Throttle linkage for Gas engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Throttle linkage for Gas engines
Page: [1]
Login
Throttle linkage for Gas engines - 10/12/2012 3:52 PM
aminklein
Score: 100
Last Login: 5/9/2013
Status: offline
I've read that a direct metal-to-metal connection on the throttle linkage for a gas engine will cause electrical interference between the ignition and the radio receiver.  It's recommended to use some sort of nylon component on the linkage to insulate the connection.  Will a nylon clevis on the throttle arm of the engine work?  Will the heat from the engine effect the nylon clevis?  I'm looking for a heavy duty nylon clevis that will fit a 2-20 thread on a rod, but they're hard to find.  Is there any other solution?  Thanks
Hide Signatures
       Post #: 1
RE: Throttle linkage for Gas engines - 10/12/2012 3:58 PM
BarracudaHockey
Score: 280
Last Login: 5/21/2013
Status: offline
A nylon clevis will be fine.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to aminklein)
       Post #: 2
RE: Throttle linkage for Gas engines - 10/12/2012 7:53 PM
hobby_man
Score: 105
Last Login: 3/23/2013
Status: offline
you are correct with regard's to the plastic. You also want the connection to stay on the throttle linkage, they way you set up a nitro engine will not work.
I use a meatal ball with a 4-40 or 5-56 screw though it and a washer on top of the plastic rod end to keep the plastic link from popping off the ball.
pm me and I can send you a picture.
or these work
http://www.sullivanproducts.com/ContSysAccMainFrame.htm
the plastic wheel on the servo will stop the electricity
Hide Signatures
       Post #: 3
RE: Throttle linkage for Gas engines - 10/12/2012 10:42 PM
3136
Score: 135
Status: offline
Have a look at this thread.
http://www.rcuniverse.com/forum/m_11210996/anchors_11212005/mpage_1/key_/anchor/tm.htm#11212005
Regards Mark
regards Mark
Hide Signatures
(in reply to hobby_man)
       Post #: 4
RE: Throttle linkage for Gas engines - 10/13/2012 5:20 AM
vertical grimmace
Score: 149
Last Login: 5/22/2013
Status: offline
I use a plastic ball link threaded 2-56 into a short thread then into a golden rod inner sleeve supported by the red or grey outer sleeve. A nylon clevis would be fine though I am sure. The one time I had bad RF interference was from a bad plug cap on my G38. With 2.4 and a modern EI, you should not have much to worry about with the nylon clevis.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to 3136)
       Post #: 5
RE: Throttle linkage for Gas engines - 10/16/2012 5:07 PM
gade600sdi
Score: 115
Last Login: 5/17/2013
Status: offline
Use a 2-56 ball link on a carbon rod or a nyrod, metal rod last choice. The RF is not as big a concern on 2.4 systems, the bigger concern you have is using a clevis, too much slop and will inconsistent idle. A clevis suggested above is wrong a BALL LINK!
Hide Signatures
(in reply to vertical grimmace)
       Post #: 6
RE: Throttle linkage for Gas engines - 10/16/2012 5:42 PM
pilotpete2
Score: 120
Status: offline
Ball links on both ends, Dubro flexible metal cable with the throttle spring left engaged. Very smooth and slop free, especially with the return spring engaged.
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to gade600sdi)
       Post #: 7
RE: Throttle linkage for Gas engines - 10/17/2012 5:40 PM
gade600sdi
Score: 115
Status: offline
quote:
ORIGINAL: pilotpete2
Pete
I should have said what Pete said BALL LINKS meaning on each end. Just dont use any clevises. I agree with the throttle spring also, I usually try to unhook it and move it to the next hole so the servo drain is a little less, but I would prefer a solid rod vs. cable which has some play involved, never tried the flexible cable but not sure what advantage it would have over a straight nyrod or metal rod.
Hide Signatures
(in reply to pilotpete2)
       Post #: 8
RE: Throttle linkage for Gas engines - 10/17/2012 6:19 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
I use fiber arrow shafts and ball ends and I unhook the spring completely.
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Throttle linkage for Gas engines
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
