Clutch keeps sticking    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Clutch keeps sticking
Page: [1]
Login
Clutch keeps sticking - 10/13/2012 1:46 AM
jbnn85
Score: 100
Last Login: 10/17/2012
Status: offline
why does my clutch keep sticking? i have tried to fix this problem a few times now. does my clutch bell need replaced? i have replaced the shoes and it fixed it of a few min. and then i saw the metal flakes again and the clutch bell keep turning. i have a caldera 3.0.. i noticed that the clutch spring didnt stay inside of the clutch shoes like i think it should. what can i do to fix my problem!!!
Hide Signatures
       Post #: 1
RE: Clutch keeps sticking - 10/13/2012 1:54 AM
nitrosportsandrunner
Score: 296
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: jbnn85
did you seat the springs on the pegs properly?
Also, could any of your bearing be bad?
And if the spring didnt stay in the groove for the shoes then the shoes will be grabbing the clutch even at idle speed.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to jbnn85)
       Post #: 2
RE: Clutch keeps sticking - 10/13/2012 4:13 AM
jbnn85
Score: 100
Status: offline
Ok cool i will check the bearings next. i have the clutch taken apart right now. maybe that is what it is.  i just read on making it to where you clutch grabs at higher rpm. basically lighting the clutch shoes. have you ever tried that? it also said that heavier clutch shoes engage earlier.
  thank you
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Clutch keeps sticking - 10/13/2012 2:00 PM
Score: 296
Status: offline
quote:
ORIGINAL: jbnn85
  thank you
the weight of the shoes will change when they engage (heavier sooner, lighter at higher rpms) but the type of spring can have the same effect. A stronger spring will mean the clutch grabs at higher rpms.
Im wondering if the spring came out of place. that would let the shoes touch the bell even at idle. and if the spring was out of place it may have been scraping against stuff.
There may also be washers which set the distance between the shoes and the clutch bell.
Hide Signatures
       Post #: 4
RE: Clutch keeps sticking - 10/13/2012 10:39 PM
jbnn85
Score: 100
Status: offline
so i checked the bearings and they are ok. cleaned them and lubed them a little. i drilled 3 little holes in each clutch shoe. and that is working so far i drove it at half speed for about 15 min. i found a few more little metal flakes, but the clutch seems to be doing good.
when i get it over half throttle the motor cuts out. Does that mean i am running it to rich? when it is stopped and i punch it to full throttle it takes off then get to a certain speed and they it just stops. but it blows out smoke the hole time and right before it stops it blows out a bunch of smoke. i wonder what it might be thats the only problem i am having with it right now .
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
