RE: PKFW IV Ausf K mit schmalturm und KWK75/L70    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: PKFW IV Ausf K mit schmalturm und KWK75/L70
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 10/25/2012 6:09 PM
Panther F
Score: 135
Last Login: 5/19/2013
Status: offline
Nice work there! At least you're making progress with yours.
~ Jeff
Hide Signatures
(in reply to EOT)
       Post #: 26
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 10/26/2012 4:10 AM
bowlman
Score: 104
Last Login: 5/17/2013
Status: offline
Looks good Mike I like how you did the elevation .
Jimmy
Hide Signatures
(in reply to Panther F)
       Post #: 27
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 10/28/2012 11:42 AM
EOT
Score: 110
Last Login: 5/14/2013
Status: offline
Panther F and Bowlman,
Thanks for the compliments.
Been sick most of the week and only got the 400 speed motors mounted. I seem to have misplaced my 10 tooth pinionsand put 12 tooth on instead which meant enlarging one screw hole and the center hole. Next will be updating the exhaust and adding tools.
Mike        EOT
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Armorcreations.weebly.com
Hide Signatures
(in reply to bowlman)
       Post #: 28
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 10/28/2012 12:01 PM
Panther F
Score: 135
Status: offline
Let us know how those 400's turn out and if they are fairly quiet too.
~ Jeff
Hide Signatures
(in reply to EOT)
       Post #: 29
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/2/2012 3:09 AM
EOT
Score: 110
Status: offline
Will do Jeff I plan on running it a bit before painting. I also plan on changing the gearboxes later,after I get back to work. to the steel ones and maybe 480 motors  But for now this is a use what you got on hand build
Mike        EOT
< Message edited by EOT -- 11/2/2012 9:30 AM >
Hide Signatures
       Post #: 30
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/2/2012 3:24 AM
EOT
Score: 110
Status: offline
OK I've been going crazy and worried about Joe couple days trying to get as much info for him as possible for when I could get a hold of him. He has access to food now and is much happier about that, he's not happy about how long the power will be out. I know if I work on something he'll call! And half way through this installment guess what??? He calls-murphy's Law right....aahh the things you'll do for your business partner and friend
OK back to work in a much better mood I made up the bits for the late exhaust and installed them. Then scrounged my surplus sprues for various pioneer tools and glued down the tools in likely locations. Late Panthers and Jagd Panthers had tools moved to the rear so I did the same with this tank.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to EOT)
       Post #: 31
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/2/2012 4:25 AM
MAUS45
Score: 100
Status: offline
Looks good Mike!!!. I am wondering if you should remove the small muffler next to the main exhaust? I know it was done away with when the Panzer IV J had the auxiliary turret traverse motor removed in favor of carrying more fuel. Not saying you have to because I know this is a paper panzer. It may have been needed for the heaver Schmalturm?
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
(in reply to EOT)
       Post #: 32
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/2/2012 10:59 AM
EOT
Score: 110
Status: offline
Maus,
I wondered what that was now I know I think I'll leave it in due to the Schmalturm.
I added some lines in the front for interlocking armor but they don't show up in pics so no picies this time
Also put some more putty in areas that needed it
Mike        EOT
Hide Signatures
(in reply to MAUS45)
       Post #: 33
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/2/2012 1:29 PM
Green Amphibian
Score: 115
Status: offline
Looking good there Mike. It will go great with your Stug.
Herman
The older I get, the better I was.
Hide Signatures
(in reply to EOT)
       Post #: 34
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/16/2012 5:27 PM
EOT
Score: 110
Status: offline
Thanks Herman,
It'll add some contrast to the Stug and my Panzer IV ausf H.
I added the electronics and did programming to the lower hull part. Still need to add a connector to the turret elevation motor , but I'm going to run it a bit to see how it does first. Also hogged out the battery box a bit for clearance. Seems my larger 5000 batteries don't fit in the HL battery box hence the crude hole!
A couple things I had happen. Adding the sloped styrene to the upper hull made it very rigid , so rigid it doesn't twist at all. I tried twisting it to the point I thought it would brake the glue bonds .  This will help the rest of the hull when re assembled.
The other thing is a safety item. I originally soldered the on off switch with the feed from the battery to the center terminal of the HL switch, that's a big NO NO, put that wire on the outside terminal. I didn't get it soldered well enough and it came loose shorting out against the negative post The next thing I smelled was an awful cooking wires smell and the battery got so hot I couldn't  touch it. In all of about 10 seconds! NOT GOOD. I disconnected the battery and put it outside for a couple house to cool, don't want a house fire and I've seen the result of one of these shorting out, they will catch fire just a heads up for all of you. Luckily no damage or fire
any way a few more picies
Mike        EOT
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Green Amphibian)
       Post #: 35
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/27/2012 7:32 AM
EOT
Score: 110
Status: offline
Finally got some time to work on this last weekend. After a couple tries at a paint mixture I'm happy with the base coat. Let's see if anyone can figure out what I'm up to with the color. Herman your excluded because you already know.
Mike        EOT
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to EOT)
       Post #: 36
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/27/2012 1:48 PM
MAUS45
Score: 100
Status: offline
IS it going to be a what if DAK Panzer?
Hide Signatures
(in reply to EOT)
       Post #: 37
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/27/2012 2:01 PM
thecommander
Score: 121
Status: offline
It looks good...but does it sound as good as it looks??? I want to hear the sounds soon Mike.....don't keep me waitng.
Join us at NEAD: http://groups.yahoo.com/group/queenspanzergroup/
He who ends up with the most toys wins!!!
Hide Signatures
       Post #: 38
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/29/2012 12:20 AM
MAUS45
Score: 100
Status: offline
Are you trying some preshading?
Hide Signatures
(in reply to EOT)
       Post #: 39
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/29/2012 12:51 AM
Pah co chu puk
Score: 110
Status: offline
Looks cool.  By the color I would guess it's a Highway Dept. tank.
HL Tiger I, HL Pzkw III, HL Stug, HL Jagdpanther
HL/DBC/DBU2 Panther G
Hide Signatures
       Post #: 40
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 11/29/2012 12:55 AM
mustclime
Score: 106
Last Login: 5/18/2013
Status: offline
Nice..........................may I sugest you lower the last track hanger wheel....hl got it so wrong there.....I really like it...it would look good next to my e50 and e100......
That which does not destroy me just makes me more irritable
Hide Signatures
       Post #: 41
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/1/2012 1:16 PM
EOT
Score: 110
Status: offline
quote:
ORIGINAL: Pah co chu puk
That was funny although I'm deprived of sleep right now. New job that requires 12 hour days and 7 days a week changing 4x4 truck transmissions but its better than unenjoyment.
Here's a hint think red southern clay
Mike        EOT
Hide Signatures
(in reply to Pah co chu puk)
       Post #: 42
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/6/2012 11:42 AM
EOT
Score: 110
Status: offline
OK we got the program at work finished and they sent us home early so having a night off I got back after this one and added some color. In the pics it looks gray but it is Tamiya's German green.
Mike        EOT
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by EOT -- 12/16/2012 12:42 AM >
Hide Signatures
(in reply to EOT)
       Post #: 43
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/6/2012 11:44 AM
EOT
Score: 110
Status: offline
OK now I need some help. Since this tank never really equisted I've decided to make it a tribute to Phil Pflueger. My question for all of you is should the tanks number be the month and year of his birth or death?
Mike        EOT
Hide Signatures
(in reply to EOT)
       Post #: 44
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/6/2012 5:31 PM
1sgt
Score: 118
Status: offline
I would say of his birthday as a selebration of a future vet and tanker enthusists.
jim
Hide Signatures
(in reply to EOT)
       Post #: 45
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/6/2012 6:11 PM
MAUS45
Score: 100
Status: offline
It's the Yellow undercoat that is effecting the Camo Green, or your camera is having trouble balancing the two colors? Still looks cool !!!!
I would use Phil's Birthday.
Hide Signatures
(in reply to EOT)
       Post #: 46
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/6/2012 6:36 PM
Buckeye36
Score: 110
Status: offline
Definitely Birthday.
Tam Tiger 1, Tam Sherman M4(105), Tam Jagdpanther G1 under construction
ElMod Jagdpanther G2, ElMod KV-1E, ElMod StuG 4
Hide Signatures
       Post #: 47
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/15/2012 2:58 AM
EOT
Score: 110
Status: offline
OK the birthday votes have it by a margin of 5 to 1, I know only 3 votes on the forum, Joe and Herman I talked to on the phone. I added a second coat of green and shot these pics upstairs and the color changed due to lighting. Also added a P to the front fender for Battle group Pflueger and a hand painted (yeah it shows but that's the way I wanted it) tribute to Phil on the back of the turret.
Sorry I don't have video capability but she runs and operates very well. Gears are quiet ( picked my best set of monkey metal gears) and she's fast. Should fit in well at Danville. That's why the orange paint, my attempt to blend in with the clay they use there. Camouflage is supposed to blend in with the location right?
Bob the sound is standard Hen Long but then this started as a budget build with pieces parts on hand.
I may add steel gear sets and EL MOD later once I have a steady job but for now she's done and awaiting the Extravaganza in the spring.
Mike        EOT
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by EOT -- 12/15/2012 1:35 PM >
Hide Signatures
(in reply to Buckeye36)
       Post #: 48
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/15/2012 1:39 PM
EOT
Score: 110
Status: offline
On it's first of many early dawn patrols
Mike                          EOT
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to EOT)
       Post #: 49
RE: PKFW IV Ausf K mit schmalturm und KWK75/L70 - 12/15/2012 1:55 PM
Panther F
Score: 135
Status: offline
I may have to make the Extravaganza just to see it up close Mike! It sure looks good!
Watching PATTON 360 on cable and I'm in the mood for a battle now!
~ Jeff
Hide Signatures
(in reply to EOT)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
