RE: Let's gasify a Vanquish    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: Let's gasify a Vanquish
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Let's gasify a Vanquish - 10/16/2012 7:01 PM
papaone
Score: 100
Last Login: 5/20/2013
Status: offline
Hello
Friend of mine told me that exhaust header forZDZ 4O RE is the same as PTE36R except dimension HF (see picture)
Dimensions HF of PTE36R is 15 mm.
Header :
I think it's easier to machine it.
http://www.troybuiltmodels.com/items/JMB40REHEADER-25.html
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Rocketman_)
       Post #: 26
RE: Let's gasify a Vanquish - 10/17/2012 2:37 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: papaone
Hello
Header :
Claude and all,
Just a quick heads ups....The Macs header for the OS140RX has the exact bolt spacing needed for the PTE36. The exhaust port is also practically identical.
I checked this with a new header I had laying around. Apparently the old header I was using was a Webra header so what I stated earlier about needing some relocating of the bolt holes is wrong. The MACS OS140RX header is a drop in fit. The only thing it will need is to drill out the holes to accept M5 bolts (original holes are for M4)
_____________________________
Regards,
MattK
Hide Signatures
(in reply to papaone)
       Post #: 27
RE: Let's gasify a Vanquish - 10/18/2012 4:28 AM
vatechguy3
Score: 100
Status: offline
thats good news.
have you run the pte36 before, or will this one be a first for you matt?
tony
Hide Signatures
(in reply to MTK)
       Post #: 28
RE: Let's gasify a Vanquish - 10/18/2012 3:58 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: vatechguy3
thats good news.
tony
No, it's the first one. Can't vouch at all for anything pertaining to this powerplant. It's pretty cheap engine at $270 so it was a no brainer to get one for testing
My original intent was to run the OS in the plane. But since I had the PTE on hand as well as the header, why not? Plus the rear exhaust configuration really makes it elementary.
On the other hand, I made mounting the soft mount common to both engines so I have options just in case the PTE is inadequate. The OS is a known at this point
Regards,
MattK
Hide Signatures
(in reply to vatechguy3)
       Post #: 29
RE: Let's gasify a Vanquish - 10/19/2012 3:26 AM
MTK
Score: 203
Status: offline
Here are a few more photos of the structural conversion. Triangle stock placed in strategic places. Then 1 layer of 4 oz glass epoxied around the firewall and the box sides, as shown.
The added lite ply top with cross members will keep the top side from flexing too much
All holes in the front of the fuse will be covered over with paper to better channel hot air away from inside the fuse
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 30
RE: Let's gasify a Vanquish - 10/19/2012 3:36 AM
MTK
Score: 203
Status: offline
Decided to also add doublers just aft of the landing gear box. This area only had a 1mm plywood perimeter as shown in one of the photos. It may not really need any other reinforcement but I felt that with the balsa sheeting only 3mm thick in this area, a bit more balsa is likely warranted.
Added 3mm doublers as shown, recessing the edges to sit flush against the 1mm plywood perimeter frame. Recessing was simple with a sanding block. I probably used more gorilla glue than necessary as shown by the foamed glue around the edges of the doubler
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 31
RE: Let's gasify a Vanquish - 10/21/2012 10:30 PM
Giant_Scale_Gasser
Score: 140
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: MTK
thats good news.
tony
For what it's worth, I just purchased a Piedmont Focus 2 with a Syssa 30 in it and if the PTE runs anywhere near what the Syssa does in terms of power, Oh My Gosh it will be a bullet!
I have never owned a pattern ship, but after watching a fellow hobbyist put the focus 2 thru it's paces, I just had to have it. Amazing speed and quite literally unlimited vertical. That joker will get out of site in a hurry, accelerating straight up.
I didn't have a way to bring her hoime from the field after striking the deal, but I should have her in my hangar sometime this week. You pattern guys and the ships you fly are simply.... AMAZING.
Hide Signatures
(in reply to MTK)
       Post #: 32
RE: Let's gasify a Vanquish - 10/22/2012 2:52 AM
MTK
Score: 203
Status: offline
The SAP180 is a great engine. I've done a whole thread on it alone. Learned an awful lot about gas engines in this size from the SAP experience. Still have one on hand.....Good luck with your set-up...
Regards,
MattK
Hide Signatures
(in reply to Giant_Scale_Gasser)
       Post #: 33
RE: Let's gasify a Vanquish - 10/22/2012 3:06 AM
MTK
Score: 203
Status: offline
Back to the topic at hand.....During the fitting of the stab I encountered a problem that any of you guys contemplating the Vanquish as your next ride should know about. The set-screws used for stab adjustment would not go in easily so I chased the threads with an M4 tap, The adjustment block inside the stab is aluminum so you don't want to cross thread anything here.
Well, the first side worked fine. Chasing threads is a simple task and should be done where ever one encounters resistance in existing threads, cleaning them up rather than X-threading them
The second side was a different issue..... the aluminum block came off inside the stab. Easy enough to take out and inspect the part. One small screw was all it was held by, plus some adhesive, possibly ca. It just wasn't enough to hold the torque of the tap and popped off.
No big deal and actually I'm kinda glad it happened on my bench. The aluminum block has two mounting holes so I am tapping these for some 4-40 screws and reinstalling the part with a pair of flat heads through the root ply rib. I'll take a few photos and show you what I did
< Message edited by MTK -- 10/22/2012 3:02 PM >
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 34
RE: Let's gasify a Vanquish - 10/22/2012 4:09 AM
MTK
Score: 203
Status: offline
Here's what I did... Tapped the aluminum block. The ears are about 2mm thick so there are enough threads to hold things together. The 4-40 flat heads make for a neat install. Also some JB-weld will hold things together long term
Click for fullsize
Click for fullsize
Click for fullsize
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 35
RE: Let's gasify a Vanquish - 10/28/2012 2:56 AM
MTK
Score: 203
Status: offline
The model is unbelievably light.....I musta missed something.... Just 10 # rtf, with an XOAR 19x10 laminated woodie. Very nice
If this model was converted to an OS140RX, it would weigh 9 1/2 lbs...very sporty. Except the 140RX can't haul big props
BTW  Shaved 35 grams from the landing gear and decided to build a mold for the modified landing gear. I prefer a lighter, springier gear that absorbs the energy rather than transfering it to the frame. Strength is fine
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 36
RE: Let's gasify a Vanquish - 10/28/2012 4:21 AM
cmoulder
Score: 106
Status: offline
Wow, excellent weight at this point!
I know you hate plastic, but do you still plan to re-cover?
Bob
Hide Signatures
(in reply to MTK)
       Post #: 37
RE: Let's gasify a Vanquish - 10/28/2012 5:21 AM
dave pattern
Score: 100
Last Login: 2/25/2013
Status: offline
 Just thought i would add, that my Dad bought a pte36 and today i test flew it for him in a 80+ inch arf pt 19.
it acts like it was pre run by the factory or redwing before he got it. it started right up and idled perfectly and ran very strong at full throttle. we didnt even adjust the needles, i didn't think we could have made it better it ran so well.
no ground running besides the first start and run of a couple of minutes and then we refueled it and flew it.
the pt had unlimited vertical at full throttle but looked more like a big yellow P51 speed wise (i'm surprised we didn't blow the pilots out of the open cocpits). it flew better at less than half throttle (a little more scale at that speed) i think he had a zoar 19-8 on it.and it pulled that easy.
instant throttle response from idle and instant response from half throttle.
it is clearly the best gas engine i have run recently.
i might be putting one in place of my ys170 soon
Dave.
Hide Signatures
(in reply to cmoulder)
       Post #: 38
RE: Let's gasify a Vanquish - 10/28/2012 4:25 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: cmoulder
Bob,
Yeah, at some point I think I'll do that. First I want to see how it flies and what else I need to change when I peel the plastic off.
One thing I see right off is the leading edge of the wing...just too blunt for my taste. And wing adjusters....
One thing at a time. Heck it may not live long enough if the radio goes south
Regards,
MattK
Hide Signatures
       Post #: 39
RE: Let's gasify a Vanquish - 10/31/2012 12:06 PM
rm
Score: 100
Last Login: 5/21/2013
Status: offline
Does this plane still have the chin cowl? or is it a 1 piece cowl now?
Hide Signatures
(in reply to MTK)
       Post #: 40
RE: Let's gasify a Vanquish - 10/31/2012 1:08 PM
cmoulder
Score: 106
Status: offline
If I recall correctly, the e-version has always had a 1-piece cowl, as shown in Matt's photos on the first page.
Maybe the g-version prototypes had chin cowls but they never made it past prototype...
Bob
Hide Signatures
(in reply to rm)
       Post #: 41
RE: Let's gasify a Vanquish - 10/31/2012 1:30 PM
danamania
Score: 105
Status: offline
Hi Bob, how are you? Hope Matt and the other NJ pattern guys made it through Sandy ok, Matt? No AC where I live but no property damage either, a blessing.  Did fly the Vanquish back to back with the Nuance last week, very different feel and I am thinking of selling the Vanquish now.  Both are very nice models, just different enough to drive me nuts! Anyway, hope all and their birds are well. Keep the faith.
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 42
RE: Let's gasify a Vanquish - 11/1/2012 3:53 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: rm
No chin cowl in the current version
Actually the current cowling is not a problem in any way. The whole engine fits inside and the mounting bolts are easily accessed from the various holes up front. In fact it may be a bit easier to fit better baffles in a one piece cowling and then slide the whole thing in place from the front. In addition, once the cowling is removed, it fully exposes the engine and mount and provides access to a front mounted CDI for example. To me, it's simpler
Dana,
W/o power, phone and internet as of Thursday. Minor damage to home and property.
This is the second hurricane to affect us here in the NE in as many years. We've had blizzards, hurricanes and earthquakes here in Joisey in the 7+ years since my return.
Having lived in Florida for 20 years and Texas for 10 prior to returning to Joisey, we experienced only one hurricane in those 30 years combined. I think Joisey is toast!!
Regards,
MattK
Hide Signatures
(in reply to rm)
       Post #: 43
RE: Let's gasify a Vanquish - 11/1/2012 4:07 PM
rcpattern
Score: 100
Status: offline
quote:
ORIGINAL: cmoulder
Bob,
The electric version that the thread was started on had a chin cowl. They changed it on later shipments.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
       Post #: 44
RE: Let's gasify a Vanquish - 11/1/2012 5:02 PM
JRgraham
Score: 105
Status: online
Good stuff, MTK!  Subscribed!
Glad to hear you made it through the storm okay!
JR Graham
D8, AMA 201522
Hide Signatures
(in reply to rcpattern)
       Post #: 45
RE: Let's gasify a Vanquish - 11/2/2012 1:33 PM
cmoulder
Score: 106
Status: offline
quote:
ORIGINAL: danamania
Dana, zero problems here. Lights flickered a couple of times and that's it. But not far away lots of electric outages and trees down. Trains were finally running yesterday so wife could get to work, which is the most important thing!
Yes, those are definitely different models!
Very interested to see how Matt's gassified version works.
Bob
Hide Signatures
(in reply to danamania)
       Post #: 46
RE: Let's gasify a Vanquish - 11/2/2012 1:35 PM
cmoulder
Score: 106
Status: offline
Arch
Another glow-motor artifact bites the dust.
Thanks for the correction. I should have referred to the photos I have of the model in your original thread.
Bob
Hide Signatures
       Post #: 47
RE: Let's gasify a Vanquish - 11/2/2012 3:13 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: Shimano
Thank you! Dumb luck in reality. Some of our neighbors fared worse. My brother who lives near me is w/o power, phone and internet too. But he's also very resourceful and just happens to work for the Board of Education.....That has turned out to be a blessing!
Some parts of our neighborhood had power restored this morn. We hope that today is the day for us too....
The gas lines are an unwanted trip down memory lane back to 1973. Smart marketeers should sell 10 gallons gas along with those generators. I would do that anyway, but I'm not in that business.
Regards,
MattK
Hide Signatures
(in reply to JRgraham)
       Post #: 48
RE: Let's gasify a Vanquish - 11/2/2012 3:21 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: cmoulder
Bob,
I guess that some e-fuses allow nose access only from the front? That would be a better, stronger and lighter arrangement for an e-fuse. Also, a firewall (if you can call it that) wouldn't need much beef to work properly if it was glued as a ring around the whole nose. Makes good engineering sense to me
Regards,
MattK
Hide Signatures
       Post #: 49
RE: Let's gasify a Vanquish - 11/5/2012 4:37 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: cmoulder
Bob and all,
It is just about completed. I will maiden it this coming weekend if weather holds up. I'll try to take some snaps of it at the field and I'll give a flight report in these pages.
Regards,
MattK
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
