Idle = full power    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Idle = full power
Page: [1]
Login
Idle = full power - 10/5/2012 10:02 PM
Varhunter
Score: 100
Last Login: 10/15/2012
Status: offline
I'm helping a friend get his engine running after it's sat for a while.  I've got it running but the idle is waaaaaaaay too fast.  The throttle servo looks fine to me and the trim is down.  My thought is the idle adjustment.  I set it to factory break in settings but it's still running fast, it's like it's wide open at idle.
Hide Signatures
       Post #: 1
RE: Idle = full power - 10/6/2012 11:49 AM
Anthoop
Score: 121
Last Login: 5/19/2013
Status: offline
Remove the air filter and check the throttle gap...should be 0.5-1mm. If that is correct but it is still revving high, then the mixture is lean, richen the LSN.
What engine is it?
_____________________________
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to Varhunter)
       Post #: 2
RE: Idle = full power - 10/6/2012 8:28 PM
Varhunter
Score: 100
Status: offline
I see Thunder Tigre 27 on the side, The exhaust dumps out the back of the engine.  I've looked at that gap and it looks about right to me, I guess i'll try getting it smaller and see.
Hide Signatures
(in reply to Anthoop)
       Post #: 3
RE: Idle = full power - 10/6/2012 10:16 PM
Anthoop
Score: 121
Status: offline
I can not find a ThunderTiger .27 with a quick search, can you put some pictures up?
Is it a slide or barrel carb and how many adjustment screws are there?
Remember that if the gap is near and it still revs high then the mixture is too lean.
Hide Signatures
       Post #: 4
RE: Idle = full power - 10/6/2012 10:19 PM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
It might be the Super Tigre .27?
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
       Post #: 5
RE: Idle = full power - 10/6/2012 10:26 PM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: proptop
I had a feeling it was not a car engine at the start...and hi btw.
Is this the one Varhunter?
http://manuals.hobbico.com/sup/supg0727-manual.pdf
Hide Signatures
(in reply to proptop)
       Post #: 6
RE: Idle = full power - 10/7/2012 6:40 AM
proptop
Score: 130
Status: offline
Hi Anthoop...how are ya!? Where is Somerset? A good friend of mine was born in Kent...Suffolk (I think I spelled that correctly? ) but now lives over here in the states...Montana....but I digress
Actually, this is the engine I was thinking of...used in some of the Duratrax vehicles...
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLDF6&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLZJ1&P=SM
Edit: Added 2nd link to blue headed version...
< Message edited by proptop -- 10/8/2012 3:41 PM >
Hide Signatures
       Post #: 7
RE: Idle = full power - 10/7/2012 10:01 AM
Anthoop
Score: 121
Status: offline
I am good, thanks..hope you are too, been a long time since I saw you around these parts. Somerset is way down in the sunny (!) SouthWest, whereas Kent is over to the East....not so sunny.
The plot thickens then...looks like it is possibly the same engine....let us see if you are right.
Hide Signatures
       Post #: 8
RE: Idle = full power - 10/7/2012 8:25 PM
JohnP2
Score: 268
Status: offline
Get the "gap" as small as you can while still being able to start the car. If that does not work, check the clutch spring(s). I had this problem recently, and it turned out I broke a clutch spring. Let us know how you do.
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
       Post #: 9
RE: Idle = full power - 10/8/2012 2:28 AM
nitroexpress
Score: 150
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Varhunter
To clarify, is it running fast or wide open.  Two very different things.
Hide Signatures
       Post #: 10
RE: Idle = full power - 10/8/2012 2:38 AM
Varhunter
Score: 100
Status: offline
Prop top has it right, it has a blue head on it though but that's it.  It sounds like it's running wide open.  but like i said the carb isn't in the wide open position.
Hide Signatures
(in reply to nitroexpress)
       Post #: 11
RE: Idle = full power - 10/8/2012 4:12 PM
proptop
Score: 130
Status: offline
There might be some sticky-gooey old oil residue gumming up the works? Maybe try flushing out the carb w/ fresh fuel...you might need to pull the high speed needle out to do this throughly...and clean the slide too...
My thought is that the fuel passages in the carb might be partially restricted by old gummy fuel? (causing a lean condition...and maybe a sticking slide )
Hide Signatures
       Post #: 12
RE: Idle = full power - 10/8/2012 6:31 PM
Anthoop
Score: 121
Status: offline
You have set the LSN and HSN as in this link? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLZJ1&P=SM
...and richening the screws (anti-clockwise) makes no difference?
Then I agree that it is probably some gummed up fuel, could be in the carb/tank/pipes/exhaust nipple.
We know the engine is running lean if the gap is small enough...so either we are not supplying enough fuel or excess air is getting in. My guess is fuel starvation rather than an air leak as you say the engine has not been used for a while.
Hide Signatures
       Post #: 13
RE: Idle = full power - 10/8/2012 7:06 PM
Varhunter
Score: 100
Status: offline
I set it all to the models book that came with it, not the engine book.  I plan on tinkering with it again today. took the carb off, and opened the head up and sprayed carb cleaner in it to try and clean it out, even sprayed the muffler.
Hide Signatures
       Post #: 14
RE: Idle = full power - 10/8/2012 7:15 PM
Anthoop
Score: 121
Status: offline
What are the settings in the book?
LSN/HSN= how many turns?
Hide Signatures
       Post #: 15
RE: Idle = full power - 10/9/2012 3:59 AM
Varhunter
Score: 100
Status: offline
They were the same as shown there or really close but I figured it out and I feel so stupid, I took the air filter off to check the gap at closed and the servo was reversed.  Thanks for all your help guys.
Hide Signatures
       Post #: 16
RE: Idle = full power - 10/9/2012 4:04 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: proptop
Thats the same engine (though with a different color head yet..) that comes in the alligator tours r/c airboat. Same head design and carburetor, just a longer crankshaft. Its too bad SuperTigres aren't made in Italy anymore.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 17
RE: Idle = full power - 10/9/2012 5:15 PM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: Varhunter
Glad you got it fixed up. No need to feel stupid, the simplest things are often easily missed.
Hide Signatures
       Post #: 18
RE: Idle = full power - 10/10/2012 4:57 AM
Varhunter
Score: 100
Status: offline
That is very true lol, Thanks again for all the help.
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
