What to look for in used 4 stroke....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> What to look for in used 4 stroke....
Page: [1]
Login
What to look for in used 4 stroke.... - 10/10/2012 7:03 AM
Warbird40
Score: 105
Last Login: 5/22/2013
Status: offline
I am being offered a 48" Ultimate Biplane with a 4 stroke and would like to know what to look for when it comes to the engine. Is there a way of knowing if the engine is good without starting it? Any tips?
Hide Signatures
       Post #: 1
RE: What to look for in used 4 stroke.... - 10/10/2012 9:50 AM
rosnik
Score: 100
Last Login: 5/23/2013
Status: offline
It's easy !
Buy one new boxed OS FS .
Get the right fuel and enjoy flying .
_____________________________
I ALWAYS THINK POSITIVE
BUT I FLY NEGATIVE.
Hide Signatures
(in reply to Warbird40)
       Post #: 2
RE: What to look for in used 4 stroke.... - 10/10/2012 10:36 AM
controlliner
Score: 100
Status: offline
See it run. There is no replacement for seeing it run at all throttle range. You can't go by compression, if the compression is weak it may be as simple as valve adjustment to fix. If you're not mechanically inclined, it may be a "pandora's box", rusted out bearings worn ring, worn valve seats.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to rosnik)
       Post #: 3
RE: What to look for in used 4 stroke.... - 10/10/2012 1:48 PM
ronwc
Score: 100
Status: online
I have had very good luck with the 1000's of used engines i've bought. Unless they have been horribly abused, most are very durable. Two strokes are a little easier, good compression and smooth bearings general mean a good engine. Four strokes turn over differently, and as mentioned earlier the valves may need adjusting and or lifters stuck from sitting - both are an easy fix. Of course, some engines are just better than others from the start.
Click to see fullsize image.
Click for fullsize
Ron - AMA 1025 - Largo, FL
Hide Signatures
(in reply to controlliner)
       Post #: 4
RE: What to look for in used 4 stroke.... - 10/10/2012 2:05 PM
Gizmo-RCU
Score: 100
Status: offline
Clean and smooth when turning over are a good start.
Gizmo
Hide Signatures
(in reply to ronwc)
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> What to look for in used 4 stroke....
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.220RCU1
