BCMA engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> BCMA engine
Page: [1] 2   next >   >>
Login
BCMA engine - 10/6/2012 11:34 AM
Toysareforkids
Score: 100
Last Login: 5/8/2013
Status: offline
I have a BCMA 40 or 44, I don't know which. Can anyone tell me how to tell. Plus where I can find info, or a manual on the engine.
 I search and I can only find old threads on it, which don't answer my questions, and the web site everyone use to use, seems to be down
  Pat
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Toysareforkids -- 10/6/2012 12:38 PM >
Hide Signatures
       Post #: 1
RE: BCMA engine - 10/6/2012 2:07 PM  1 votes
BadAzzMaxx
Score: 448
Last Login: 5/22/2013
Status: offline
The BCMA is a re-branded SPE and also the same as a MT40
If I remember right SPE is now MLD
Any two stroke gas engine out of China will have about the same manual,
Milton
_____________________________
Contact Milton@rcextremepower.net
Team RCeXtremePower.com
Hide Signatures
(in reply to Toysareforkids)
       Post #: 2
RE: BCMA engine - 10/6/2012 2:10 PM  1 votes
KenLambert
Score: 155
Status: offline
It looks like a 42cc poulan
website
www.lambertsrc.com
Hide Signatures
       Post #: 3
RE: BCMA engine - 10/6/2012 2:36 PM  1 votes
BadAzzMaxx
Score: 448
Status: offline
Sure does, I never looked at the pictures before posting, Just has a RCexl ignition with a BCMA label.
The BCMA were rear mounted.
Milton
quote:
ORIGINAL: KenLambert
Hide Signatures
(in reply to KenLambert)
       Post #: 4
RE: BCMA engine - 10/6/2012 3:32 PM  1 votes
Super08
Score: 135
Status: offline
I am thinking the only thing that is from BCMA is the ignition.
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
(in reply to BadAzzMaxx)
       Post #: 5
RE: BCMA engine - 10/6/2012 3:55 PM
captinjohn
Score: 247
Status: offline
Hey if it runs good...run it like you stold it.   I am sure it is a Poulan.     Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to Super08)
       Post #: 6
RE: BCMA engine - 10/6/2012 9:42 PM
Toysareforkids
Score: 100
Status: offline
Thank you all!
      After your suggestion of it being a Poulan 42, I searched it, and it is a Poulan 42.
   I will now find a plan to a plane that I can build for it. I have no idea what yet!
  Thanks,  Pat
Hide Signatures
(in reply to captinjohn)
       Post #: 7
RE: BCMA engine - 10/7/2012 1:22 AM
KenLambert
Score: 155
Status: offline
it actualy looks like one of my mufflers
website
www.lambertsrc.com
Hide Signatures
       Post #: 8
RE: BCMA engine - 10/7/2012 10:59 AM
Lifer
Score: 148
Last Login: 5/23/2013
Status: offline
I have been using one for about 5 years. It is currently installed in a Hangar 9 150-size P-47. Best prop for that setup has been a XOAR 19x8. Not as powerful as other engines in its class but it has been trouble free. I would be happy to answer any questions that you have if it would be of any help.
Hide Signatures
       Post #: 9
RE: BCMA engine - 10/7/2012 6:17 PM  1 votes
av8tor1977
Score: 665
Status: offline
I'm not sure it is a Poulan 42cc. The Poulan 42cc had the ignition coil mounted in the chain saw; not on the engine. Looks like this engine has mounts for a coil on the cylinder. It might be a Poulan 46cc.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Lifer)
       Post #: 10
RE: BCMA engine - 10/8/2012 6:10 AM
Ernie Misner
Score: 130
Status: offline
Is it a simple piston port or is there a reed block in there?
Hide Signatures
(in reply to av8tor1977)
       Post #: 11
RE: BCMA engine - 10/8/2012 6:45 AM
av8tor1977
Score: 665
Status: offline
It is piston ported. Here's a pic of a 42cc.
AV8TOR
Click for fullsize
Hide Signatures
(in reply to Ernie Misner)
       Post #: 12
RE: BCMA engine - 10/8/2012 10:51 AM
KenLambert
Score: 155
Status: offline
thats the old style 42 they changed them for the EPA on the newer models. The 46cc has an oval carb adapter that slides on, but at this point it could be anything they all been sold and bought by so many companys.
website
www.lambertsrc.com
Hide Signatures
       Post #: 13
RE: BCMA engine - 10/8/2012 12:14 PM
Toysareforkids
Score: 100
Status: offline
Thanks guy's!
  Here is some more pictures of it.
 The exhaust has slots with nuts behind, to hold the muffler on.
 What is the tube that was added to the diaphragm cover for?
 I got this engine in a trade, and I guess he didn't know what it is either.
  Pat
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: BCMA engine - 10/8/2012 4:37 PM
captinjohn
Score: 247
Status: offline
The tube is so you can run a rubber line too the inside of the airplane to a place with dead air.  Not always needed.   For right now get it on a test stand or airplane to test run it and learn how to start & run it. Also getting the carb set too the right basic settings so it will run right. Capt,n
Hide Signatures
       Post #: 15
RE: BCMA engine - 10/8/2012 5:23 PM
w8ye
Score: 318
Status: offline
It might be a Homelite 45?
Doesn't really matter as long as it runs.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 16
RE: BCMA engine - 10/8/2012 5:35 PM
Lifer
Score: 148
Status: offline
BCMA was run by a guy named Adam who lived in Colorado. He eventually gave up. The engines are made by SPE, and are 43cc. They are currently sold by Cermark and Chief RC.
Hide Signatures
(in reply to w8ye)
       Post #: 17
RE: BCMA engine - 10/9/2012 1:50 AM
Toysareforkids
Score: 100
Status: offline
quote:
ORIGINAL: av8tor1977
AV8TOR
  It looks like you have yours on a stik. That is what I was thinking of building for mine. What inch wing do you have? What inch wing would you sudjest to use?
  I'm going to scratch build mine so any size is ok. I'm thinking maybe a 70-80" wing.  I have the plans for the 101" Bud Nosen big stik, that I could shrink down, or I also have the the plans for a 50" sweet & low, that I could blow up.  but I think I'd rather have a shoulder wing.
  Pat
Hide Signatures
       Post #: 18
RE: BCMA engine - 10/9/2012 1:52 AM
Toysareforkids
Score: 100
Status: offline
After looking at pictures of the SPE, they are not the same engines as mine.
  Pat
quote:
ORIGINAL: Lifer
Hide Signatures
(in reply to Lifer)
       Post #: 19
RE: BCMA engine - 10/9/2012 2:06 AM
Toysareforkids
Score: 100
Status: offline
 I kinda agree, But! If I hang it on the nose of a stik, and someone say's Hey! whats the engine your running, and I say a Poulan 42, and someone goes, No it's not! it's a Homelite 45, or something else, don't you know what you have!, I don't want to say no I don't know!
 Other wise I could care less. Like you say, as long as it runs good, it'll fly a plane.
 I don't care what it is, I just want to know.
 20 some years ago I had a Homelite on a GP 100" Cap 21, but it looked different. I don't remember what size it was now.
 Pat
quote:
ORIGINAL: w8ye
Hide Signatures
(in reply to w8ye)
       Post #: 20
RE: BCMA engine - 10/9/2012 2:33 AM
w8ye
Score: 318
Status: offline
The fact is . . . The engine was part of a trade and you're not sure what it is? And what is important is that it flies the plane and you are having fun.
The Poulan and Homelites like this were made different 10-15 yrs ago than they are now. These brands are still made today but they are a different design. In fact, now the Poulan, McCulloch, and Homelite in 46cc are identical except for the color.
Some important identifying features of the engine are that it has what's called a bolt on carb and was not one that had the carb mounted in the chainsaw case with a rubber bellows connecting the carb to the engine like they are today. The other important feature is that the coil originally fastened to the cylinder on this engine and was not mounted in the chainsaw case.
Some other facts about the engine was that these designs were typically from 33 to 50 cc. What rpm it turns what prop might be the best judge of what size it is?
There were probably more 42cc engines made than the other sizes?
Original AMA #31261
Hide Signatures
       Post #: 21
RE: BCMA engine - 10/9/2012 3:00 AM
w8ye
Score: 318
Status: offline
Here is a picture of a Poulan 46 and take notice that it has an adapter on the intake because this engine originally had a rubber boot to the carb. The carb was not a bolt on one.
< Message edited by w8ye -- 10/9/2012 3:47 AM >
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 22
RE: BCMA engine - 10/9/2012 3:06 AM
w8ye
Score: 318
Status: offline
Here are a couple pictures of a Poulan 42. Notice the bolt on carb and magneto
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 23
RE: BCMA engine - 10/9/2012 3:26 AM
w8ye
Score: 318
Status: offline
Later model Homelite 45 with the rubber boot type intake. There was a slightly earlier one with a bolt on intake
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 24
RE: BCMA engine - 10/9/2012 4:00 AM
w8ye
Score: 318
Status: offline
Studying all the pictures, I think your engine is a Poulan 42.
They should pull a 18 X 10 around 7200?
It is difficult to identify these as they changed little things from year to year?
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> BCMA engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
