dle 20 cc muffler extention    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> dle 20 cc muffler extention
Page: [1]
Login
dle 20 cc muffler extention - 10/9/2012 2:07 PM
michael wood
Score: 120
Last Login: 5/21/2013
Status: offline
Hi everyone Iam building a tiger moth 120 and using A dle 20cc engine my problem is the muffler exaust tube is to short to go thur the cowling by about 2 inches is there away to add a piece of hose on the exaust pipe the wont melt are should I just cut a large hole in the cowl and hope the exaust goes thru what would you all do( also no room for a wrap around muffler do to where the ignition box is located on the fire wall) michael
Hide Signatures
       Post #: 1
RE: dle 20 cc muffler extention - 10/9/2012 2:15 PM
ahicks
Score: 669
Status: offline
1/2" female copper pipe fittings are a really nice slip fit on that outlet if that's any help. -Al
Hide Signatures
(in reply to michael wood)
       Post #: 2
RE: dle 20 cc muffler extention - 10/9/2012 3:41 PM
raptureboy
Score: 178
Last Login: 5/20/2013
Status: online
I use heater hose from the auto store with a hose clamp. Could also use the silicone types for glow engines.
< Message edited by raptureboy -- 10/16/2012 4:02 PM >
_____________________________
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to ahicks)
       Post #: 3
RE: dle 20 cc muffler extention - 10/9/2012 5:00 PM
MTK
Score: 203
Status: online
Mc Master Carr carries silicone and teflon tubing that will work fine. Suggest you drill and tap the exhaust stinger at the end for 4-40 button head screws. Put a couple 1/8" button heads on it and then slide the tube over them and secure with a tie wrap
Regards,
MattK
Hide Signatures
       Post #: 4
RE: dle 20 cc muffler extention - 10/9/2012 5:16 PM
michael wood
Score: 120
Status: offline
how do you hold the copper pipe on
Hide Signatures
(in reply to MTK)
       Post #: 5
RE: dle 20 cc muffler extention - 10/10/2012 3:47 AM
ahicks
Score: 669
Status: offline
I use a thin coat of the same silicone I use to seal the muffler to the exhaust port and a couple of small sheet metal screws installed 180 degrees apart. It's never come off or loosened to date!
Hide Signatures
       Post #: 6
RE: dle 20 cc muffler extention - 10/10/2012 4:50 AM
Ernie Misner
Score: 130
Status: offline
That must be red or black high temp silicone rubber.
Hide Signatures
       Post #: 7
RE: dle 20 cc muffler extention - 10/10/2012 5:48 AM
michael wood
Score: 120
Status: offline
guess ill try the copper tubing and see how that works out michael
Hide Signatures
(in reply to Ernie Misner)
       Post #: 8
RE: dle 20 cc muffler extention - 10/15/2012 9:57 PM
gofast53
Score: 100
Last Login: 11/16/2012
Status: offline
I tried using high temp silicon hose but the gas exhaust fumes kept eatting into the silicon and splitting it. I now use a rubber radiator hose from the auto parts store. It already had a couple of 45 degree bends in it and is a snug firt on the end of the stinger with a plastic tie for good measure. I am running a DLE20 with the noisey stock canister muffler, but the hose extension has quietened it down alot.
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> dle 20 cc muffler extention
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
