Great Planes Matt Chapman Eagle 580 EP ARF 50"    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> Great Planes Matt Chapman Eagle 580 EP ARF 50" Page: [1]
Login
Great Planes Matt Chapman Eagle 580 EP ARF 50" - 10/8/2012 3:05 AM
rrlouis
Score: 100
Last Login: 10/21/2012
Status: offline
I just purchased this plane, my first sport plane. I plan to fly this with:
E-590 Power Up 32 Sport Outrunner Brushless motor
E-191 HURC 80 Amp OPTO Brushless Motor ESC (overkill, I know)
G-150 3 Amp UBEC
Either a 3S 2200mah or a 4S 2600mah Lipo
Hitec 19g HS-82MG Metal Gear Micro Servos
I have been watching for posts on modifying the problems others have had, and I've seen some ideas on beefing up the landing gear supports in the fuse using plywood up the sides and along the bottom behind the gear mounting plate. I've also plugged the stock mounting holes on the motor mount and re-drilled for the larger x-mount of the Power Up 32 motor with no problem. But I don't like the connecting bar for the two elevator halves. As others have reported, it seems that it will develop some flop after a while. I figure that I will use one servo for each elevator, but I am unsure how to do this. If I mount them mirror image on each side of the fuse, I will have rotation sync problems if I use a y-harness. Can I overcome this by mounting one upside down from the other so that as both rotate clockwise, one will push from the bottom and the other from the top, or should I just use two channels for this with my Spektrum DX7S? I was planning to use two channels also for the ailerons. Is this too much?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Great Planes Matt Chapman Eagle 580 EP ARF 50 - 1/21/2013 6:31 AM
bobbitchen
Score: 100
Last Login: 2/12/2013
Status: offline
I know it's over 3 months since your post, but I have the same plane and run 2 elevator servos. Right half goes to ELEV and left half goes to AUX2. Select dual elevator for Wing Type in setup screen, reverse as needed and you're in business
Hide Signatures
(in reply to rrlouis)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
