Possible Short?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Possible Short?
Page: [1]
Login
Possible Short? - 10/5/2012 3:22 PM
smithcreek
Score: 159
Last Login: 6/18/2013
Status: offline
My engine quit mid-flight. Running fine, no signs of overheating or stumbling, then just cut out instantly. First thing I checked was the ignition wiring for loose connections. Only thing I found was the positive wire on the charging wire on my ignition switch may have melted by coming in contact with my muffler. I checked everything else and my spark is fine. I tried to find a wiring diagram for the typical rc switch (specifically using a heavy duty futaba), to see if I could figure it out, but could not. Can anyone tell me, is it possible the red wire shorted out on the muffler? I know that circuit does not work, you can't charge when the switch is on, but is that red still hot?
_____________________________
For a kit you are, and to a kit you shall return.
Hide Signatures
       Post #: 1
RE: Possible Short? - 10/5/2012 3:48 PM
ahicks
Score: 669
Status: online
If that charge line is hot with the switch on I'd be surprised. Shouldn't be that hard to figure out with a multi meter? With the switch turned on, touch one lead to the red wire, the other to the engine. You'll see voltage or you won't. That should satisfy your curiosity?
Hide Signatures
(in reply to smithcreek)
       Post #: 2
RE: Possible Short? - 10/5/2012 3:55 PM
All Day Dan
Score: 156
Last Login: 6/19/2013
Status: offline
Check the sensor and its connector for an intermittent connection. There are a lot of other aspects if the ignition system that could be intermittent. I always bring a spare module with me when I go flying. The charging side of the ignition switch has no effect when the switch is on. Dan.
Dan
Hide Signatures
       Post #: 3
RE: Possible Short? - 10/5/2012 4:32 PM
smithcreek
Score: 159
Status: offline
quote:
ORIGINAL: ahicks
Thanks, I was feeling lazy. Checked and confirmed, not the issue. Overheating maybe. I'll give it another go today, increasing the exit hole for air flow.
Hide Signatures
(in reply to ahicks)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Possible Short?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
