play in rear wheels on volcano epx pro    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Volcano EPX PRO
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> play in rear wheels on volcano epx pro
    Page: [1]
    Login
    play in rear wheels on volcano epx pro - 10/15/2012 10:21 PM
    NateDogg80
    Score: 100
    Last Login: 2/26/2013
    Status: offline
    All of the wheels on the truck have a little play in them which i assume is normal. but it seems i have a little more in the rear.  Especially on one side, the wheel kinda of tilts in. Nothin seems to be be broken or bent.  Could it be wheel bearings or drive cups or what?  Any help would be greatly appreciated.
    Hide Signatures
           Post #: 1
    RE: play in rear wheels on volcano epx pro - 10/15/2012 10:29 PM
    nitrosportsandrunner
    Score: 296
    Last Login: 6/18/2013
    Status: offline
    quote:
    ORIGINAL: NateDogg80
    could indeed be the bearings.
    could also be a spacing issue. the hole in the stub axle that the drive pin goes threw should be almost flush with the ball bearing on the outside of the wheel hub. But if its out a tad further, then you get some play. A washer or shim can take up the slop. Careful its not too thick, as that will make the wheel drag.
    Sometimes the wheel hubs get a bit of slop in them, where the ball bearings press in. a bearing cant do its job if its not tight in the hub.
    You will want to check over those things and replace if needed. Play can damage the dogbone.
    If no one part seems to be in fault, then just run it as is. Alittle play wont break anything right away. But if you find a bad bearing, replace it ASAP.
    _____________________________
    SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 rock crawler, Redcat
    Hide Signatures
    (in reply to NateDogg80)
           Post #: 2
    RE: play in rear wheels on volcano epx pro - 10/16/2012 8:17 PM
    NateDogg80
    Score: 100
    Status: offline
    THANKS AGAIN.
    One other question.  I see they make different rated or size bearings for my volcano.  A 10*5*4 bearing and a 15*10*4 bearing.  Do you know what the difference is and which ones I need?
    Hide Signatures
    (in reply to nitrosportsandrunner)
           Post #: 3
    RE: play in rear wheels on volcano epx pro - 10/16/2012 10:50 PM
    Score: 296
    Status: offline
    THANKS AGAIN.
    that sir, is a trick question
    the epx pro models have hubs which use 2 different bearings. Larger bearing on the inside, smaller on the outside.
    so you need both 02138 and 02139 in order to replace the bearins in all 4 wheel hubs.
    Hide Signatures
           Post #: 4
    RE: play in rear wheels on volcano epx pro - 10/17/2012 12:01 AM
    NateDogg80
    Score: 100
    Status: offline
    I'm confused.....  What do you mean by the inside AND outside?
    I took off rear wheel hubs to replace with aluminum and only replaced one bearing per side because thats all I saw.  Did I miss something, or is the second set in another place?
    Hide Signatures
           Post #: 5
    RE: play in rear wheels on volcano epx pro - 10/17/2012 12:42 AM
    Score: 296
    Status: offline
    If you pull the stub axle out of the wheel hub, you should see a larger bearing that was between the axle and hub. The smaller bearing sits on the outside of the hub, closest to the wheel.
    Hide Signatures
           Post #: 6
    RE: play in rear wheels on volcano epx pro - 10/17/2012 6:35 PM
    NateDogg80
    Score: 100
    Status: offline
    Do''h!!!!!
    That explains why i have so much slop in my rear wheels.
    OK..... so how in the heck do you get the larger bearing out of the hub.  it looks darn near impossible.
    Hide Signatures
           Post #: 7
    RE: play in rear wheels on volcano epx pro - 10/17/2012 6:53 PM
    Score: 296
    Status: offline
    Do''h!!!!!
    a small flat screw driver can do the job.
    doesnt hurt to spray alittle WD40 1st. Dirt and such will make the bearing not want to come out.
    you have to pry alittle here, then there to work it out evenly.
    Once its out alittle, the screw driver can be used from the side the other bearing was in to push it out.
    Not having that bearing in your new hubs will indeed make it wobbly!
    Honestly, if you are installing new hubs I suggest putting in new bearings. Not doing so is like changing your car's oil but leaving in the old oil filter. Its gonna be better, but not the best.
    Hide Signatures
           Post #: 8
    RE: play in rear wheels on volcano epx pro - 11/21/2012 1:20 AM
    madweasel
    Score: 100
    Last Login: 5/22/2013
    Status: offline
     If I may suggest..you might want switch out the plastic hubs and go to aluminum. They tend to break easy with a few good jumps lol
    Hide Signatures
           Post #: 9
    Page:   [1]
    Page: [1]
    Volcano EPX PRO
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.625RCU1
