M51 Sherman Cast Upper Hull    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> M51 Sherman Cast Upper Hull
Page: [1]
Login
M51 Sherman Cast Upper Hull - 10/8/2012 2:01 PM
hemi
Score: 100
Last Login: 5/16/2013
Status: offline
I'm gather parts to build my Tamiya M51. I'm looking for a cast upper hull to use to replace the welded version that comes with the kit. I already have all of the Schumo resin parts.
Thanks for any leads.
_____________________________
John
Hide Signatures
       Post #: 1
RE: M51 Sherman Cast Upper Hull - 10/8/2012 2:35 PM
pattoncommander
Score: 132
Last Login: 5/19/2013
Status: offline
I used a Mato upper....works fine...have it lockled on like a Tammy. .
Click to see fullsize image.
Click for fullsize
HL M-26, M-46, M-41B, T-34/85, IDF M-51 (2)
Hide Signatures
(in reply to hemi)
       Post #: 2
RE: M51 Sherman Cast Upper Hull - 10/8/2012 2:41 PM
mcovalsk
Score: 105
Status: offline
Here you have all thje info for using the Schumo parts and make the thing. http://www.modelersite.com/PDF_Fotos_26/M51.htm
Contact to Nick Aguilar for the hull as the Mato is oversized. ndaguilar@grandecom.net
Mario Covalski
Editor Modelersite
Hide Signatures
(in reply to hemi)
       Post #: 3
RE: M51 Sherman Cast Upper Hull - 10/9/2012 9:52 PM
hemi
Score: 100
Status: offline
Mario
I purchased your PDF on the M51 build, I used that as a cross ref when I ordered the Schumo parts. Your work is fantastic.
John
Hide Signatures
(in reply to mcovalsk)
       Post #: 4
RE: M51 Sherman Cast Upper Hull - 10/9/2012 9:55 PM
hemi
Score: 100
Status: offline
PattonCommander
NIce work on your M51. Thanks for the option, I'll check it out.
John
Hide Signatures
(in reply to pattoncommander)
       Post #: 5
RE: M51 Sherman Cast Upper Hull - 10/10/2012 12:39 AM
Panther G
Score: 116
Status: offline
Yes , very nice Mario. i have a subscription to your magazine so I have seen many examples of your work.
Tamiya Panther G, HL/Tamiya TigerI, WSN/HL T-34/85, WSN/Tamiya T-34/85, WSN/HL DBCRC2 T-34/85, HL/Tamiya Pershing, Mato/Tamiya Sherman,HL KV-1, HL Pz III, HL/Custom scratch JP, HE/Tamiya Abrams, HE/Tamiya LEO 2A5, Vs Abrams M1A1, Vs T-72, HL Bergepanthe
Hide Signatures
(in reply to hemi)
       Post #: 6
RE: M51 Sherman Cast Upper Hull - 10/10/2012 2:21 AM
edoubleaz
Score: 233
Status: offline
MATO Works. Nick's is good and comes with posts for the Tamiya traverse.
Untitled by edoubleaz, on Flickr
check out www.desertarmor.com for all our work.
Hide Signatures
(in reply to Panther G)
       Post #: 7
RE: M51 Sherman Cast Upper Hull - 10/10/2012 4:20 PM
mcovalsk
Score: 105
Status: offline
Hi John
Thanks for your support!
I strongly recommend the hull from Nick, is not easy to work with but you will get an accurate reproduction in the end. Anyway I have a Mato hull if you need something cheap, but I recommend the Nick's one.
With the one from Nick you will have some work as I explain in the article, by the other hand the Mato's is easy to work with but I was not happy with the dimensions, didn't look like the M51 after placed in the hull, but is an option if you don't like resin parts.
Please if you need some advice regarding my article, don’t hesitate ask me, and have in account that I used photoetched holders for the canisters from Archer ( also from Axel modelbaun ) instead the scratch ones I made for the M51, as I show in the M50 article http://www.modelersite.com/PDF_Fotos_27/M50Sherman.htm
Mario Covalski
Editor Modelersite
Hide Signatures
(in reply to hemi)
       Post #: 8
RE: M51 Sherman Cast Upper Hull - 10/10/2012 4:24 PM
mcovalsk
Score: 105
Status: offline
Yes you are right Mato works, and yours looks fantastic, a great piece of modelling. However if you want to perspire for a while the Nick's will look better in the end. It also saved me to make oll the cats texture. BUT modelling have many ways to do things and yous worked terrific too.
Mario Covalski
Editor Modelersite
Hide Signatures
(in reply to edoubleaz)
       Post #: 9
RE: M51 Sherman Cast Upper Hull - 10/10/2012 5:17 PM
Panther F
Score: 135
Status: offline
My A1E8 was built using Nicks hull and turret.
Never regretted it either.
~ Jeff
Hide Signatures
       Post #: 10
RE: M51 Sherman Cast Upper Hull - 10/10/2012 9:52 PM
AFV432
Score: 100
Last Login: 5/18/2013
Status: offline
We have a couple of M1's on the go take a look here http://www.rctankregiment.com/rctankforum/viewtopic.php?f=9&t=3972
nigel also built his M51's using a mato upper http://www.rctankregiment.com/rctankforum/viewtopic.php?f=9&t=2531
most of the traverse and elevation uses H/long as the Tammy stuff isnt great
Hide Signatures
(in reply to Panther F)
       Post #: 11
RE: M51 Sherman Cast Upper Hull - 10/10/2012 10:24 PM
mcovalsk
Score: 105
Status: offline
You guys do a great job, unfortunately I tried several times to register in your forum to share my work and always I was rejected..... rare at leats.
Mario Covalski
Editor Modelersite
Hide Signatures
(in reply to AFV432)
       Post #: 12
RE: M51 Sherman Cast Upper Hull - 10/19/2012 1:44 AM
hemi
Score: 100
Status: offline
Very nice work. I'll contact Nick for a resin top. I'm just starting to add detail to my T34 build. I used a wsn lower hull and added everything else from a trumpeter T34-85 static kit. Tamiya electronics for a KV1. It's fully functional now so on to detailing and finish. I want to start building my M51. Hmmmmm maybe do both at the same time. The work you guys do is inspirational. I appreciate the help
John
John
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
