nitro blizzard    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Blizzard EV
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> nitro blizzard
    Page: [1]
    Login
    nitro blizzard - 10/8/2012 11:00 PM
    racingfan48
    Score: 100
    Last Login: 4/17/2013
    Status: offline
     I got a question for anyone with experience with the nitro kyosho blizzard.  I cant seem to get the throttle to return back to full neutral so in the process the idle hangs high and sheers the pins inside the transmission.  At first when i put it together i had the control arm for the transmission too short but it worked ok, then I fixed the length of it and now i have this idle issue.. Any ideas on if its the other arms maybe or is it that little throttle setup they have with the rubber band wrapped around it... Any suggestions?
    Thanks alot!!!
    Hide Signatures
           Post #: 1
    RE: nitro blizzard - 10/10/2012 7:10 AM
    racingfan48
    Score: 100
    Status: offline
    Fixed the problem for the most part, ended up using an exhaust spring and putting it on an open eye loop on throttle link and it pulls shut now
    Hide Signatures
    (in reply to racingfan48)
           Post #: 2
    RE: nitro blizzard - 10/14/2012 8:08 PM
    Paul1981
    Score: 100
    Last Login: 3/28/2013
    Status: offline
    I had similar problems with mine; I solved it by ditching the mechanism and having a 3rd servo to seperate the forward/reverse changing duties from the throttle.  Pictures on page 71 of the other Blizzard thread...
    http://www.rcuniverse.com/forum/m_6690636/mpage_71/key_/tm.htm
    Hide Signatures
           Post #: 3
    RE: nitro blizzard - 10/15/2012 12:59 AM
    racingfan48
    Score: 100
    Status: offline
    Hey thanks alot I did that instead and works even better now. Just routed the transmission servo to the landing gear port on receiver and makes it easier to know it's not going to strip the pins out haha. Thanks alot for the help!!
    Hide Signatures
    (in reply to Paul1981)
           Post #: 4
    RE: nitro blizzard - 10/15/2012 6:10 AM
    Lorduss
    Score: 100
    Last Login: 10/30/2012
    Status: offline
    the blizzard is alot of fun but as a nitro it drove me crazy, i bought the tranny and chassie plate and converted mine to electric with a crawler setup.
    i still love it but it has other flaws, mostly having to do with my wet snow
    _____________________________
    Function over fashion, I dont do shelf queens!
    Hide Signatures
           Post #: 5
    RE: nitro blizzard - 10/21/2012 12:21 AM
    Paul1981
    Score: 100
    Status: offline
    Not a problem.  You may find that it might not engage properly occasionally (very rare though), but at least it doesn't strip any of the pins by trying to engage at high revs.
    Hide Signatures
           Post #: 6
    RE: nitro blizzard - 10/21/2012 12:33 AM
    racingfan48
    Score: 100
    Status: offline
    Yea, it's a blast now that it works right. Just waiting on snow. I've been designing a fully functional snow blade for it so it should be interesting!
    Hide Signatures
           Post #: 7
    RE: nitro blizzard - 10/24/2012 6:56 AM
    racingfan48
    Score: 100
    Status: offline
    http://www.rcuniverse.com/gallery/galleryItem.cfm?itemID=235064&dummy=9729.622448794544&opener=/community/profile.cfm%3Fsection%3Dgallery%26memid%3D583512
    Here's the snow blade so far
    Hide Signatures
           Post #: 8
    Page:   [1]
    Page: [1]
    Blizzard EV
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.984RCU1
