RE: Need Help with Fox 15 Davis Conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> RE: Need Help with Fox 15 Davis Conversion
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Need Help with Fox 15 Davis Conversion - 10/12/2012 5:29 AM
AMB
Score: 110
Last Login: 5/21/2013
Status: offline
If compression seems low a phone call to Fox may be in order, really think the head is out of the loop martin
Hide Signatures
(in reply to tweedy)
       Post #: 76
RE: Need Help with Fox 15 Davis Conversion - 10/12/2012 5:53 AM
steve111
Score: 100
Status: offline
How easily does it start? If it's starting all right then I can't see either ether content or compression being the problem. The figures quoted seem way low, even for a worn-out engine.
If it can do 15500 in standard glow form, I can't see that Fox would be particularly sympathetic.
Out of interest, have you tried something like an 8x4, 8x6 or 9x4 with it running as a diesel? 9x6 and 10x6 are both more than I would normally use for a .15 (I fly CL), so I'm wondering how it would go on a smaller prop.
Hide Signatures
(in reply to AMB)
       Post #: 77
RE: Need Help with Fox 15 Davis Conversion - 10/12/2012 6:25 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: steve111
Pretty much my thoughts on the starting Steve, something is being missed here.
What I want to know is, does it misfire when running as a diesel?
Hide Signatures
(in reply to steve111)
       Post #: 78
RE: Need Help with Fox 15 Davis Conversion - 10/12/2012 7:09 PM
tweedy
Score: 100
Last Login: 5/20/2013
Status: offline
I think the problem may be the Cylinder to piston fit, if you look at the wear pattern on the piston it is wearing at the top on one side of the piston, and at the bottom on the other. I talked to Chris at Fox and he is going to send me a piston and Cylinder Assembly that is on the tight side, and I will spend an evening hand lapping it.
Hide Signatures
(in reply to AMB)
       Post #: 79
RE: Need Help with Fox 15 Davis Conversion - 10/12/2012 7:48 PM
AMB
Score: 110
Status: offline
Nice- hope that fixes it nice to deal with folks that care, did not mention it before but thought that might have been issue, glows can scream on lower compression
diesel a lost cause martin
Hide Signatures
       Post #: 80
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 2:24 AM
Hobbsy
Score: 650
Status: offline
Martin, I'm going to run my Fox .15 conversion tomorrow with a variety of props. One problem though, I need to either make or scrounge up some kind of bushing for the props. Not a single one fits the Fox shaft.
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to AMB)
       Post #: 81
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 2:40 AM
AMB
Score: 110
Status: offline
Hobbsy I have a variety of K and S thin wall aluminum tubing some even telescopes like a rc transmitter antenna so can fit almost any engine a must in the small ones, you can wrap some tape around the shaft to bring up the diameter so a good fit in I guess 1/4 inch is the standard prop bore I have done it you may have to
do a re-wrap when you change props martin
scotch tape to the rescue
K and S bush for prop
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Hobbsy)
       Post #: 82
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 5:41 PM
Hobbsy
Score: 650
Status: offline
OK, here are the props I ran,
A MasterAirscrew Scimitar 9x5S rpm====12,100
A Taipan 10x4 rpm================9,200
A Graupner 10x5.5 rpm=============9,000
Idle==========================3,100
I only got a single outside photo to take, its really difficult to take them in the fall, as you can see. This one about two clicks from the peak. I don't seem to have a 10x6 of any brand. I think you can take a look at the Taipan and see why it made only 9,200 rpm but that dude makes some serious wind.
The fuel was Davis ABC blend.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 83
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 6:46 PM
tweedy
Score: 100
Status: offline
quote:
ORIGINAL: Hobbsy
I'f I'm able to sort things out and get those kind of numbers I will be a happy camper
Tweedy
Hide Signatures
       Post #: 84
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 7:37 PM
AMB
Score: 110
Status: offline
Tweedy most likely you will get those numbers everything i fly diesel or 4 strk glow we get 9 to 10K on the revs and sure they unload a bit in the air, an other 300 at least martin
I should have my digital fish scale early next week so I can see the real numbers on thrust on the planes should be interesting and not "well feels like a lot"
Hide Signatures
       Post #: 85
RE: Need Help with Fox 15 Davis Conversion - 10/13/2012 10:33 PM
Hobbsy
Score: 650
Status: offline
I finally found a 10x6 that I thought was a 10x8 because it was buried in a stack of props on a peg board hanger. It is a Graupner 10x6 Scimitar.
Graupner 10x6 Scimitar rpm ====9.250, the idle with this prop is a very steady 2,400. It is about 40 degrees right now and there was no idle cool down at all.
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 86
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 12:50 AM
AMB
Score: 110
Status: offline
not bad at alll, but Brrrrrrrrr on the temp high 80s here today MARTIN
FOOD FOR THOUGHT A 10X6 IS A COMMON FOR A 40 GLOW
Hide Signatures
       Post #: 87
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:10 AM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: AMB
Too windy to fly yesterday so we ran engines. A bloke ran a c/l unmuffled Norvel 40 BB on an APC 9x7 and I tachoed it at 15200 RPM.
I ran my Oliver Tiger MOD 2.5cc on a Master 10 x 6 and got 7600 RPM consistently with a maximum of 8200 RPM. However it would
only hold the latter speed for about a minute before overheating.
It turned the full RAM 8 x 6 comfortably at 12100 RPM.
It also turns an APC 7 x 6 at 16500 and an APC 8x4 at 15400 which makes it a goodin!
Regarding the claimed Davis RPM figures my gut feeling is that they're fantasy and as far as I'm concerned the myth is busted!
A fair amount of salesmanship in the claims?
Ray
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 88
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 11:36 AM
Diesel Fan
Score: 100
Last Login: 5/19/2013
Status: online
 Should do the quoted rpm on a single blade 10x6 methinks.
Hide Signatures
(in reply to qazimoto)
       Post #: 89
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 11:44 AM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: Diesel Fan
... or the 10 x 6" with an inch and a half off each blade.
Hide Signatures
(in reply to Diesel Fan)
       Post #: 90
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 1:24 PM
Hobbsy
Score: 650
Status: offline
Coming within 750 rpm with a fairly new engine isn't exactly myth busting and comparing a .40 to a .15 isn't what I'd call fair either.
Hide Signatures
       Post #: 91
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:08 PM
AMB
Score: 110
Status: offline
Hi Hobbsy I just thought it was interesting that a 10x6 prop was listed as a common size for40 size glow engines, a 15 diesel has no issue turning one
Just checked my factory sheet on PAW and indeed a 10x6 one of the suggested props so I guess in the 9 to 10K rev range on a 10x6
is the norm for a 15 diesel, the Davis sheet list 9x7 so a 10x6 I think pretty equal to a 10x6 best regards martin
Post note just became a grandfather yesterday was told about time since just hit the 80 mark in Sept
Hide Signatures
       Post #: 92
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:19 PM
Mr Cox
Score: 102
Status: offline
I thought it made 9250rpm on a 10x6?
That would make it 1250rpm less than the claims, and on pair with other .15 diesels. Perhaps not a myth busted but certainly a marketing bluff being caught. I would prefer to think of it as a missprint though.
Hide Signatures
       Post #: 93
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:26 PM
gcb
Score: 100
Status: offline
quote:
ORIGINAL: AMB
Congratulations on both milestones!
BTW, I turn 71 next month and I have two grandsons...both in college.
George
Hide Signatures
(in reply to AMB)
       Post #: 94
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:36 PM
Hobbsy
Score: 650
Status: offline
Sorry Mr. Cox, my memory is more flawed than my math, Like George I'm currently 70 and so far that has not been a bad thing. I am still searching for an APC 10x6 although I doubt I'll see that kind of rpm with it either. But as the guy said at the end of that Dirty Harry movie, "I gots to know."
Congrats on the grandchild Martin, I have 17 of em, I wonder how that happened.
Hide Signatures
(in reply to Mr Cox)
       Post #: 95
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 3:51 PM
AMB
Score: 110
Status: offline
Mr Cox think it is a miss-print Mr Davis has very high ethics do does not resort to false claims has no need too martin see my post and replys dated'10/3 and replys of others martin
Hide Signatures
       Post #: 96
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 10:13 PM
greggles47
Score: 100
Status: offline
quote:
ORIGINAL: AMB
Congrats on both Martin. Are you a grandfather or grandmother....errr is it a boy or girl?
I've got two granddaughters - they're so great, I sometimes think I should have just gone there first. hahahhaha!
Greg
Hide Signatures
(in reply to AMB)
       Post #: 97
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 10:27 PM
AMB
Score: 110
Status: offline
HOBBSY`.. 17?? must be the baby virus, no cure LOL had to say that, family get togethers must really be an event martin
Hide Signatures
(in reply to greggles47)
       Post #: 98
RE: Need Help with Fox 15 Davis Conversion - 10/14/2012 10:50 PM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: Hobbsy
A new engine which is now getting what seems to be a much needed new p/l.
I'd say it was fair comment.
Hide Signatures
       Post #: 99
RE: Need Help with Fox 15 Davis Conversion - 10/15/2012 1:15 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: Hobbsy
.........and comparing a .40 to a .15 isn't what I'd call fair either.
Hi Dave,
            that comparison was already done when a .15ci engine was quoted using a 10x6 - the extropolation was linking that prop to what sized engine normaly would use one.
The unfairness lies in fair placing a 10x6 with any .15ci engine and then saying it does 10500 rpm in any usable form.
By democratic vote here, it just ain't possible.
Hide Signatures
       Post #: 100
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> RE: Need Help with Fox 15 Davis Conversion
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
