RE: XYZ 20cc engines from Valley View    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: XYZ 20cc engines from Valley View Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: XYZ 20cc engines from Valley View - 10/9/2012 4:12 PM  1 votes
raptureboy
Score: 183
Last Login: 6/19/2013
Status: offline
You know the Chinese, if you can't make your own steal someone elses. xyz, dle, ying yang wong, wa hoo wang. Yippe!
_____________________________
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to dirtybird)
       Post #: 26
RE: XYZ 20cc engines from Valley View - 10/9/2012 4:48 PM
bkjlfp
Score: 100
Last Login: 6/18/2013
Status: offline
I emailed VV about a spinner adapter and they mailed me one. Works great. Don't know how much it was because it was free. I bought the engine from them, maybe that helped.
Hide Signatures
(in reply to Mpizpilot)
       Post #: 27
RE: XYZ 20cc engines from Valley View - 10/30/2012 1:17 AM
geeter
Score: 108
Last Login: 6/16/2013
Status: offline
i have seen pics of the xyz 20 cc motor. thinking of getting one soon. the muffler design shows the engine on it's side,with the stack pointing down, this is what i need. another showes it upright with the stack pointed down. you can't have it both ways,like inverted or upright mounting. the stack would have to have a different configuration. which is it?...thanks...........RON
Hide Signatures
(in reply to bkjlfp)
       Post #: 28
RE: XYZ 20cc engines from Valley View - 10/30/2012 1:44 AM
denney47
Score: 105
Last Login: 5/13/2013
Status: offline
We have both type mufflers Ron, many customers use this engine on profile airplanes so we provide the profile muffler for them.  If they are going to use it in an airplane that the engine will be inverted we will provide that muffler.
Thank you
Tom
quote:
ORIGINAL: geeter
DLE/XXZ Engines - Factory Authorized Distributor
Hide Signatures
(in reply to geeter)
       Post #: 29
RE: XYZ 20cc engines from Valley View - 10/30/2012 1:45 AM
denney47
Score: 105
Status: offline
We also have Pitts style mufflers for this engine also.
Thank you
Tom
Valley View RC
Hide Signatures
       Post #: 30
RE: XYZ 20cc engines from Valley View - 10/30/2012 2:06 AM
karolh
Score: 315
Status: offline
Sounds all good.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to denney47)
       Post #: 31
RE: XYZ 20cc engines from Valley View - 10/30/2012 3:24 AM
acdii
Score: 155
Status: offline
I ordered one today. It will be mounted inverted, so I probably should shoot them an email even though I plan to use a Pitts on it.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to karolh)
       Post #: 32
RE: XYZ 20cc engines from Valley View - 10/30/2012 4:15 AM
geeter
Score: 108
Status: offline
thanks for the return so soon. i get it, so get the muffler with the motor mounted on it's side configuration. good e-nuff.....thanks again...RON
Hide Signatures
(in reply to acdii)
       Post #: 33
RE: XYZ 20cc engines from Valley View - 1/9/2013 5:43 AM
bkjlfp
Score: 100
Status: offline
quote:
ORIGINAL: SigMan
i have mine XYZ 20 sitting on top my GP Revolver 70 in the other room waitng for after Christmas assembly. thought i would start seeing videos on youtube by now of these after the excellent review in FlyRC magazine. oh, i also order the opto kill switch and it was still only 200 bucks. what a great deal if she runs good.
Did you get your Revolver in the air yet? I put the XYZ 20cc in my Revolver 70 and it is a perfect combo. Had to add a little weight to the tail but not much. Moved the fuel tank back to just in front of the wing tube and had to cut out a small piece of ply and a little of the foam from under the canopy/hatch to clear the vent line on top. With the stock fuel tank it will run forever at mid throttle settings and does some 3D as well. I run a 17 X 4W APC prop. Tons of throttle response. So far I have never had it quit on me in the air - just let it get warm. I also have a high idle programmed to a switch to make sure and then kick it off for landing.
Have fun with the Revolver - my favorite plane (or at least as favorite as my Seagull 540 68").
Hide Signatures
(in reply to SigMan)
       Post #: 34
RE: XYZ 20cc engines from Valley View - 1/9/2013 11:30 AM
SigMan
Score: 110
Last Login: 6/10/2013
Status: offline
quote:
ORIGINAL: bkjlfp
quote:
ORIGINAL: SigMan
Have fun with the Revolver - my favorite plane (or at least as favorite as my Seagull 540 68'').
no, i havent even started putting it together. i hope to have it ready by spring. i got a couple of small BNF's and they been keeping me busy. glad to her your have a great time with your Revolver.
Club Saito Member #1
AMA# 542304
Hide Signatures
       Post #: 35
RE: XYZ 20cc engines from Valley View - 1/9/2013 2:00 PM
Edwin
Score: 156
Status: offline
Further back, it was mentioned the carb is a walbro, is it? Is it a real walbro, not a copy?
Edwin
Hide Signatures
       Post #: 36
RE: XYZ 20cc engines from Valley View - 1/9/2013 5:00 PM
flygilmore
Score: 131
Last Login: 5/16/2013
Status: offline
Yes, it is a real Walbro if you get it from VV at least. I got one over Christmas break and it looks very nice. It will going on my sons PT .60 trainer. We wont be lacking power to say the least!
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
(in reply to Edwin)
       Post #: 37
RE: XYZ 20cc engines from Valley View - 1/9/2013 5:13 PM
denney47
Score: 105
Status: offline
The XYZ 20's do have a real Walbro Carburetor, we have not had any problems with this engine since we made a few changes with the factory.
Please let me know any feedback you have, good or bad.
Thank you
Tom
Valley View RC
valleyviewrc.com
Hide Signatures
(in reply to flygilmore)
       Post #: 38
RE: XYZ 20cc engines from Valley View - 1/9/2013 5:41 PM
karolh
Score: 315
Status: offline
It's so nice to now have so many choices in the 20cc engine size which is becoming quite popular.
Karol
Hide Signatures
       Post #: 39
RE: XYZ 20cc engines from Valley View - 1/9/2013 6:21 PM
Edwin
Score: 156
Status: offline
Damn, I might have to try one. I have a rcgf 20cc (one of the very early ones), that for the most part is a decent engine. But I just dont like that chinese carb. I'm going to be replacing it with a real walbro. Same on my DLE30. I usually dont mind tinkering with engines, its kinda fun. But now I have too many that need tinkering on a regular basis. I want them to run right out of the box so I can get more flying time in, been spoiled by my zenoahs and us engines. I'll do more conversions if I want to tinker.
Sometimes there's something in a name. When I first saw XYZ, I didnt give it another thought and figured it was some copy of a copy of another copy and figured it would be like the ngh brand. I've seen a lot of reviews about ngh and bottom line in most of them was a list of "if you do this, that, and another thing" they can be made to run. Thats not what I'm willing to pay for anymore. I have a crrc 40cc thats a worthless piece of junk. The main bearing seat is too big for the bearing so its slightly loose. It has about 1/32" of lateral side to side play. Which explains the ridiculous amount of vibration it has. These engines had a history of breaking crankshafts for awhile. I'll try some JB weld in the seat later to see if that can fix it. That along with the timing being wrong and a cantankerous carb, turned me away from off brands. The only reason I'm willing to give the XYZ 20cc a try is because its from Valley View. I've done business with them in the past and consider them honest.
Edwin
< Message edited by Edwin -- 1/9/2013 8:09 PM >
Hide Signatures
       Post #: 40
RE: XYZ 20cc engines from Valley View - 1/9/2013 7:46 PM
A6TEXAN
Score: 100
Last Login: 6/15/2013
Status: offline
I recieved mine just before christmas. manual list props at 15x10,16x8,16x10,17x6. i have not ran mine yet. wlabro carb, rxcel ignition.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Edwin)
       Post #: 41
RE: XYZ 20cc engines from Valley View - 1/9/2013 8:25 PM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
VV sells those carb pretty reasonable if you want one for your DLE. Edwin, you might also try tapping that bearing into the loose mount with some brass shim stock around it.
Hide Signatures
(in reply to A6TEXAN)
       Post #: 42
RE: XYZ 20cc engines from Valley View - 1/10/2013 12:07 AM
Edwin
Score: 156
Status: offline
I'm not interested in another chinese dle carb. I want a real walbro carb. I'm concerned that with shims, it might be off center a small amount. Enough to cause a crank to break later on.
Edwin
Hide Signatures
(in reply to Ernie Misner)
       Post #: 43
RE: XYZ 20cc engines from Valley View - 1/10/2013 1:56 AM
Ernie Misner
Score: 130
Status: offline
Like I said, VV sells those carb very reasonable.
Hide Signatures
(in reply to Edwin)
       Post #: 44
RE: XYZ 20cc engines from Valley View - 1/10/2013 2:57 AM
Edwin
Score: 156
Status: offline
I sent a msg to VV asking if the carbs are walbro.
Edwin
Hide Signatures
       Post #: 45
RE: XYZ 20cc engines from Valley View - 1/10/2013 3:24 AM
A6TEXAN
Score: 100
Status: offline
see the second picture above.
Hide Signatures
(in reply to Edwin)
       Post #: 46
RE: XYZ 20cc engines from Valley View - 1/10/2013 3:28 AM
Edwin
Score: 156
Status: offline
I know about that one. I'm asking about DLE30.
Edwin
Hide Signatures
       Post #: 47
RE: XYZ 20cc engines from Valley View - 1/11/2013 7:38 PM
flygilmore
Score: 131
Status: offline
Check out the DLE 30 thread perhaps........
Hide Signatures
(in reply to Edwin)
       Post #: 48
RE: XYZ 20cc engines from Valley View - 1/11/2013 8:27 PM
Edwin
Score: 156
Status: offline
It hasnt been high on my priority list, I'm pulling the dle 30 and putting the US35 back on. It flew fine with that engine. VV got back with me on the replacement carbs for the XYZ 20cc. They are not in stock yet. When they are, I'm buying one. Just for grins, I'll try it on the dle30 and see how it does before it goes on the rcgf 20. If it works good enough, I'll get another. In the mean time, I'll check out that dle30 thread you mentioned. The replacement dle30 carbs at VV are the same as the stock carbs, I just wanted to confirm that.
Edwin
Hide Signatures
       Post #: 49
RE: XYZ 20cc engines from Valley View - 1/21/2013 11:46 PM
u2fletch
Score: 100
Status: offline
Installing my XYZ into a Revolver 70 as well. Bought two, the other is going into a Balsa Nova build that I am doing for some friends.
Here is a pic of the awesome extension arms for the choke plate and throttle that Valley View provides with the XYZ 20. When these arms are installed on the carb, they line up perfectly with the pushrod holes pre- drilled in the Revolver 70 firewall. That assumes of course an inverted engine install, which I think most everyone does with that plane and engine combo.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Edwin)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
