Rampage xt gas leak problem help!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Rampage xt gas leak problem help!
Page: [1]
Login
Rampage xt gas leak problem help! - 10/6/2012 9:51 PM
007mrdr
Score: 100
Last Login: 3/30/2013
Status: offline
  hi guys today i was driving my rampage xt and had a half full tank but it all ran out in about 20-25 minutes i was putting more gas in there but i saw that there were some gas dripping from the air filter i took the sponges off the air filter coming from -i guess-  there is a thing that opens and closes when you turn choke on and off some yellow or goldenish thing i guess that is where the air and the gas meets and there was lots of gas in there. i did some drifting and lots of turns with the car can it be because of that ? need your help guys hope its not a big thing thanks
_____________________________
Cars: E-Revo vxl(2s) - Redcat Rampage XT(95octane) - HPI Racing Savage XS(2s)
Hide Signatures
       Post #: 1
RE: Rampage xt gas leak problem help! - 10/7/2012 11:07 PM
bbuzzard
Score: 101
Last Login: 5/21/2013
Status: offline
That yellow goldish thing is the choke valve...not sure what you are describing with the fuel dripping. BTW, I only get about 35 minutes with a full tank, so I don't where you are having fuel problem.
Baja SC / Redcat Rampage MT / FG Marder(XTM) / Hurrax Crypton / Nutech MMT
Hide Signatures
(in reply to 007mrdr)
       Post #: 2
RE: Rampage xt gas leak problem help! - 10/8/2012 5:40 AM
007mrdr
Score: 100
Status: offline
www.icloud.com/photostream/#A95oqs3qGDBpaS here are some pics the fuel is coming out from where the choke valve is at. All the air filter sponges was all full of fuel i took them off to check out and saw that the place where the choke valve was full of fuel hope its not important and btw i havent tuned it yet and a full tank goes about 45 minutes and will to much oil in the mixture make any problems?
Hide Signatures
(in reply to bbuzzard)
       Post #: 3
RE: Rampage xt gas leak problem help! - 10/8/2012 7:13 AM
splcrazy
Score: 100
Last Login: 5/18/2013
Status: offline
how is the compression ? fuel flooding into the air filter is a sign of a bad ring happening .
Hide Signatures
       Post #: 4
RE: Rampage xt gas leak problem help! - 10/8/2012 3:31 PM
007mrdr
Score: 100
Status: offline
quote:
ORIGINAL: splcrazy
what does it mean ? this is my first gas engined rc so if you can explain more i will be happy thx
Hide Signatures
(in reply to splcrazy)
       Post #: 5
RE: Rampage xt gas leak problem help! - 10/8/2012 3:41 PM
bbuzzard
Score: 101
Status: offline
I can't tell from those pics...Are you sure it is actual fuel or  the filter oil on the inside of the filter housing? You will have some fuel spray inside the front carb area but from the pics, it doen't look like a problem.
quote:
ORIGINAL: 007mrdr
Hide Signatures
       Post #: 6
RE: Rampage xt gas leak problem help! - 10/8/2012 5:23 PM
007mrdr
Score: 100
Status: offline
İ am sure that it is fuel I smelled it and the fuel seemed to be coming out from the choke valve housing or somewhere deeper the pics were taken after it was dry. And the filter sponges were all wet im sure no oil because i havent oiled it and it was completely dry before running but then when i squeezed the sponges there
were lots of fuel in the sponges then i opened it and saw fuel coming from the choke housing
Hide Signatures
       Post #: 7
RE: Rampage xt gas leak problem help! - 10/8/2012 5:34 PM
bbuzzard
Score: 101
Status: offline
You need to make sure you oil those oil filters or you will kill the motor in dirty situations. This may be an issue that the fuel is soaking through because you didn't oil the filters.
Hide Signatures
       Post #: 8
RE: Rampage xt gas leak problem help! - 10/8/2012 7:16 PM
007mrdr
Score: 100
Status: offline
quote:
ORIGINAL: bbuzzard
youre right i couldnt do it cause i had no oil or wd-40 etc with me and i was just using it onroad cause i didnt oil it well hope you are right next time ill oil it and try again
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
