Faster NiMH Chargers?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Faster NiMH Chargers?
Page: [1]
Login
Faster NiMH Chargers? - 10/11/2012 1:34 AM
Zlash03
Score: 100
Last Login: 5/23/2013
Status: offline
 I recently bought myself a drfit car but there is one downside to it. The charger. (Boy, big suprise on an RTR.) Like all RTR chargers, it takes 8 hours to charge a single 7.4v, 1800mAH battery. Quite frankly, I cant stand that and I think its stupid companies include such slow, weak chargers. Ive only owned it for 2 days and have used it a whopping...2 times. I expect that from a 1/6th scale Hummer from Toys R Us, not a big expensive hobby grade drift car! Ok, so after my rant here is what im really came here to find out:
The battery I have is a (stated above) 7.4v, 1800mAH, NiMH. Im looking for a charger that is going to charge it up somewhere around <5 hours. I only found one charger that suits my needs: http://www.rcplanet.com/Hobbico_2_Hour_AC_Wall_Charger_7_2V_Pack_p/hcap0117.htm But when I started reading up on it more, I found out it only wants to charge NiCd batteries. Does anyone know of some fast, cheap chargers that wont break the bank? I just dont want to spend that much on this battery to charge it because its the lowest powered battery that could have been given with this car. (My Mini T has a higher mAH than this thing and the Mini T battery is an NiMH too.)
Hide Signatures
       Post #: 1
RE: Faster NiMH Chargers? - 10/11/2012 4:28 AM
TheWoodCrafter
Score: 102
Last Login: 2/21/2013
Status: offline
You will need a budget quite a bit bigger than that for a decent charger.
Look lower on the page.
Hide Signatures
(in reply to Zlash03)
       Post #: 2
RE: Faster NiMH Chargers? - 10/11/2012 6:51 AM
Goldenduff
Score: 114
Last Login: 5/22/2013
Status: offline
Couldn't see what amps that charger puts out.
Do yourself a huge favour. Buy a lipo charger ( it will do all chemistries) and a 2cell lipo. Read up on how to charge and use them.
1hr charge times will be the max and you can grow with it. 6min charge times are achievable!!
Look at hobbyking
_____________________________
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to TheWoodCrafter)
       Post #: 3
RE: Faster NiMH Chargers? - 10/11/2012 7:50 PM
Zlash03
Score: 100
Status: offline
quote:
ORIGINAL: Goldenduff
Look at hobbyking
I would get a LiPo charger and battery combo but the battery would be useless to me. The reason is because the ESC can only take a 1800-3600mAH, 7.2v, NiMH pack. So based on that I can only get this battery and charger combo: http://www.rcplanet.com/DuraTrax_Onyx_2000mAh_Battery_Venom_Sport_Charger_p/dtxc2035-vnr0649.htm
Hide Signatures
(in reply to Goldenduff)
       Post #: 4
RE: Faster NiMH Chargers? - 10/11/2012 9:00 PM
trax de max
Score: 114
Status: offline
voltage is voltage, the nimh pack you have when charged is 8.4V, as is a 2s lipo. The 7.2V on the label is the nominal voltage on lipos the nominal voltage is 7.4V all these are is manufacturing descriptions about the pack.
Sorry officer i thought the speed limit only applied to people with driving licenses.
Hide Signatures
       Post #: 5
RE: Faster NiMH Chargers? - 10/11/2012 9:15 PM
Goldenduff
Score: 114
Status: offline
Capacity is not a factor. As stated above the peak voltage of 2cell lipo will not hurt your esc. The advantage of lipo is voltage stays steady through out the run so speed doesn't drop however because of this you need to be careful not to over discharge them. Also storage and charge can be dangerous e- as can crossing the road!
Hide Signatures
(in reply to trax de max)
       Post #: 6
RE: Faster NiMH Chargers? - 10/11/2012 9:20 PM
trax de max
Score: 114
Status: offline
I forgot to add you need a low voltage alarm or cut off with lipo. If this is your first go at lipo then this is very important takes a long time to get timing right too not use alarms or cut off's
Hide Signatures
       Post #: 7
RE: Faster NiMH Chargers? - 10/11/2012 9:45 PM
Zlash03
Score: 100
Status: offline
quote:
ORIGINAL: trax de max
Yeah this would be my first LiPo for a car. (I have a Blade MQX but it came with the built-in LVC and LiPo charger.) I read up on LiPo's a lot not to long ago and I know all about the alarms and LVC's. Would the mAHs still matter since the esc doesnt want more than 3600? Cause I found a Charger and LiPo combo here and its 3200mAH: http://www.rcplanet.com/Venom_LiPo_2S_7_4V_3200mAh_Battery_Venom_2_4_Cell_p/vnr1553-vnr0652.htm Then I would just plug the balancer on the battery into this alarm: http://www.ebay.com/itm/NEW-2in1-Indicator-1-8s-RC-Lipo-Battery-voltage-Tester-low-voltage-Buzzer-Alarm-/251142978169?pt=Radio_Control_Parts_Accessories&hash=item3a7949ba79 Would that be an ok setup for what im looking for? The alarm seems pretty popular though too.
Hide Signatures
       Post #: 8
RE: Faster NiMH Chargers? - 10/11/2012 10:10 PM
Goldenduff
Score: 114
Status: offline
Capacity in mah does not matter. The motor will draw the current it needs. As long as the battery can provide the rate of amp draw the capacity will only determine how long it can sustain the delivery of the amp draw.
Hide Signatures
       Post #: 9
RE: Faster NiMH Chargers? - 10/11/2012 10:24 PM
Zlash03
Score: 100
Status: offline
Oh ok. I see. I think I will just stick with this setup for right now though in the interest of price since I can just get more LiPos later on and use the same charger. Thanks.
Hide Signatures
       Post #: 10
RE: Faster NiMH Chargers? - 10/11/2012 10:34 PM
trax de max
Score: 114
Status: offline
that alarm would work, there is maybe the same but less cost ones.
I think i would choose a charger with a display so you can see what's happening with the battery rather than one with leds. For batteries this size you don't need a powerful charger.
Battery i'd choose the small capacity nano techs. 2200mah rather than the venoms. google N2200.2S.25.
Hide Signatures
       Post #: 11
RE: Faster NiMH Chargers? - 10/11/2012 10:42 PM
Zlash03
Score: 100
Status: offline
I might have to consider that battery or one like it. Cant beat the price though thats for sure. I paid more for my Mini-T battery.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
