Rookie II Thrust line?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Rookie II Thrust line?
Page: [1]
Login
Rookie II Thrust line? - 10/11/2012 11:29 PM
carbunkle
Score: 100
Last Login: 5/19/2013
Status: offline
I wanted to check my thrust line and this is how I did it.
I am assuming it needs to be parallel with the bottom of the jet.
Experienced knowledge would be appreciated if shared.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Rookie II Thrust line? - 10/11/2012 11:53 PM
hotspot 01
Score: 100
Last Login: 5/21/2013
Status: online
I've actually got a little up thrust in mine with no bad affects now with 130 flights.
Hide Signatures
(in reply to carbunkle)
       Post #: 2
BaldEagel
Score: 118
Status: offline
I think it says in the instructions putting the thrust line about in line with the top of the fus, I admit when i flew mine I put a trim adjust on the T6 trim of the vectored thrust setting and flew it like that, it needed a bit of adjustment, but not much.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 3
RE: Rookie II Thrust line? - 10/12/2012 9:41 AM
Robrow
Score: 100
Status: offline
Nice jet, I miss mine sometimes, shame they have not replaced it with another entry level composite machine.
rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
(in reply to BaldEagel)
       Post #: 4
RE: Rookie II Thrust line? - 10/12/2012 10:44 AM
B.S.
Score: 100
Last Login: 5/16/2013
Status: offline
You can still buy one(new)..
Best Regards
Hide Signatures
(in reply to Robrow)
       Post #: 5
RE: Rookie II Thrust line? - 10/12/2012 1:16 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: B.S.
Sort of.
I tried to buy one all last spring/summer. The response was... I had to pay for it up front, and it was 10 weeks (min) for delivery. Why have a US distributor if they aren't going to stock anything??
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to B.S.)
       Post #: 6
RE: Rookie II Thrust line? - 10/12/2012 8:36 PM
B.S.
Score: 100
Status: offline
Oh bad...
In Europe you can buy it here and it is on stock:
http://www.der-schweighofer.at/wg/6537/jet_trainer
Best Regards
Hide Signatures
(in reply to Dr Honda)
       Post #: 7
RE: Rookie II Thrust line? - 10/12/2012 11:40 PM
ivesdo
Score: 100
Status: offline
I always flew mine with neutral thrust.  Let the mounting rails set the thrust.  I set the nozzle by eye to neutral as well and never seemed to have any issues with changes in trim due to thrust.  The only thing I can say about my setup is that I am flying with a Simjet 1700 (17 lb engine), started with a Kangaroo, then a Rookie 1 and the the II.  As a result of the lower thrust, the thrust nozzle never had a lot of effect except to help around corners and raise the nose for landing.
I flew it again later this last season and really had fun with it.
Doug
Doug Ives
Hide Signatures
(in reply to B.S.)
       Post #: 8
RE: Rookie II Thrust line? - 10/13/2012 10:58 AM
BaldEagel
Score: 118
Status: offline
C-ARF have available a full vectored thrust unit for the Rookie, its a lot lighter than the Zimmerman unit, but not as well made.
Mike
Hide Signatures
(in reply to ivesdo)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
