ae 15 stuck    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
RC10GT
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> ae 15 stuck
    Page: [1]
    Login
    ae 15 stuck - 10/6/2012 10:49 AM
    sjhm9102
    Score: 100
    Last Login: 3/28/2013
    Status: offline
    hi ae 15 rc10gt been sittin 5 years i got the motor unstuck now rope well rope doesnt want to catch the motor any help? thanks?
    Hide Signatures
           Post #: 1
    RE: ae 15 stuck - 10/6/2012 4:32 PM
    1QwkSport2.5r
    Score: 155
    Last Login: 5/24/2013
    Status: offline
    quote:
    ORIGINAL: sjhm9102
    Pull the one-way clutch out of the pullstarter and clean it with either fresh fuel or denatured alcohol. Run a soft towel soaked with alcohol through the middle of the bearing and rotate the bearing either direction a few times to get the oil sludge loosened up. One-way clutches tend to slip if the needle bearings can't move or if they're too wet with oil. When cleaned out, install dry without any oil and it should work well. While the One-way clutch (bearing) is out of the car, look the outside over to check for cracks. If its cracked, replace it. They will slip if the outer housing is cracked.
    Also, clean the starter shaft off really well with fuel or denatured alcohol and use some 400-600grit sandpaper to lightly "buff" the starter shaft going the long way. This will help the one-way clutch (bearing) to grip better.
    Hope this helps you.
    _____________________________
    *Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
    Hide Signatures
    (in reply to sjhm9102)
           Post #: 2
    RE: ae 15 stuck - 10/7/2012 4:20 PM
    sjhm9102
    Score: 100
    Status: offline
    thank you that helps a alot i aprecciate the write up on that i just got back into rc i am a novice
    Hide Signatures
    (in reply to 1QwkSport2.5r)
           Post #: 3
    RE: ae 15 stuck - 10/7/2012 7:13 PM
    1QwkSport2.5r
    Score: 155
    Status: offline
    quote:
    ORIGINAL: sjhm9102
    Post back if that works for you and gets you going.
    Hide Signatures
           Post #: 4
    RE: ae 15 stuck - 10/9/2012 12:29 PM
    sjhm9102
    Score: 100
    Status: offline
    hi i got the cover off and the rope recoil spool cameout with it how do i wind it back up set it .
    Hide Signatures
           Post #: 5
    RE: ae 15 stuck - 10/9/2012 5:30 PM
    Big Alice
    Score: 105
    Status: offline
       http://www.youtube.com/results?search_query=how+to+rewind+an+rc+engine+pullstart&oq=how+to+rewind+an+rc+engine+pullstart&gs_l=youtube.12...936.38118.0.41382.38.32.0.5.5.0.434.6218.0j15j10j3j1.29.0...0.0...1ac.1.kNw2g4pNNhU
    Hide Signatures
           Post #: 6
    RE: ae 15 stuck - 10/10/2012 3:49 PM
    sjhm9102
    Score: 100
    Status: offline
    thanks i got it wound up but i have about 2 inces of rope hangin i will wind it tighter btw i was looking at the o.s 18 crv s with 11 j rotary carb is it a big difference in hp and speed thank you in advance
    Hide Signatures
    (in reply to Big Alice)
           Post #: 7
    RE: ae 15 stuck - 10/10/2012 5:50 PM
    controlliner
    Score: 100
    Status: offline
    quote:
    ORIGINAL: sjhm9102
    Huge difference in power, "wheelies". I put one in my T-Maxx and does it ever perform now!
    "Keep it clean and not too lean" Duke Fox
    Hide Signatures
           Post #: 8
    Page:   [1]
    Page: [1]
    RC10GT
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.391RCU1
