RE: Kit building glue    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Kit building glue
Page: <<   < prev  1 [2]
Login
RE: Kit building glue - 10/14/2012 5:07 AM
glydrjocky
Score: 100
Last Login: 5/23/2013
Status: offline
Elmers wood glue and Titebond have held strong over time. I built a Wanderer glider back in 1981 and still have the well worn wing hanging on the wall. The Bridi Trainer 40, which I still fly today, was built the next year. Both the glider wing and the trainer glue joints are holding strong after all this time. Wood glue is great and so is the patience required when you build with it. Sometimes I long for those days on the work bench in high school when I would frame up a wing, turn out the garage light and let it sit till I got home from school to unpin it the next day.
Hope that helps,
Tony
_____________________________
" The only people who truly know where the "edge" lies, are those who have gone over"
Hide Signatures
(in reply to oldbassard)
       Post #: 26
RE: Kit building glue - 10/15/2012 12:51 PM
Zor
Score: 181
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: klord125
I use Titebond. But I make sure I clean up any excess real good. Mostly because I'm a weight nut and when sanding sheeting or other areas it makes a big difference if you get rid of any excess. I can't use CA it kills me. I loved using Ambroid but build time is a little longer in my opinion.
klord125,
It would have been interesting if you had been able to back up the big difference with figures; at least an estimate.
Zor
Hide Signatures
(in reply to klord125)
       Post #: 27
RE: Kit building glue - 10/15/2012 3:50 PM
klord125
Score: 100
Status: offline
Zor, My point wasn't from a weight thing. Thats just me from 1/2a days and haven't been able to let it go.  I was refering to sanding the glue. It makes a big difference when final sanding from an ease stand point. Just my .02
Hide Signatures
(in reply to Zor)
       Post #: 28
RE: Kit building glue - 10/15/2012 4:39 PM
Fleet
Score: 100
Last Login: 11/14/2012
Status: offline
Man, what great memories.   We used to build our planes in woodshop in school.   Helped in our grades but we still had to make birdhouses, whirlygigs, and simple furniture for the better part of the grade.
Good to, the school board let us use a schoolbus with driver for a weekender to Patuxant River, Maryland for an AMA contests.  Those days are long gone and not likely to be repeated.
Ray W
Fleet Brotherhood #7
Hide Signatures
       Post #: 29
RE: Kit building glue - 10/16/2012 6:29 AM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: Zor
quote:
ORIGINAL: klord125
klord125,
Zor
You said that you were a weight nut and I interpeted (I think logically) that removing the surplus was saving lots of weight of the model.
I was suggesting that you could have  given an estimate of how much weight it was saving.
Zor
Hide Signatures
(in reply to Zor)
       Post #: 30
RE: Kit building glue - 10/16/2012 1:55 PM
ARUP
Score: 134
Status: offline
I like wood glue, Ambroid (Sigment, Duco) and epoxy. I only use CA to fab jigs. For me, CA is terrible if it get on something that needs sanding.
As an aside about weight savings: the 1933 Darmstadt D-28b 'Windspiel' sailplane was built with a primary goal of a very small, efficient, manoeverable and lightest sailplane possible to take advantage of small thermals. Quoting Martin Simons' book 'Sailplanes 1920-1945'- "All joints were carefully wiped before the adhesive set." is found on p82.
Interesting stuff that goes to show there is nothing new under the sun!
Hide Signatures
(in reply to Zor)
       Post #: 31
RE: Kit building glue - 10/16/2012 2:59 PM
klord125
Score: 100
Status: offline
I have never weighed the excess glue that I removed. Its not that big a deal on larger planes. But it can be on smaller 1/2a and such planes when grams/ounces are a big deal.
Hide Signatures
(in reply to ARUP)
       Post #: 32
RE: Kit building glue - 10/16/2012 3:34 PM
Edwin
Score: 156
Status: online
*Titebond - For general building. No need to work fast, its just a hobby.
*CA - Little tack jobs, small repairs, ca hinges, maybe a fiberglass patch. Too expensive to use regularly.
*30 min epoxy - High strength areas.
*Less than 30 min epoxy - thinned with denatured alcohol for fuel proofing.
*Gorilla Glue or any other polyu foaming glue (I used to use ProBond, cant find it anymore) - Where 30 min epoxy wont work. Like some windshield installations (very fine bead), wing mounting joints, robart hinges (couple of drops does fine), and wing sheeting.
*GOOP - Stick anything to air. I use it to glue parts to Polyester glass fuses (epoxy doesnt stick so good to polye), like air tanks to a polye fuse.
*RC-56 (or equivalent) - for canopies that i dont screw on.
*JB Weld - Thinned with denatured alcohol makes a good heat shield inside a cowl and on the fuse.
*Hobby Finish Reson - For glassing to wood, also makes a good filler when mixed with micro balloons or saw dust. Sands like hard balsa.
For making cowls - Thinned 30 min epoxy or finish reson. Finish reson is a little more stiffer than epoxy. Both are durable.
The only reason I dont use West Systems reson is cost and quantity. I dont need so much. UNLESS - I'm making a glass fuse which I havent done yet.
Edwin
Hide Signatures
       Post #: 33
RE: Kit building glue - 10/19/2012 1:52 AM
tennessee_flash
Score: 105
Last Login: 5/24/2013
Status: offline
What is the best glue to use for laminating large doublers without worrying about warping?
Hide Signatures
(in reply to Edwin)
       Post #: 34
RE: Kit building glue - 10/19/2012 1:54 AM
Edwin
Score: 156
Status: online
I use titebond. Sandwich them between two pieces of straight wood and weight it down.
Edwin
Hide Signatures
(in reply to tennessee_flash)
       Post #: 35
RE: Kit building glue - 10/19/2012 2:00 AM
VincentJ
Score: 145
Status: offline
Good advice.
VJ
Hide Signatures
(in reply to Edwin)
       Post #: 36
RE: Kit building glue - 10/19/2012 2:07 AM
tennessee_flash
Score: 105
Status: offline
Thank you Edwin.
Flash
Hide Signatures
(in reply to VincentJ)
       Post #: 37
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
