Picco 45 DF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> Picco 45 DF
Page: [1]
Login
Picco 45 DF - 10/9/2012 6:04 PM
bpbrinson
Score: 100
Last Login: 6/18/2013
Status: offline
Just to let you guys know..... http://www.ebay.com/itm/290787814256?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Picco 45 DF - 10/9/2012 10:04 PM
airraptor
Score: 131
Last Login: 6/20/2013
Status: offline
looks well used.
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to bpbrinson)
       Post #: 2
RE: Picco 45 DF - 10/9/2012 11:01 PM
combatpigg
Score: 381
Status: online
quote:
ORIGINAL: airraptor
looks well used.
That's why it's difficult for a lot of guys to sell their used engines with a clear conscience.
Unless the price is really low or if the engine's internals has passed a real close and through inspection by the owner. Thankfully the market still has a lot of neat old engines that never got used.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to airraptor)
       Post #: 3
RE: Picco 45 DF - 10/9/2012 11:22 PM
bpbrinson
Score: 100
Status: offline
15 years in an attic in southeast Texas, you would look well used also. I can assure you it has not even had a glow plug screwed in. Minor aluminum oxidation causing minimum outer discoloration. Inside still had oil it was packed with. That is why I said never ran, did not say new. It was new when I bought it with 2 others in about 1988. Box lost but have book.
Brooks
Hide Signatures
(in reply to combatpigg)
       Post #: 4
airraptor
Score: 131
Status: offline
yes i know. when i sell new or used engines i will take a pic of the exhaust, to see the piston and as many pics as feasable. i was mainly looking at the front of the pipes where they look like they were rubbing/banging against the engine. I havent looked at the Ebay add yet though. I wonder how the Picco compairs to the OS or K&B DF engines in this size.
AMA # 186123
Hide Signatures
       Post #: 5
RE: Picco 45 DF - 10/9/2012 11:24 PM
bpbrinson
Score: 100
Status: offline
Pipes are very well used, one crashed but usable. I did have 2 other Picco's. Been flying fast a long time. Just because you guys dont see someone post does not mean every one else flies slow....
Brooks
Hide Signatures
       Post #: 6
RE: Picco 45 DF - 10/10/2012 12:11 AM
MJD
Score: 125
Last Login: 6/19/2013
Status: offline
RVman had one in his Screamin Demon, I recall it moved along "real good" but I can't quantify the engine beyond that. It was the first rear exhaust Demon I ever launched, I remember the pipe blasting at my face and my eyes watering from the rich exhaust nitro fumes..
I try to be pessimistic, but why bother?
Hide Signatures
       Post #: 7
RE: Picco 45 DF - 10/10/2012 12:25 AM
bpbrinson
Score: 100
Status: offline
quote:
ORIGINAL: airraptor
I have ran the K&B (mine)and the old OS FI/RE (buddies). The Picco, comparatively is a brick, very heavy. Seems with the pumped K&B that I was only getting upper 22k and the OS was in the lower to mid 23's with 7.2x8.6. With the Picco I was getting in the low to mid 24's. The K&B was a pain to get set up with the pump but otherwise was easy to run if you did not change load to much. Wished I could tell you my pipe measurement. And it looks like the APC 7.2x8.6 is no longer made. I flew these engines on modified quickees, a Holy Smoke, several Diamond Dusts and a very thin delta that I will not say how fast it went as some here will will get nasty. Not sure I believe it myself . Picco's are beasts if allowed to rev... Besides electric is the fastest
Brooks
< Message edited by bpbrinson -- 10/10/2012 1:51 AM >
Hide Signatures
       Post #: 8
RE: Picco 45 DF - 10/10/2012 5:47 AM
airraptor
Score: 131
Status: offline
nah no one gets mad just a bunch of non believers. tell us how fast....
AMA # 186123
Hide Signatures
       Post #: 9
RE: Picco 45 DF - 10/10/2012 6:15 AM
bpbrinson
Score: 100
Status: offline
Here is a pic of an average run on that day. Did get a 213 on one run. Was not too sure about that one. Wished I had a pic of the plane,I think those pics ended up at an ex's house. It was a foam core, glassed 33" delta with a 3.75% at root airfoil (9/16 thick at thickest). Everything was faired in and clean. It died a 180+ death. Bent shaft on Picco. This was about 1995. Now my fast plane is a 1.8 m 4000watt 170+ hotliner. Much easier to fly and see at my old age.
Brooks
Click for fullsize
Hide Signatures
       Post #: 10
RE: Picco 45 DF - 10/10/2012 6:55 AM
combatpigg
Score: 381
Status: online
Nice work!
The 7.2 x 8.6.......
I loved this prop and ran it on my 1st Nelson FAI .40...but it was a slight overload for the .40 right out of the bag. It ran so hot that the silicone pipe seals melted every run.
Hide Signatures
       Post #: 11
RE: Picco 45 DF - 10/10/2012 7:48 AM
bpbrinson
Score: 100
Status: offline
Yes, I had to cut cooling holes in my fairing work or otherwise cook under the faired area. I blew silicone often. I did cut down that prop to at or just under 7 inches. Some one posted a while back that a 45 could not do 200. I disagree, obviously, did it often. But physics will not allow much more with the high rev props. The helical tip speed of a 7 inch prop looses so much efficiency due to getting close to trans sonic speeds. A 7 inch prop at 25000 and 200 MPH is getting very close to mach .85 or more. Getting very close to limits and efficiency is taking a dive. Only way to lower tip speeds is to go with a smaller prop. Some electric guys are turning =/- 5 inch props near 50,000 and going 225 or so with small very clean F5D airplanes. The newest movement I am watching is the geared 10x23 folders that tip speeds are still around mach .5 and have great thrust. Lots of F5D guys are playing with those setups. The F5S guys are using 25 inch pitch with larger props to go 260+. Many are pushing close to 10KW to do that. Thats 13 hp!!!!! My hotliner is 4000 watts+ in and about 3300 watts (4.4hp) to prop with a 18x21. Tip speeds are still under Mach .65. It can accelerate from launch to 150+ in about 3 seconds flat. I am limited to 3-5 second bursts of power or let the majic smoke out. It is also much easier to make and electric aerodynamic than a slimer. Don't get me wrong, slimers are fun and fast, but if you want to go REAL fast electric is starting to be the way to go.
Sorry, got long winded
Brooks
Hide Signatures
       Post #: 12
RE: Picco 45 DF - 10/10/2012 9:01 AM
Petrovsky
Score: 100
Last Login: 6/17/2013
Status: offline
No international buyers
Tracto Allergicus
Hide Signatures
       Post #: 13
RE: Picco 45 DF - 10/10/2012 6:08 PM
BiggerDanno
Score: 100
Last Login: 5/21/2013
Status: offline
I have one of these new waiting for me to build my Screaming Demon.
Need a header, anyone make one or have a spare?
Hide Signatures
(in reply to Petrovsky)
       Post #: 14
RE: Picco 45 DF - 10/11/2012 1:30 AM
combatpigg
Score: 381
Status: online
quote:
ORIGINAL: bpbrinson
Brooks
Electric motors have no soul.
Engines "come to life".
When Jim Green fired up one of his 427 Ford "Cammers" at a local Cacklefest ...just to let the crowd hear it run, it brought a tear to my eyes.
I just can't picture myself ever getting a little emotional if some guy flipped a switch on a 2500 HP electric motor.
Hide Signatures
       Post #: 15
RE: Picco 45 DF - 10/11/2012 1:41 AM
lfinney
Score: 105
Status: online
i just received my headers from Mac's products, and it was for a 3+2 long stroke rossi, they either have or will make headers for the rear exhaust piccos, they have the side exhaust picco headers in stock, i dropped by last time i was in sac and bought some for my picco's...
Hide Signatures
       Post #: 16
RE: Picco 45 DF - 10/11/2012 3:37 AM
MJD
Score: 125
Status: offline
quote:
ORIGINAL: bpbrinson
Brooks
I would say this is approaching the limit for a normally aspirated .40 c.i. glow engine in a model controlled via human eyesight: MB .40 powered speed model
The prop diameter associated with raising the rpm further to gain hp, in combination with the frontal area constraints probably mean diminishing returns are lurking around the corner. And keeping the engine together I guess.
Hide Signatures
       Post #: 17
RE: Picco 45 DF - 10/11/2012 4:42 AM
airraptor
Score: 131
Status: offline
Yes the electric stuff is super easy to hit 240 plus. They are running low 52s on the pylon course now. I think they are on 7x14 props around 22,000. I love to see those hot liners fly launch to 150 mph straight up. I love gas/glow stuff also. I have a little profi 21 I need to put on something.....
AMA # 186123
Hide Signatures
(in reply to MJD)
       Post #: 18
RE: Picco 45 DF - 10/11/2012 7:29 AM
combatpigg
Score: 381
Status: online
My Nelson 40 hits 30,000 in the air with a 6.75" x 7 prop. I don't recall trying less diameter than that...since the hand launches were pretty wimpy for the first 20 feet after leaving my hand. IIRC the launch rpm has to be no higher than 22,000 on that prop because of no inflight mixture control. So, 3 pounds of thrust to launch a 4 pound model.
Hide Signatures
       Post #: 19
RE: Picco 45 DF - 10/13/2012 5:48 AM
combatpigg
Score: 381
Status: online
Let's see some threads about engines like this Picco .45 submitted here by true hotrodders.
Hide Signatures
       Post #: 20
RE: Picco 45 DF - 10/16/2012 10:23 PM
lfinney
Score: 105
Status: online
the two pipes in the pics with the .45 picco , one is a picco part fine for lower nitro or none..and has much less volume, the other pipe is a macs marine pipe with double cone angles and is used with 15-65 percent nitro fuels..the double angle on the front cone really wakes the pipe effect up, during initial testing the boaters were shocked at the transition and better top end.
Hide Signatures
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
