RE: My 1st Kit Progress    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: My 1st Kit Progress
Page: <<   < prev  1 [2]
Login
RE: My 1st Kit Progress - 10/8/2012 6:46 PM
carrellh
Score: 179
Last Login: 5/24/2013
Status: offline
quote:
I'm having a tough time picking my covering colors
My first kit built trainer was mostly dark blue, with yellow tail and wing tops. It was not very pretty but was easy to see.
I had two ARF trainers, before I built the PT-60 kit, that were mostly white. They were O K but I prefer the dark base with bright trim.
I am a fan of red and white. For me it is very visible in the air. Mostly red, with the white on top of the wings and on the sides of the fuselage.
My Corsair is a tribute to http://www.warbirddepot.com/aircraft_fighters_f2g-race57.asp but it is solid red on the bottom.
The Astro Hog is covered like the picture on the box.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
- Carrell
Hide Signatures
(in reply to BillinIndiana)
       Post #: 26
RE: My 1st Kit Progress - 10/8/2012 7:35 PM
WB6JGD
Score: 100
Last Login: 5/25/2013
Status: offline
The Thunder Tiger GP series engines are good engines.
Bill, I have copied and pasted a couple of links about covering a model airplane. There is a lot of good information here. Mike did a very nice job on the how-to article and the covering videos.
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=726
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=67
- Allan B
Cub Brotherhood #180
Hide Signatures
(in reply to Zor)
       Post #: 27
RE: My 1st Kit Progress - 10/8/2012 7:39 PM
All Day Dan
Score: 151
Status: offline
Bill, I’ve been building for the past 65 years. Be sure to speak to your loved ones before you continue. It’s a great addiction for which there is no rehab. Dan.
Dan
Hide Signatures
       Post #: 28
RE: My 1st Kit Progress - 10/8/2012 7:55 PM
huck1199
Score: 115
Status: offline
Bill
Here are some pics of my color scheme
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Zor)
       Post #: 29
RE: My 1st Kit Progress - 10/8/2012 9:14 PM
BillinIndiana
Score: 100
Status: offline
Thanks for all the info everyone.
  I was planning on doing some checkers too. That is one part I knew I was going to put on.. Now for the rest of the plane  IDK?...hahaha
Hide Signatures
(in reply to huck1199)
       Post #: 30
RE: My 1st Kit Progress - 10/8/2012 9:24 PM
RCKen
Score: 416
Status: online
Bill,
Consider doing some kind of straight line down the fuselage. It can be a line, or a line where you change colors on the fuselage. The reason for this is that the straight line will help you in orientation of the plane when it is in the air.
Another good trick for orientation is to have contrasting colors on the top and bottom of the wing. That was you will be able to tell instantly which way your plane is oriented. Look at doing strong bright colors for your covering scheme. Reds and yellows are usually the easiest to see. whites, blues, and lighter colors should be avoided as they will tend to blend into the background of the sky.
As a funny side note, we had a guy come to our field that had a plane covered in silver monokote. Look sharp as all get out on the ground. Then he took off and the plane simply disappeared into the sky!!!!!!
You definitely want your plane to be very very visible to you. always remember that when you design a covering scheme. I have a Senior Telemaster that I use for piggy-backing gliders up to altitude with. Since it's getting way WAY up there in altitude I covered the bottom of the wing with Cub Yellow and black checkerboards on the wing tips to aid in visibility when it was up at a high altitude.
Hope this helps
Ken
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
Ultra Sport Brother #1
www.gettingairborne.com
Hide Signatures
       Post #: 31
RE: My 1st Kit Progress - 10/8/2012 10:11 PM
BillinIndiana
Score: 100
Status: offline
quote:
ORIGINAL: RCKen
I actually bought a roll of Ultracote "Chrome", thinking it would reflect the sun.. maybe not ....?
Hide Signatures
(in reply to RCKen)
       Post #: 32
RE: My 1st Kit Progress - 10/8/2012 10:14 PM
huck1199
Score: 115
Status: offline
You could use the chrome on the windows as I did.
Hide Signatures
       Post #: 33
RE: My 1st Kit Progress - 10/9/2012 1:07 AM
Fs one
Score: 105
Last Login: 5/13/2013
Status: offline
You aredoing a great job .Reminds me when i first started.Keep up the good work doing a fine job.Give us a few pics when she's all done.Didn't read anywhere the fella asking for help.Give the guy some encouragement.
Norm
Hide Signatures
       Post #: 34
RE: My 1st Kit Progress - 10/9/2012 1:31 AM
RCKen
Score: 416
Status: online
quote:
ORIGINAL: BillinIndiana
quote:
ORIGINAL: RCKen
I actually like to put a 1/2" strip of chrome monokote on the leading edge of my planes. I find that helps me to see the plane better on the landing approach, but I have had others at my field tell me that it would distract them to see that glint off the leading edge when the plane is coming in for a landing. Something like that is a personal choice.
Ken
RCU Forum Manager
Hide Signatures
       Post #: 35
RE: My 1st Kit Progress - 10/9/2012 3:25 PM
Zor
Score: 181
Status: offline
quote:
= RCKen
Ken
Ken,
I agree that it is a personal choice.
I have tried the silver reflecting strip on the leading edge once.
It was not "chrome monokote"; it was a self-adhesive aluminum foil.
I did not like the sun reflection as the model on final approach coming toward me was reflecting the sun rays coming from my back. That sun reflection was changing and doing some flashing as small maneuvering was taking place toward the center line of the runway.
I paint nearly all my wings with a white leading edge to contrast with the usually green backgound.
This avoids any variable sun flashing as approach speed is being controlled.
To each his preference.
Regards from Zor
< Message edited by RCKen -- 10/9/2012 4:18 PM >
Hide Signatures
(in reply to RCKen)
       Post #: 36
RE: My 1st Kit Progress - 10/10/2012 1:41 AM
green river rc
Score: 100
Last Login: 3/5/2013
Status: offline
Always good to see kit building is still alive, much more rewarding than pulling it out of a box and having the exact same plane as the next guy.
With the parts left over, Im going to build a motorcycle.
Hide Signatures
(in reply to Zor)
       Post #: 37
RE: My 1st Kit Progress - 10/10/2012 8:06 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: green river rc
green river rc,
It is a matter of what an individual enjoys as a hobby.
Having two (or more) identical models allows the owners and pilots to compete as to their abilities to setup the model and compare themselves as pilots.
Competing is part of human society.
Zor
Edited 11 Oct. 2012 at 23:47 EDT to change the name from "greem" to "green".
Sorry about the mispelling of a name.
End
< Message edited by Zor -- 10/12/2012 4:47 AM >
Hide Signatures
(in reply to green river rc)
       Post #: 38
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
