote:
ORIGINAL: paw080
quote:
ORIGINAL: dennis
Tony
Tony,
Thats a nice set up and a good looking model. I have one origional Jr Ringmaster left and one new manufacture Pat King kit. The red&white is a Pat King kit, the silkspan yellow is an Estes. But the next one was going to have a Paw 061 simply because I like to use longer lines and 55 foot seems to work for me. Incidentally as you know newer manufactured kits have infinitely better wood then Sterling had in their offerings.
To Don,
The covering is Ultrakote red/white checkers covering. It's worth $26 a roll simply to not have to paint them on a model. They can be had from 1/2 inch to 4 inch. Also available in other colors.
Hide Signatures
       Post #: 23
RE: Starting a P-40 By Brodak - 10/10/2012 11:10 PM
Don B.H.
Score: 100
Status: offline
Wll in the first photo you see my old Enya .19VI and it fit then a I pulled out the Magnum .15XLS and refit the smaller engine now I am waiting for the new OS.10LA engines to get  here. That is holding up 2 planes now this one and the Ringmaster Jr and now I need smaller lines,  So I ordered some .12 cable 7 strand.
I have .15 by 55 ft. but they will be to large I think....
I am doing all this because I want the stellar performance.....
< Message edited by Don B.H. -- 10/11/2012 12:10 AM >
MidAtlanticCombat
Hide Signatures
       Post #: 24
RE: Starting a P-40 By Brodak - 10/11/2012 2:43 AM
paw080
Score: 100
Status: offline
quote:
ORIGINAL: Don B.H.
Hi Don, Yeah, I think the 55' X .015" lines willl be too much drag for your OS .10 LA.
I have flown a T.D. .09 powered Jr Flite Streak on 52' X .012" lines before, it had plenty of
line tension, even during overhead stuff. Can you do me/us a favor and calculate a wing area
estimate for the P-40 model? I'm assuming the Brodak Me 109 kit would be about the same.
I'm blaming you for starting this thread, because now I'm seriously thinking of buying Brodak's
Me 109 repro kit. The wing area estimate will tell me what engine displacement range I can use
to power the model. I would likely do a bit of wood substitution, like I always do.
Tony
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.389RCU1
