Lipo Battery Fails    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Lipo Battery Fails Page: [1]
Login
Lipo Battery Fails - 10/6/2012 6:06 PM
Harv2828
Score: 100
Last Login: 5/14/2013
Status: offline
I have had four batteries ruined, some on the first run. The #6 cell of a 6S battery goes down to 3.0 while the other cells are OK. I use a Rimfire 60 motor, 6S 5000 45C battery, 100 amp esc with a 12x10. What is the probable cause...any help will be appreciated.
Hide Signatures
       Post #: 1
RE: Lipo Battery Fails - 10/6/2012 6:26 PM
4*60
Score: 111
Last Login: 5/24/2013
Status: offline
What batteries? Ratings vary.  Some claims on my smaller pack purchases have been completely bogus.
You have posted similsr over a 2 year period.  Same charger/tester???  Some balance lead extensions I have had have bad connectors and cause invalid errors.  Something wrong definitely since I hsve never run into this on any packs over 3-4 years!
_____________________________
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
(in reply to Harv2828)
       Post #: 2
RE: Lipo Battery Fails - 10/6/2012 6:38 PM
guver
Score: 174
Last Login: 5/23/2013
Status: offline
Two reasons that I can think of that will cause cell #6 to be lower than the rest at end of run.
Cell # 6 is the smallest capacity cell.
Cell # 6 started out at a lower voltage.
A couple of other reasons wouldn't show up in the first run.
and airplanes were in
Hide Signatures
(in reply to 4*60)
       Post #: 3
RE: Lipo Battery Fails - 10/6/2012 7:46 PM
Harv2828
Score: 100
Status: offline
Turnigy 6s 5000ma 45-90C
Hide Signatures
(in reply to 4*60)
       Post #: 4
RE: Lipo Battery Fails - 10/6/2012 7:51 PM
Harv2828
Score: 100
Status: offline
Re 6S failure. I even use a balancer to ge all cells down and then when charged with a CellPro 10S all cells go up to spec except #6 which doesn't take a charge. On another charger it won't charge at all and states " bad cell count". It's a puzzelment.
Hide Signatures
(in reply to guver)
       Post #: 5
RE: Lipo Battery Fails - 10/6/2012 7:59 PM
guver
Score: 174
Status: offline
Then It is probably reason 2. Cell 6 started at a lower voltage thus finished at a lower voltage.
Hide Signatures
       Post #: 6
RE: Lipo Battery Fails - 10/10/2012 4:22 AM
countilaw
Score: 219
Status: offline
quote:
ORIGINAL: Harv2828
Maybe you need to stop using   HK  batteries and start using    a product such as   Venom, or Thundertiger.     I heard a lot  of bad stuff about  Hobby King batteries.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 7
RE: Lipo Battery Fails - 10/10/2012 1:55 PM
rmh
Score: 252
Status: offline
quote:
ORIGINAL: countilaw
quote:
ORIGINAL: Harv2828
Frank
Pack failures are not brand specific -
the typical failure on Lipos starts with pushing the cells past a reasonable point Any brand
We use meters and check after every flight -takes 15 seconds - IF we have pushed pack to lower than 3.7 volts per cell - we change flight time or battery/prop - whatever- to keep keep the cell from being pulled down into 3.6 -or lower.that really screws up LiPos.
The low voltage cutoff in some ESC can be changed to cutoff at a higher point . Typically those which use a programming card include this feature
Libby is still watching you
Hide Signatures
(in reply to countilaw)
       Post #: 8
RE: Lipo Battery Fails - 10/10/2012 2:03 PM
Goldenduff
Score: 114
Status: offline
What amps do you draw?
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to rmh)
       Post #: 9
RE: Lipo Battery Fails - 10/10/2012 2:06 PM
trax de max
Score: 114
Status: offline
while there is some not very good lipos, A lot of the problems come from how the batteries are treated.
Using a poor charger which isn't as accurate as it should be.
If the cut off is set quite low but still at an ok level, but running till its hit all the time is not good for the battery either.
The damage is generally done at discharged voltage or fully charged voltage.
Sorry officer i thought the speed limit only applied to people with driving licenses.
Hide Signatures
(in reply to rmh)
       Post #: 10
RE: Lipo Battery Fails - 10/10/2012 3:07 PM
init4fun
Score: 168
Status: offline
quote:
ORIGINAL: Harv2828
I've never seen HK trash last longer than one flying season , at best , and I've got Hyperion and Thunderpowers that are going on 4 or 5 seasons with no failures . I use a Hyperion EOS0606i charger , balance charge every time , and use the packs all in the same airplanes . To me , I have seen the proof that Turdnigy IS junk and so it comes down to ; Pay more at the beginning and get better packs that last , or buy cheap and end up spending MORE by replacing the cheap packs every time they fail .
Does anyone honestly believe a cheap HK pack is comparable in quality to a Hyperion pack ? My real world flight results are all I need to see to prove buying the better packs makes better financial sense than wasting money on HK junk .....
up UP and Away !!!
Hide Signatures
       Post #: 11
RE: Lipo Battery Fails - 10/10/2012 3:43 PM
rmh
Score: 252
Status: offline
quote:
ORIGINAL: init4fun
quote:
ORIGINAL: Harv2828
I do - but it is dependant on size pack and application.
We buy stuf from 160 ma single cell to 5 cell at 5000 ma 40c
at $100.00 for a double pack as used for F3A - we simply cannot see using stuf which is double /triple the price when direct comparison shows little or no difference or worse yet, not as good.
Wheneach flight is same length -the same sequences -you get a very good basis for comparison.
Hide Signatures
(in reply to init4fun)
       Post #: 12
RE: Lipo Battery Fails - 10/10/2012 4:15 PM
Goldenduff
Score: 114
Status: offline
My HK (3cell 4000mah and 4cell 5000mah) are on the go up to 3 yrs later. I balance charge every time, store at 12 deg C, charge at 1C and discharge at 70% max of constant amp drain rate.
What amp did you try to get out of your 6cell?
Hide Signatures
(in reply to rmh)
       Post #: 13
RE: Lipo Battery Fails - 10/10/2012 7:34 PM
countilaw
Score: 219
Status: offline
Let's face it,   to sell cheap you have to buy cheap.          Cheap batteries are cheap because they don't pass the normal   quality control standards the same as the more expensive batteries.       Lipo will puff up  when charged due contamination within the pack.    They will puff up after being dropped or mistreated.
But mostly,   HK  buys cheap batteries that are substandard to start with and sell them cheap to unsuspecting people who buy only because the batteries are cheap and they think they are getting a good deal.   When actually they are buying substandard batteries that can't or haven't pass quality control.
Frank
Hide Signatures
(in reply to Goldenduff)
       Post #: 14
RE: Lipo Battery Fails - 10/10/2012 10:17 PM
Goldenduff
Score: 114
Status: offline
Well I have bought so many HK lipos that are good that even if the next 5 10 I buy are rubbish I will not be out of pocket. I rarely charge over 1c, balance charge them 9 out of 10 times and draw about 70% of their theoretical constant output. I live in Scotland so it's too easy to store at 10 deg C. Never had trouble with several 3 and 4 cells.
Again, what amps was the original poster trying to draw from the 5amp 45c 6cell lipo? More than 150amps I would say is too much.....
Hide Signatures
       Post #: 15
RE: Lipo Battery Fails - 10/12/2012 4:03 AM
1THEPALMER
Score: 100
Status: offline
Wow Frank, check your sig line. You appear to have made it your JOB to slag HK LiPos in every thread they are mentioned.
Are you payed by another battery supplier to do this?
Hide Signatures
       Post #: 16
RE: Lipo Battery Fails - 10/12/2012 2:36 PM
init4fun
Score: 168
Status: offline
quote:
ORIGINAL: 1THEPALMER
Frank , Like just about any other thinking person is , , , Is reflecting on the fact that HK actually has the gall to advertise for help wanted from regular hobbiests to SHILL their products on the various RC forums . It's been reprinted DOZENS of times in various threads around here (the HK want ad looking for shills , that is) . Now since HK won't play by the rules and have their paid reps wear the "I work for HK' logo in their avatars , it makes any and all on line praise they receive suspect . Let me ask you a question here , , Do you have any proof that Frank may be in the employ of another hobby company ? Can you show me an ad from ANY other RC company advertising for shills like HK has done ?
I'll say it again ; Since HK advertises for people to praise their products on line , without identifying themselves as HK employees , ANY AND ALL HK PRAISE IS NOW SUSPECT !
What's so hard for you guys who are enjoying the HK "Bargains" to understand about that ?
up UP and Away !!!
Hide Signatures
(in reply to 1THEPALMER)
       Post #: 17
RE: Lipo Battery Fails - 10/12/2012 3:34 PM
Goldenduff
Score: 114
Status: offline
I'm enjoying bargains and appreciate that some of their products are sub quality.
Hide Signatures
       Post #: 18
RE: Lipo Battery Fails - 10/12/2012 7:26 PM
trax de max
Score: 114
Status: offline
quote:
ORIGINAL: Goldenduff
I'm just tight, Not one of the 4 packs have caused any concern for me. But I have read that people had problems with the high capacity packs not being reliable and unstable. I would still buy from them as good brand batteries are just too expensive for me.
Hide Signatures
       Post #: 19
RE: Lipo Battery Fails - 10/12/2012 9:21 PM
Goldenduff
Score: 114
Status: offline
I agree, I would be grounded without HG. However I would probably buy more expensive if I had heaps of money!
Hide Signatures
(in reply to trax de max)
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
