XYZ 20cc engines from Valley View    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> XYZ 20cc engines from Valley View
Page: [1] 2 3 4 5   next >   >>
Login
XYZ 20cc engines from Valley View - 10/5/2012 2:08 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
Has anyone had any experience with the XYZ brand engines from VV? They look a lot like the DLE, one heck of a cheap price at the moment, don't know how long it will last. They had a hand in the developement and might be the only importer. I did see one fly locally on an AW ProX260 and it ran great. First class people at VV too and that's a plus.
Thanks, Ernie
http://www.valleyviewrc.com/estore/xyz-20cc-gas-engine.html
>>>>> This new 20cc was developed in collaboration between Valley View RC and XYZ manufacturing. After many hours of testing we feel this is one of the best 20cc engines on the market today. We have ran severalof these engines on our test stand and in an airplane and have had no failures. This engine comes with a Rcexl ignition, genuine NGK-CM-6 spark plug, composite engine mount and long throttle and choke arms.
Specifications:
Displacement: 20cc
Bore: 1.3in / 32mm
Stroke: 1.0in / 25mm
Weight: 0.75kg/ 26.5oz
RPM Range: 1650 - 9000
Output: 2.5 hp @ 9000RPM
Requires: unleaded gasoline, 2-cycle oil, ignitionbattery & propeller
Includes: Rcexl electronic ignition, muffler, spark plug, throttle and choke arms, engine mount, and manual
Propellers: 14 x 10,15 x 8, 16 x 6, 16 x 8, 17 x 6, 17 X 8
Hide Signatures
       Post #: 1
RE: XYZ 20cc engines from Valley View - 10/5/2012 2:19 AM
Mpizpilot
Score: 100
Last Login: 6/17/2013
Status: offline
I've got two. Bought direct for $175 each. Didn't come the rcexcel ignition though. Mine have been absolutely perfect for me.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 2
RE: XYZ 20cc engines from Valley View - 10/5/2012 2:22 AM
Ernie Misner
Score: 130
Status: offline
What ignition did it come with? Thanks for the input, great that yours are flawless.
Hide Signatures
(in reply to Mpizpilot)
       Post #: 3
RE: XYZ 20cc engines from Valley View - 10/5/2012 2:39 AM
captinjohn
Score: 247
Last Login: 6/20/2013
Status: offline
quote:
ORIGINAL: Mpizpilot
Direct ...from where?   Also what kind of power has it got compared too other 20cc engines?    Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
       Post #: 4
RE: XYZ 20cc engines from Valley View - 10/5/2012 5:27 AM
Ernie Misner
Score: 130
Status: offline
From VV John, follow the link above.
Hide Signatures
(in reply to captinjohn)
       Post #: 5
RE: XYZ 20cc engines from Valley View - 10/6/2012 4:04 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: Ernie Misner
Ernie....you go follow the link...............or something
Hide Signatures
       Post #: 6
RE: XYZ 20cc engines from Valley View - 10/6/2012 5:55 PM
Lifer
Score: 153
Last Login: 6/19/2013
Status: offline
Any chance that the exhaust port can be rotated to the rear?
Hide Signatures
       Post #: 7
RE: XYZ 20cc engines from Valley View - 10/6/2012 8:59 PM
ahicks
Score: 669
Status: offline
Ernie I think Capt,n was wondering where you could buy the XYZ engines direct?
Hobbyking had them, but betting the fact VV does now might have somethng to do with the fact they don't any more?
RCG/RCGF still there though....
I'd like to know how the 20cc XYZ stacks up against the beam mount RCG/RCGF and DLE engines regarding how fast it'll turn an APC 17x6? I know the RCG and DLE are about the same, turning something in the 8400 - 8700 rpm range in my experience. -Al
Hide Signatures
(in reply to Lifer)
       Post #: 8
RE: XYZ 20cc engines from Valley View - 10/6/2012 9:09 PM
karolh
Score: 315
Status: offline
Really ??
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to ahicks)
       Post #: 9
RE: XYZ 20cc engines from Valley View - 10/6/2012 9:24 PM
ahicks
Score: 669
Status: offline
Huh?
Really what?
-Al
Hide Signatures
(in reply to karolh)
       Post #: 10
RE: XYZ 20cc engines from Valley View - 10/6/2012 9:39 PM
karolh
Score: 315
Status: offline
Never knew the RCGF could turn that much rpm on a 17x6 prpop.
Karol
Hide Signatures
       Post #: 11
RE: XYZ 20cc engines from Valley View - 10/6/2012 10:15 PM
TunnelBill
Score: 100
Last Login: 6/18/2013
Status: offline
I got mine today and it looks good, they ran the engine for 20 min. before it was shipped. That is great service. The manual said to use a Hard Mount, Do not use a soft mount, I was going to use a Dubro mount, is this a Soft mount? Any input would be great because I am new to Gas.
Bill
< Message edited by TunnelBill -- 10/7/2012 2:26 AM >
Hide Signatures
       Post #: 12
RE: XYZ 20cc engines from Valley View - 10/6/2012 10:20 PM
yankos
Score: 100
Last Login: 6/10/2013
Status: offline
Total weight is 750gr? With muffler and ignition?
Hide Signatures
(in reply to TunnelBill)
       Post #: 13
acerc
Score: 221
Status: offline
The Du-Bro is a soft mount unless you have the aluminum one. I would not use aluminum, build a beam or use the Du-Bro. I have two on the Du-Bro's been fine for over a year. Have seen the aluminum one's break from the inside corner's.
I have two of the RCGF's and they are both in the mid 8K's with a Xoar 17x6.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 14
RE: XYZ 20cc engines from Valley View - 10/6/2012 11:00 PM
ahicks
Score: 669
Status: offline
Re: RCGF, the beam mount version is pretty strong, stand off version not as much.
Dubro soft mount has rubber grommets between the motor mount and the firewall
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD633&P=7
A lot of guys prefer something like this one:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXATG7&P=ML
Total weight is 750gr? With muffler and ignition? - Not very likely. If they don't specify what the spec. includes, safest bet would be it's engine only?
Hide Signatures
(in reply to acerc)
       Post #: 15
RE: XYZ 20cc engines from Valley View - 10/6/2012 11:43 PM
Mpizpilot
Score: 100
Status: offline
quote:
ORIGINAL: captinjohn
quote:
ORIGINAL: Mpizpilot
Direct from xyz in china. They were selling them right here in the rcu swap shop. I've also got a dle 20 and to be honest I can't tell the difference. The xyz does come with a walbro carb as well and real ngk cm6 plugs.
Hide Signatures
       Post #: 16
RE: XYZ 20cc engines from Valley View - 10/7/2012 12:27 AM
SigMan
Score: 110
Status: offline
i have mine XYZ 20 sitting on top my GP Revolver 70 in the other room waitng for after Christmas assembly. thought i would start seeing videos on youtube by now of these after the excellent review in FlyRC magazine. oh, i also order the opto kill switch and it was still only 200 bucks. what a great deal if she runs good.
Club Saito Member #1
AMA# 542304
Hide Signatures
       Post #: 17
RE: XYZ 20cc engines from Valley View - 10/7/2012 12:32 AM
Ernie Misner
Score: 130
Status: offline
They are bound to weight exactly the same as the DLE..... a clone? Sorry John if the link didn't work. Valley View is the importer and distributor it looks like. Insane price on them right now, don't know how long that will last. May as well get 3 or 4.....
Can anyone tell me for sure if the exhaust flange mount is exactly the same as the DLE. I will want to get a header and tuned pipe eventually and Mac's does have the DLE header. Also I'm hoping the DLE ring is the same so I can get one from Frank Bowman since he already has the DLE rings.
Thanks, Ernie
Hide Signatures
       Post #: 18
RE: XYZ 20cc engines from Valley View - 10/7/2012 3:09 PM
captinjohn
Score: 247
Status: offline
Thanks, Ernie
AH-Heck....get a dozen....that way you will have extra parts to keep em going!
Hide Signatures
       Post #: 19
RE: XYZ 20cc engines from Valley View - 10/7/2012 4:51 PM
karolh
Score: 315
Status: offline
Capt,n I was drinking my coffee and you almost made me choke
Karol
Hide Signatures
       Post #: 20
RE: XYZ 20cc engines from Valley View - 10/7/2012 9:24 PM
geeter
Score: 108
Last Login: 6/16/2013
Status: offline
i had a 50cc XYZ gas engine about three years ago, sold by southeast engines. it ran great in my 82 " ws super sportster by great planes,even with a smoke system and stock muff. they are good engines in my view and have enough power for most flying............RON
Hide Signatures
       Post #: 21
RE: XYZ 20cc engines from Valley View - 10/7/2012 10:21 PM
captinjohn
Score: 247
Status: offline
Thanks, Ernie
You know what Ernie, that "direct" place you talked about, might be able to set u up with a pipe!!!   Get some extras of them too!
Hide Signatures
       Post #: 22
RE: XYZ 20cc engines from Valley View - 10/8/2012 3:05 AM
denney47
Score: 105
Last Login: 5/13/2013
Status: offline
I can answer a few of these questions,
The engine was developed in cooperation between Valley View RC an XYZ.  We used the Rcexl ignition instead of the XYZ ignition; we believe this gave the engine more power, easier starting and is more reliable.  There were some minor changes made in the engine and the muffler was changed.  Any muffler or header that will fit a DLE 20 will fit this engine.
The engine comes with, Rcexl ignition, NGK CM-6 spark plug, muffler, fiber beam mount and longer throttle and choke arms.
Any additional questions contact Tom at: tom@valleyviewrc.com
FYI, we are testing a 40cc twin cylinder engine that may be available soon from VVRC
DLE/XXZ Engines - Factory Authorized Distributor
Hide Signatures
       Post #: 23
RE: XYZ 20cc engines from Valley View - 10/8/2012 4:41 AM
Mpizpilot
Score: 100
Status: offline
Definitely get it from ValleyView. I paid $175 and that was without the rcexcel ignition. One more thing, if you need a a spinner adapter, contact trutun. They now have the tooling to make them. I paid a little extra to have them made for me. No one carried them at the time I needed them.
Hide Signatures
(in reply to denney47)
       Post #: 24
RE: XYZ 20cc engines from Valley View - 10/8/2012 1:32 PM
dirtybird
Score: 173
Status: offline
It sure looks like the NGH 25CC that I have.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> XYZ 20cc engines from Valley View
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
