Volcano EXP Pro - electric - full throttle at startup    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Volcano EPX PRO
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano EXP Pro - electric - full throttle at startup
    Page: [1]
    Login
    Volcano EXP Pro - electric - full throttle at startup - 10/8/2012 1:47 AM
    MrJim
    Score: 100
    Last Login: 4/14/2013
    Status: offline
    Looking for some help with my Red Cat Volcano EXP Pro –
    When the radio is switched on, and then the car is switched on. There is a red light that comes on solid. The motor/throttle jumps to full speed uncontrollable. I do have steering control when this happens but no throttle control.forward or reverse.  I unplugged the battery, reconnected, changed the battery’s in the remote control. I am new to this and don’t know what to do from here. Any help? Thanks
    Hide Signatures
           Post #: 1
    RE: Volcano EXP Pro - electric - full throttle at startup - 10/8/2012 2:16 AM
    nitrosportsandrunner
    Score: 296
    Last Login: 6/19/2013
    Status: offline
    quote:
    ORIGINAL: MrJim
    1st, rebind your radio to your reciever.
    process shown in this video:
    http://www.youtube.com/watch?feature=player_embedded&v=cXwhQzfwbL4
    then recalibrate the ESC to the radio.
    Process shown in my video here:
    http://www.youtube.com/watch?v=_OkwkziFWE8
    If you do both those things you should get throttle control back.
    _____________________________
    SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
    Hide Signatures
    (in reply to MrJim)
           Post #: 2
    RE: Volcano EXP Pro - electric - full throttle at startup - 10/14/2012 3:21 AM
    MrJim
    Score: 100
    Status: offline
    I followed the instructions to bind and calibrate. Afterwards there was no difference. Sometimes it appears to be working and I can run it for a few minutes. Then the throttle becomes unresponsive, no forward or reverse, and then starts to work again. Or it might take off at high speed uncontrollably. There is no consistency to what this will do.
    I’ve had this for about 2 months with no issues until now. Any other suggestions?
    Hide Signatures
    (in reply to nitrosportsandrunner)
           Post #: 3
    RE: Volcano EXP Pro - electric - full throttle at startup - 10/14/2012 1:50 PM
    Score: 296
    Status: offline
    quote:
    ORIGINAL: MrJim
    do you own any other radio systmes? If you do, drop it into the volcano.
    What you describe could be the radio/reciever being messed up....or it could the esc.
    If you can find out for sure which...then go to redcat's site and fill out the warrenty form and detail the issue and what you have tried.
    did your reciever ever get wet? The flysky recievers dont like even a drop of water!
    Hide Signatures
    (in reply to MrJim)
           Post #: 4
    RE: Volcano EXP Pro - electric - full throttle at startup - 10/15/2012 12:20 AM
    bpohl
    Score: 100
    Last Login: 5/3/2013
    Status: offline
    I had the same issue with my son's exceed infiniy. It has the same style ESC. It end up being a ESC being bad. Another way to rule out ur receiver is swap the plugs were ur servo and ESC plug into. Put ur ESC in the steering spot and ur steering servo where ur ESC would normally go.  If it steers to one direction and won't come back than u know its the receiver or radio.  If it does the same you can pretty much figure it's ur ESC. I agree with Nitro. They don't like moisture at ALL!
    Hide Signatures
           Post #: 5
    RE: Volcano EXP Pro - electric - full throttle at startup - 10/15/2012 5:13 AM
    MrJim
    Score: 100
    Status: offline
    Thanks for the tip. I switched the connectors and sure enough I had throttle forward and reverse with the steering wheel, and left right control with the throttle trigger. I filled out the warranty form for the ESC with Red Cat.
    Hide Signatures
    (in reply to bpohl)
           Post #: 6
    Page:   [1]
    Page: [1]
    Volcano EPX PRO
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.406RCU1
