setting up a Webra Bully for gas    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> setting up a Webra Bully for gas
Page: [1]
Login
setting up a Webra Bully for gas - 10/10/2012 11:25 PM
pura
Score: 100
Last Login: 5/23/2013
Status: offline
Hi,
I have a NIB Webra Bully that was set up for gas. I have got it to the point of getting ready to run it but have a few questions since I am relatively new to gas and this engine.
First is the ignition system. I see that the battery lead is not a connection we use today plus the wiring order, by color is different. Not sure what to do here - cut off the lead and solder on a current plug and re-arrange the wires by color?
My engine did come with instructions but they make no mention of the gap on the Bosch spark plug.
Anything else I should be aware of before I try to start it would be appreciated. I have both a Pitts style muffler and a tuned pipe. I have[image][/image] a header as well as you can see in the photo, but I will have to find a flexible connector for the 2.
Bill
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: setting up a Webra Bully for gas - 10/11/2012 1:21 AM
All Day Dan
Score: 151
Last Login: 5/25/2013
Status: offline
pura, the black and red wires in the connector that power the ignition module are universally the negative and positive leads, respectively, for the battery. The yellow wire is probably not being used at all. Most connectors being used are the Futaba type but you can use any connector you want between the battery and the module. Don’t forget the switch that goes between the two. You certainly want to be able to connect to that so pick the connector that mates to it. Now, that being said, hopefully someone really knows. Dan.
_____________________________
Dan
Hide Signatures
(in reply to pura)
       Post #: 2
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> setting up a Webra Bully for gas
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
