DLE Throttle arm question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DLE Throttle arm question
Page: [1]
Login
DLE Throttle arm question - 10/11/2012 6:21 PM
chuck993
Score: 100
Last Login: 11/26/2012
Status: offline
I just bought a DLE20 for my yak 90-120 and the picture in the manual does not match the throttle arm and choke arm position. My throttle arm is ligned up with the choke arm so the choke arm is in the way. The manual shows the choke arm on one side and the throttle arm on the other side. The only way I can do that is take the throttle arm off and flip it over, which means the servo will pull the throttle open vs pushing it open.
Has anyone run into this? Did you flip the throttle arm or use the provided throttle arm extension?
Chuck
Hide Signatures
       Post #: 1
RE: DLE Throttle arm question - 10/11/2012 6:50 PM
Truckracer
Score: 304
Last Login: 5/20/2013
Status: online
Its common practice to flip the arms as needed. You can also buy replacement arms that are offset further from the carb. These are available from Valley View and many other vendors. Don't feel that you are locked into using the arms as supplied.
Hide Signatures
(in reply to chuck993)
       Post #: 2
RE: DLE Throttle arm question - 10/11/2012 7:27 PM
chuck993
Score: 100
Status: offline
great, thanks, how about the placement of the throttle servo, the manual says to keep it a good distance from the engine, can I place it in the engine box or infront of the fuel tank, any distance required?
Hide Signatures
(in reply to Truckracer)
       Post #: 3
RE: DLE Throttle arm question - 10/11/2012 7:34 PM
Truckracer
Score: 304
Status: online
I usually place the servo fairly close to the engine ...... in the engine box or just behind it. There has been many words written about this subject and connecting the servo to the carb. Please do yourself a favor and read the sticky note at the top of this forum for gas engine newbies. Also, do some searches in this forum for throttle servo hookup, throttle servos, linkages, throttle curves, etc. Lots already written on the subject and very easy to search.
Hide Signatures
       Post #: 4
RE: DLE Throttle arm question - 10/12/2012 2:47 AM
chuck993
Score: 100
Status: offline
I have other gas engines, just that DLE manual seemed to stress not putting the throttle servo near the engine, that was my concern.
Hide Signatures
       Post #: 5
RE: DLE Throttle arm question - 10/12/2012 3:50 PM
raptureboy
Score: 178
Last Login: 5/18/2013
Status: offline
If you bought it from Tower then throw it out(the manual). It is useless, and follow the sticky notes. And throw out anything you know about glow engines and read all the notes here, by jedijody,T.O.M. and others.
_____________________________
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 6
RE: DLE Throttle arm question - 10/12/2012 10:02 PM
chuck993
Score: 100
Status: offline
yes the manual sucks i downloaded one online, I've got other gassers for the last 5 years, first time with a dle and some things seemed questionable, so I am use to gassers, should do pretty good in my yak once I get it setup correctly
Hide Signatures
(in reply to raptureboy)
       Post #: 7
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DLE Throttle arm question
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
