expired date turbine oil    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> expired date turbine oil
Page: [1]
Login
expired date turbine oil - 10/8/2012 1:38 PM
tiporare
Score: 100
Last Login: 4/12/2013
Status: offline
hi every one
i have a few cans of expired date turbine oil .
can i use them?
i talked to friend of mine which is aviation engineer and he told me thet i can use it
with no problem
i will be glad to hear more opinions
thanks
Hide Signatures
       Post #: 1
RE: expired date turbine oil - 10/8/2012 1:52 PM
FlyinTiger
Score: 105
Last Login: 5/20/2013
Status: offline
I'm curious to know (as a new RC turbine pilot) what experies in the turbine oil? Is there a "best if sold by" date on the side of the container you have?
_____________________________
Albert Hibpshman
Hide Signatures
(in reply to tiporare)
       Post #: 2
RE: expired date turbine oil - 10/8/2012 1:56 PM
madmodelman
Score: 110
Last Login: 5/22/2013
Status: offline
No problem to use, the oil has several additives for full size use which deteriorate over time hence the sell by date.
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
       Post #: 3
RE: expired date turbine oil - 10/8/2012 2:06 PM
ticketec
Score: 105
Status: offline
All products used in full sized aviation must have a shelf life or expiration date on them. There is no "best before". This date, is the amount of time after manufacture or packaging, that the OEM guaranties that their product will still meet the required specification. I.e, if the shelf life of a paint is 4 years, then 4 years after the date of manufacture, if you were to apply that paint product, it would have the correct viscosity, soild content, coverage, etc during application, and then it would take the same amount of time to flash off, cure, and finally if would have the same final finish qualities as per the minimum required by the specification that it was sold as meeting or exceeding.
In full sized RPT (regular public transport, millitary, etc ) we discard many products because they have reached their shelf life. (General aviation are a little less concerned at times) The product can be perfectly ok, but must be discarded. I discarded over $5000 worth of paint products after an audit 2 weeks ago for this very reason. would I use it for my models? Damn straight I would not hesitate (just mixed a batch of fuel last week with time ex oil) to use the oil in for my models as long as there is no signs of rust on the tin and there are no contaminates as you pour it out.
dave
Hide Signatures
(in reply to FlyinTiger)
       Post #: 4
RE: expired date turbine oil - 10/8/2012 4:58 PM
Harley Condra
Score: 105
Status: offline
Please send all of your expired turbine oil to me, and I will be pleased to dispose of it for you, saving you both time and the expense of legal disposal methods.
Harley Condra
BVM REP, Skymaster REP, JetCat REP
Hide Signatures
(in reply to ticketec)
       Post #: 5
RE: expired date turbine oil - 10/8/2012 7:04 PM
Dave Wilshere
Score: 108
Status: offline
How many years was it in the ground?
Dw
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to Harley Condra)
       Post #: 6
RE: expired date turbine oil - 10/8/2012 9:25 PM
jetmodeller
Score: 100
Status: offline
Hi i have been using turbine oil that was canned 20years ago for two years now no problems what so ever regards Keith
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 7
RE: expired date turbine oil - 10/8/2012 9:45 PM
madmodelman
Score: 110
Status: offline
Glad you said that Keith, I've got a ton of 2010 vintage
Hide Signatures
(in reply to jetmodeller)
       Post #: 8
RE: expired date turbine oil - 10/8/2012 10:45 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: FlyinTiger
I'm curious to know (as a new RC turbine pilot) what experies in the turbine oil? Is there a ''best if sold by'' date on the side of the container you have?
Nothing other than the FAA.
For "real" or "Full Scale" aircraft... they set dates on the oil. But, in reality, the oil is fine, if the can was never opened. It's kind of like putting an expiration on a twinkie. It's just a precaution, and to put a limit on the manufactures liability.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 9
RE: expired date turbine oil - 10/9/2012 12:42 AM
josecilurzo
Score: 100
Status: offline
for me too!!!
Jose
Hide Signatures
       Post #: 10
RE: expired date turbine oil - 10/9/2012 9:29 AM
ticketec
Score: 105
Status: offline
quote:
ORIGINAL: Harley Condra
Love to mate, but all the local Jet boys have a standing offer to the same effect I hooked them up with just over a ton of Jet A1 last time. Maybe you'll have to move to sunny Queensland for some of the free stuff
dave
Hide Signatures
       Post #: 11
RE: expired date turbine oil - 10/9/2012 6:02 PM
GrayUK
Score: 102
Last Login: 5/21/2013
Status: offline
No problem, you can use it, been doing it for years.
Paul G
no one told you when to run...
Hide Signatures
       Post #: 12
RE: expired date turbine oil - 10/11/2012 4:41 AM
Wayne22
Score: 105
Status: offline
If you think about it, we only use the oil once. most of it goes through the combustion chamber and is burnt..the tiny remainder goes through the bearings once, and then is burnt in the exhaust..
Full scale, it is circulated, pumped, filtered, heated, cooled, piped over and over until the next oil change....
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
(in reply to GrayUK)
       Post #: 13
RE: expired date turbine oil - 10/11/2012 4:55 AM
cactusflyer
Score: 110
Last Login: 4/5/2013
Status: offline
quote:
ORIGINAL: Wayne22
Great point.....and in full scale the turbine oil is not changed! It is replaced at the overhaul after thousands of hours of use.
Tailwinds,
John
Proud to be a rookie!
Hide Signatures
(in reply to Wayne22)
       Post #: 14
RE: expired date turbine oil - 10/11/2012 5:50 PM
SJN
Score: 105
Status: offline
quote:
ORIGINAL: cactusflyer
quote:
ORIGINAL: Wayne22
Tailwinds,
John
Well, our 737-700`s with CFM`56`s use about 4 quarts every 48 hours , so it sort of replaces the oil regualry by itself
Sonnich Johannesen
Hide Signatures
(in reply to cactusflyer)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
