RE: SPITFIRE MK9 Composite ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: SPITFIRE MK9 Composite ARF
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:08 PM
dany golan
Score: 100
Last Login: 5/22/2013
Status: offline
Thanks Roy
The dimensions of the exhaust stacs are:
Total length of each exhaust 50 mm
Exit opening length 30 mm
Exit opening width 10 mm
Hide Signatures
(in reply to roydefiant)
       Post #: 26
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:28 PM
dany golan
Score: 100
Status: offline
quote:
ORIGINAL: Rebel Flyer
Nice looking Mark... I do have a few questions.
1. How far back did you have to move the engine back?
2. How much weight did you have to add up front?
3. What equipment, if any did you have aft of the cg?
4. Are you using the small inboard flaps that you have to cut out?
I want to do the same mark and I also have a DA85 with the Slimline muffler. I also have a Quadra 100 and have not decided which motor to go with.
The Quadra is about 10 pounds too.
Thanks for the input. Rebel
Thanks Rebel
We installed the engine directly to the firewall . We had to cut the lower part to allow the installation of exhaust. By the way, the Slimline exhaust is very wide and touches the cowl sides.Therefore, we had to push the cowl sides out about 3 mm on both sides.
We added about 3 kg in the nose above the engine
We installed the tail landing gear, ruder end elevator servos + the reciver behind the cockpit.
Yes, we use the inboard flaps. We conected them to the main with guid pin like the full size plane
< Message edited by dany golan -- 10/7/2012 10:46 PM >
Hide Signatures
(in reply to Rebel Flyer)
       Post #: 27
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:34 PM
dany golan
Score: 100
Status: offline
Building the instrument panel
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dany golan)
       Post #: 28
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:36 PM
dany golan
Score: 100
Status: offline
Building the Chassis control
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 29
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:38 PM
dany golan
Score: 100
Status: offline
Building the Throttle quadrant
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 30
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:40 PM
dany golan
Score: 100
Status: offline
The cockpit is now assembled including all scale details
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 31
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:43 PM
dany golan
Score: 100
Status: offline
Building the cannons and machine guns
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 32
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:45 PM
dany golan
Score: 100
Status: offline
Operational navigation lights
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 33
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:52 PM
dany golan
Score: 100
Status: offline
Building the radiators
we modified the original radiators cowls edding the flaps and radiators screens. We used car air condition radiator screen. we cut parts of it and intalled in the cowls
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 34
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:54 PM
dany golan
Score: 100
Status: offline
Assembly and installation of the systems and components such as: Receiver and electrical system, servo and flight control systems, Landing gear air system, fuel system, Ignition system, Chock system (servo operated), switches and more....
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 35
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:56 PM
dany golan
Score: 100
Status: offline
Painting process and marking
We used Hambrol modeling paint and finished with 50% mat transparent lacquer
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 4:59 PM
dany golan
Score: 100
Status: offline
And finally the Meiden with the controls in Avi Sirota`s good hands
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 7:23 PM
nudger
Score: 105
Last Login: 5/20/2013
Status: offline
Hi dany golan
Just like to say some of the best modelling work I've seen,and that cockpit is a work of art.
Excellent. Nudge
Hide Signatures
       Post #: 38
RE: SPITFIRE MK9 Composite ARF - 10/7/2012 9:10 PM
rcguy59
Score: 129
Last Login: 5/23/2013
Status: offline
WOW!!! Fantastic work. You've done it justice and then some.
_____________________________
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to nudger)
       Post #: 39
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 1:27 AM
roydefiant
Score: 100
Status: offline
amazing, thanks for measurements
Hide Signatures
(in reply to rcguy59)
       Post #: 40
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 2:50 AM
kwblake
Score: 110
Status: offline
Unbelievable craftsmanship.  I have to tell you, that when I first looked at the photos of your plane, I thought " why would they be posting photos of the restored aircraft?"  The top far right photo must be of the real thing.  You gentlemen are true master craftsmen.
You should all be very proud!
Kevin
Hide Signatures
       Post #: 41
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 3:19 AM
kwblake
Score: 110
Status: offline
Oops.  I misread your original post.  I thought this was a build by your club. Two of you? Unreal !!
Kevin
Hide Signatures
(in reply to kwblake)
       Post #: 42
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 3:54 AM
FireBee
Score: 100
Status: offline
Dany, Avi,
You have completely mastered this Spitfire. Every detail is incredible and as a whole she is truly an awesome airplane. Looks great from every angle in the air or the ground shots.
I volunteer at the museum where the restored aircraft is flown quite regularly. Here is the link
http://www.militaryaviationmuseum.org./
Along the back wall of the hanger is a picture when she was found in a school yard in your country. The restoration and your replication is perfect . . As I'm sure the pilot is just out for afternoon tea!
Regards, Mike
Mike P.
Hide Signatures
       Post #: 43
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 3:58 AM
FireBee
Score: 100
Status: offline
You need to post some thoughts and pics on the RCU thread. "Spitfire Brotherhood". Such a plane should be seen by all.
R, Mike
Spitfire Brotherhood #8.
Mike P.
Hide Signatures
(in reply to FireBee)
       Post #: 44
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 5:10 AM
fw190
Score: 100
Status: offline
Amazing work! Thanks for sharing
Happy Flying!
Hide Signatures
       Post #: 45
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 10:30 AM
verbails
Score: 100
Last Login: 5/19/2013
Status: offline
Hi Mr Golan
Your work and that of your friend is awesome. I work on a airfield with several Spitfires and I can confirm you cockpit it bang on accurate now if you only had a 14 inch tall person you could ditch your transmitter.
Chris
Hide Signatures
(in reply to fw190)
       Post #: 46
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 1:33 PM
avi sirota
Score: 100
Status: offline
Hello all,
Thanks for the kind words and compliments. This project was interesting in doing both the background investigation as well as the scale detailing and flying.
Working with Dany is challenging because everything must be accurate and more then that-unique. Other then the nuts and bolts almost everything was made by hand out of everyday items such as wood plastic or any other "junk" in the workroom. You can only imagine how many times we called each other in strange hours of the day (and night) saying: hey! I've got an idea how to make the panel\guns\flaps and so on…
On the other hand we followed the KIS rule: keep it simple .
Part of my job in this project was to install the radio and power equipment without violating the cockpit. I had many nights spent routing and modifying the entire plane just to go around the cockpit. Looking at the entire plane one can find a new item every time even after hundreds of hours with it.
Thank you for spending the time to follow our project.
Avi
Hide Signatures
(in reply to verbails)
       Post #: 47
RE: SPITFIRE MK9 Composite ARF - 10/8/2012 1:54 PM
flyingchef
Score: 105
Status: offline
Beautiful work!
You mentioned that 3Kg (6.6lb) of nose weight was added, what is the plane total weight?
If you make a trip to Denver, bring your Spitfire, I would love to fly mine and yours in formation!
Great Job again!
Click for fullsize
Bruno
Spitfire Brotherhood #41
Hide Signatures
(in reply to avi sirota)
       Post #: 48
RE: SPITFIRE MK9 Composite ARF - 10/9/2012 9:58 PM
dany golan
Score: 100
Status: offline
Thanks everyone for your kind words.
Bruno,
The overall weight of the aircraft is 18 kg (39.6 lb)
The model flys Great
We would love to fly together with you, but we are located on the other side of the globe .....
Hide Signatures
(in reply to flyingchef)
       Post #: 49
RE: SPITFIRE MK9 Composite ARF - 12/11/2012 9:31 AM
dany golan
Score: 100
Status: offline
Hello everyone
Here's some pictures and video from the annual meeting of the Israeli Scale club that took place last weekend at Ketziot in southern Israel
The Spitfire is flown by Avi Sirota
http://www.youtube.com/watch?v=GXlWFkIAfFw&feature=youtu.be
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.564RCU1
