Composite insulators overview    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Airtronics Support Forum >> Composite insulators overview
Page: [1]
Login
Composite insulators overview - 10/10/2012 8:10 AM
adamconant
Last Login: 1/21/2013
Status: offline
Everyone is aware that electron movement under a magnetic flux follows Flemings left hand rule. Lot of literature is available on this. I have been exploring possibility of applying this to improve breakdown voltage in insulators. I did come across after lot of search that a paten was taken by Cheng et al Patent no 3.963,858 on 15 June 1976."High voltage electrical insulator adapted to prevent flashover".
    Around 1976 composite insulators were not available. Hence the patent speaks about embedding permanent magnets in ceramic insulators.
    Ceramic insulators are brittle and hence wall thicknesses are usually high.
    Hence the surface field strength of embedded magnets is low and hence the effect of magnetic field on deflection of electrons is also low.
    However in composite insulators, this concept can be easily applied - as it involves a process of injection molding of silicone around a fiberglass rod.
    Fiberglass discs with magnets embedded with a particular pattern / density can be made by magnet manufacturers.
    Magnet manufacturers are not composite manufacturers and composite manufacturers are shy of approaching magnet manufacturers- unless there is a strong market pressure to develop new products.
    For the same string length, break-over voltage can be increased or margin of safety could be improved.
    Is there any reason why such magnet embedded magnet composite insulators have not been developed?
Hide Signatures
       Post #: 1
RE: Composite insulators overview - 10/10/2012 1:42 PM
gsmith6879
Last Login: 5/24/2013
Status: offline
What in the world does this have to do with Airtronics? What happens when you click on the embedded link "composite insulators"?
_____________________________
Gaines
Hide Signatures
(in reply to adamconant)
       Post #: 2
RE: Composite insulators overview - 10/10/2012 2:48 PM
mschulz531
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: gsmith6879
it's a spammer...again...reported.
Gold Wing Su-26m/DLE-30, Twist 60/Saito 1.15, Airtronics 2.4 Ghz SD-10G.
Hide Signatures
(in reply to gsmith6879)
       Post #: 3
RE: Composite insulators overview - 10/12/2012 8:26 AM
adamconant
Status: offline
Hah?What is wrong with my topic here?
Hide Signatures
(in reply to mschulz531)
       Post #: 4
RE: Composite insulators overview - 10/12/2012 2:01 PM
mschulz531
Status: offline
quote:
ORIGINAL: adamconant
What does this topic have to do with Airtronics?
Reported again...and user blocked this time.
Go away.
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.434RCU1
