RE: Himax power combo HC3514-2900 for Funjet ultra    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Himax power combo HC3514-2900 for Funjet ultra Page: <<   < prev  1 [2]
Login
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/9/2012 3:29 AM
commander dave
Score: 100
Last Login: 12/22/2012
Status: offline
I noticed the RPM numbers are off the chart. Max RPM for this motor should be 40,000. The downloaded data that is posted in the video above shows numbers at times that should not be possible. 3,000 to 175,000 RPM really?
Hide Signatures
(in reply to commander dave)
       Post #: 26
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/9/2012 3:41 AM
commander dave
Score: 100
Status: offline
I noticed the RPM is off the chart. It shows 3,000 to way over 100,000. Can that even be possible. This motor is rated to max at 40,000.
Hide Signatures
       Post #: 27
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/9/2012 3:25 PM
iron eagel
Score: 118
Last Login: 5/20/2013
Status: offline
There is no way a 2850KV motor would be spinning at 100 k on a three cell, there is something wrong there. For the rpm to jump like that the ESC must be losing sync with the motor would be my guess, I'd be interested in seeing whats CC has to say about that data.
What is really weird are the two spikes in current one at 109 amps the second at 140...
Is that data from the last video run you posted?
Now my software is a bit older what happened to the castle graph view for data it a lot easier to interpret than the spreadsheet? You can export a jpg like this.
Click to see fullsize image.
Click for fullsize
< Message edited by iron eagel -- 10/9/2012 5:43 PM >
Hide Signatures
       Post #: 28
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/10/2012 12:35 AM
commander dave
Score: 100
Status: offline
OK so I contacted CC again today. They hooked me up with Steve that specializes in airplanes. He said to go back a load an older version of the firmware. Version 3.27 and set the PWM at 8Khz and the timing to low. Tried this and holly sh.. it works. Full throttle with no crazy mode. Steve says that some of the more recent firmware has updates for helicopters and could me messing with my Himax setup. I can't say enough about how great CC is with their support and repairs. I have sent my cooked ESC's to them four times and they have fixed them all at no cost. I should have called them much earlier. Thanks to everyone for posted and giving support.
Hide Signatures
       Post #: 29
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/10/2012 12:47 AM
iron eagel
Score: 118
Status: offline
Go fly it and have some fun with it for a change.
Hide Signatures
       Post #: 30
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/10/2012 5:44 AM
airraptor
Score: 130
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: commander dave
lol isnt that what i said to do????
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 31
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/11/2012 12:39 AM
commander dave
Score: 100
Status: offline
Arirapter - Thanks for the input. As soon as this 45 degree Michigan weather and wind breaks I'm going to go out and hit it hard. Thanks
Hide Signatures
(in reply to airraptor)
       Post #: 32
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/11/2012 1:09 AM
MJD
Score: 125
Last Login: 5/13/2013
Status: offline
This thread reminded me that I really ought to own a power meter for the few electrics I do have. So today I grabbed a PowerMatch unit, seemed to have the specs needed for the stuff I fly. Too late to be of any use here though!
I try to be pessimistic, but why bother?
Hide Signatures
       Post #: 33
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/11/2012 1:33 AM
commander dave
Score: 100
Status: offline
MJD - Hope the post helps others with issues they may be having after upgrading the firmware and settings. Can't say enough good things about the folks at Castle creations. Great support and if you leave a message with them they respond very quickly with a call back. Like I have said in posts they have fixed my ESCs many times at no cost no questions asked. I will continue to buy their products for that reason. Also glade to see that you purchased the power meter. Nice to have a couple extra toys in the box.
Hide Signatures
(in reply to MJD)
       Post #: 34
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/11/2012 3:43 AM
MJD
Score: 125
Status: offline
I'm actually looking forward to the demise of the Funjet so the motor package can go in something a little more streamlined. That system is probably good for a bunch more speed in something with less frontal area.
Hide Signatures
       Post #: 35
RE: Himax power combo HC3514-2900 for Funjet ultra - 10/11/2012 4:32 AM
airraptor
Score: 130
Status: offline
No worries. Commander. Castle does a great job with customer service. Mjd when buying a watt meter look at the max amps it can handle as some of the normal ones only goto 75 amps and. Of super accurate there.
AMA # 186123
Hide Signatures
(in reply to MJD)
       Post #: 36
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
