Cheap NGK CM-6 plugs    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Cheap NGK CM-6 plugs
Page: [1]
Login
Cheap NGK CM-6 plugs - 10/9/2012 9:10 PM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
How much are you guys paying for the NGK CM-6 plugs? This looks cheap compared to what I've seen....
http://www.quickieparts.com/spark-plugs/ngk-cm-6-cm6-5812-395-ngk-spark-plug-for-da-engines-3w-engines.html
Hide Signatures
       Post #: 1
RE: Cheap NGK CM-6 plugs - 10/9/2012 9:39 PM
pe reivers
Score: 646
Last Login: 6/18/2013
Status: offline
Add shipping, then how much do you plan to save on a yearly basis?
IMHO, spark plug cost is an extremely minor part of the total hobby cost. Driving the car 100yds extra each day is more expensive.
_____________________________
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 2
RE: Cheap NGK CM-6 plugs - 10/9/2012 9:40 PM
DaleD
Score: 105
Last Login: 6/19/2013
Status: offline
 Attractive price indeed! Shipping cost seem a bit high unless you are buyi large quantities for retail sale.
DaleD
Hide Signatures
       Post #: 3
RE: Cheap NGK CM-6 plugs - 10/9/2012 9:43 PM
STUKA BARRY
Score: 130
Status: offline
O'Reiley Auto parts= $3.65 ea. they might have to order them if the plugs are'nt instock, but it only takes one day
KEEP UM FLYIN
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: Cheap NGK CM-6 plugs - 10/9/2012 11:12 PM
fredscz
Score: 102
Status: offline
I just bought some from Auto-Zone and 2 plugs were less than $6.00 total including tax.
Fred
Life''''s tough......It''''s even tougher if your stupid!! " J. Wayne
Hide Signatures
(in reply to STUKA BARRY)
       Post #: 5
RE: Cheap NGK CM-6 plugs - 10/10/2012 12:12 AM
Ernie Misner
Score: 130
Status: offline
O'riley's or Auto Zone sounds good guys, thanks loads. Okay, so the NGK CM-6 is much better than say the stock DLE plug. Isn't there something like a platinum plug or whatever that's a step up from the NGK? Just curious, even if there is the NGK might be the best compromise for the buck.
Hide Signatures
(in reply to fredscz)
       Post #: 6
RE: Cheap NGK CM-6 plugs - 10/10/2012 3:37 AM
ahicks
Score: 669
Status: offline
Man, you love opening can's of worms don't you?
Iridium plugs are what you're thinking of I think. You can get them in a CM-6 type plug, they're made by NGK, and they're about twice as much money. Because of that, many buy them thinking they'll get more performance on top end. When they don't, they claim the plugs are junk, a waste of money.
What they should have been looking at was the difference in low rpm performance. The plugs run more cleanly in richer conditions than the CM-6 will. That's it.... To some though, that feature is worth every extra penny that plug costs......
-Al
Hide Signatures
       Post #: 7
RE: Cheap NGK CM-6 plugs - 10/10/2012 4:58 AM
Ernie Misner
Score: 130
Status: offline
The iridium plugs might be the way to go then if you're having a fouling problem during break in, uncurable rich spot, or any plug fouling scenerio that's driving you.
Back in the '60's we'd spring for the platinum Lodge plugs out of necessity when running Castrol R (think plug fouling nightmare) when they had to start before a race. That was in racing two strokes like the Bultaco Pursang motorcycle.
If anyone can find and post a spark plug conversion chart showing the different brands of NGK CM-6 type plugs, please do.
Thanks, Ernie
Hide Signatures
(in reply to ahicks)
       Post #: 8
RE: Cheap NGK CM-6 plugs - 10/10/2012 1:39 PM
ahicks
Score: 669
Status: offline
Trying to minimize any false hopes, I like these plugs, but I'm shy of going so far as saying they'll help prevent fouling? Fouled to me is when the plug simply won't fire? Iridiums will darn sure foul if you flood the engine! Not more forgiving there either. Saying they're more about being more forgiving of a rich mixture is the best way I can think of to describe them. Where the standard plug leaves the engine running lumpy, missing, hesitating, etc. due to the rich mixture, the iridium works to smooth some of that out.
I still think most guys will be happier with the CM-6/standard plug. Iridiums are more of a specialized thing for guys that might be described as a "tuner"? Those looking for (and able to recognize?) that last little bit of available performance? Just don't look for it over about 2500-3000 rpm. with this plug, I doubt you'll find anything there. That's my take on them anyway.... FWIW, -Al
Hide Signatures
       Post #: 9
RE: Cheap NGK CM-6 plugs - 10/11/2012 1:29 AM
acerc
Score: 221
Status: offline
I don't understand this mentality over spark plug's. I pay $4 for a NGK-CM6, an OS # 8 glowplug is $8 and the four stroke plug is $10. The sparkplug will out last the glow plug ten fold at least. There are many of us who has engine's with gallon's thru them and numerous years with the first plug we installed. I don't ever recall any one , or thread,  with such concern's over the glowplug. All in all the NGK is very cheap. One can achieve much more or less performance by the grade of fuel, grade of oil, timing, and the tune. But the spark plug? At $4 buck's?
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 10
RE: Cheap NGK CM-6 plugs - 10/11/2012 4:35 AM
w8ye
Score: 318
Status: online
You guys have not talked about the CM-6 size iridium plugs offered by RCEXL yet?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to acerc)
       Post #: 11
RE: Cheap NGK CM-6 plugs - 10/11/2012 5:11 AM
Ernie Misner
Score: 130
Status: offline
http://mvvs.nl/RCexl.htm Scroll down to the ICM-6 plug.
Hide Signatures
(in reply to w8ye)
       Post #: 12
RE: Cheap NGK CM-6 plugs - 10/11/2012 2:19 PM
ahicks
Score: 669
Status: offline
That's the plug I was speaking of. I was thinking NGK made it (and all other Iridium plugs?), but could be wrong about that. -Al
Hide Signatures
       Post #: 13
RE: Cheap NGK CM-6 plugs - 10/11/2012 5:37 PM
acdii
Score: 155
Status: offline
You know the difference between the standard plug and Iridium? End point resistance!  Not the resistor that is in the body mind you, the resistance between the points of the center electrode and ground strap. Because  it has lower resistance, there is a greater area for the the spark to jump across.  This is the only thing that makes it better for a richer mixture at low end.  The spark can make the jump through heavier air/fuel mixtures because of the lower electrical resistance between the electrodes. That's it, no magic to them.  You pay more for them because the metal to make them cost more. Is it worth the price? Yeah it is when you consider what acerc said. Compare the cost of one plug that in most cases will never be replaced again, unless you really really fly it every day 365 days a year and wear the motor out, against the price of glow plugs, which in the life of a glow motor, you can go through quite a few of them before the motor wears out.
Think about it this way, the plugs in your car are rated for 100K miles, made with the same material that is in the Iridium plug.  Think you will ever put 100K miles of wear on one of these?  The only time I can see replacing the plug is when it gets broken in a crash, or you did something stupid and snapped it off.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 14
RE: Cheap NGK CM-6 plugs - 10/11/2012 6:08 PM
Ernie Misner
Score: 130
Status: offline
Where can we get the RCEXL plugs in the US if we wanted to?
Doing a cross reference search for the NGK CM-6 plug, it appears that the Champion Y82 is the same size and heat range.
< Message edited by Ernie Misner -- 10/11/2012 6:37 PM >
Hide Signatures
(in reply to acdii)
       Post #: 15
RE: Cheap NGK CM-6 plugs - 10/11/2012 9:33 PM
ahicks
Score: 669
Status: offline
Here's one source:
http://www.milehighrc.com/Ignition_Items.html
Hide Signatures
       Post #: 16
RE: Cheap NGK CM-6 plugs - 10/11/2012 10:13 PM
acerc
Score: 221
Status: offline
acdii,
If that's the case, your explanation for the iridium plug, then I will switch to them. I don't typically run to rich but will take all the help I can get. Especially at low end, you know like going into or out of a hover. And 7 buck's, plus shipping, for a plug that will last the life of the engine is very well worth it.
Robert
Hide Signatures
       Post #: 17
RE: Cheap NGK CM-6 plugs - 10/11/2012 11:13 PM
ahicks
Score: 669
Status: offline
You may like it based on your expectations! These things are made for engine guys.....
The talk regarding opening a CM-6 to .024 to ease "burbling" symptoms? See if you don't think it runs more cleanly in mid range as well. Not something easily measured, but you may notice it?
Here's something else to ponder. Many don't like to run rich because they can't. What if you could? What if this plug plain just made it easier to tune the low speed to something you can live with?
Oh, and I would order a couple of them. The freight is the same, and I don't know about you, but I generally manage to flood my engine pretty regularly. This plug won't fix that... -Al
Hide Signatures
(in reply to acerc)
       Post #: 18
RE: Cheap NGK CM-6 plugs - 10/12/2012 6:28 AM
Ernie Misner
Score: 130
Status: offline
..... won't "fix" the flooding Al, but will not foul out as soon as a standard plug. Less resistance in producing the spark. That's what I was alluding to earlier and that's what we had a bit of luck with decades ago with the then popular platinum tip plugs. A good thing all the way around. Good to see that Mile High has them and O'Reily's probably won't.
Hide Signatures
       Post #: 19
RE: Cheap NGK CM-6 plugs - 10/12/2012 2:21 PM
acerc
Score: 221
Status: offline
Ok! Now you've got me stumped. What exactly do you mean by,  You may like it based on your expectations! These things are made for engine guys.....
Robert
Hide Signatures
       Post #: 20
RE: Cheap NGK CM-6 plugs - 10/12/2012 2:36 PM
mixerfix
Score: 100
Last Login: 6/16/2013
Status: offline
Well, that depends.
In Israel (where I am located) - I am asked to pay ILS 75-85 for a spark plug. That is, about $20. And I need to drive to get it. So - if I can get it shipped for about $5-$10 to my local post office, that is a bit of a saving :-).
Not SUPER much, but still. And - the non-annoyance factor is high. Why the qp394uyrqweijhr94yb0938qhruw eijnrjwxfh should a CM6 cost $20!?!?!?!?
M
quote:
ORIGINAL: pe reivers
Hide Signatures
       Post #: 21
RE: Cheap NGK CM-6 plugs - 10/12/2012 4:11 PM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: acerc
I mean I've seen quite a few guys try this plug, and because it wouldn't produce noticeably higher rpm, turn the next bigger size prop, or because it didn't make an extra hour of daylight every day, write in and say they felt ripped off. That the plug wasn't worth the extra money?
You wrote " Especially at low end, you know like going into or out of a hover." which I believed to be a reasonable expectation, and also leads me to believe you recognize the demands on an engine while doing this? -Al
Hide Signatures
(in reply to acerc)
       Post #: 22
RE: Cheap NGK CM-6 plugs - 10/12/2012 4:17 PM
acerc
Score: 221
Status: offline
Thank's Hick's.
I don't know why when I read that it hit me like "Huh"/ "Wha". Just one of those morning's I guess.
Robert
Hide Signatures
       Post #: 23
RE: Cheap NGK CM-6 plugs - 10/12/2012 7:23 PM
Ernie Misner
Score: 130
Status: offline
mixerfix in Israel, you get an A+ for dedication and faithfulness in this fun hobby in spite of the high prices and difficulity there. You are an inspiration and an attitude adjuster for us.
Hide Signatures
(in reply to acerc)
       Post #: 24
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Cheap NGK CM-6 plugs
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
