RE: Cons for installing redundant receiver batteries ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Cons for installing redundant receiver batteries ?
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 4:13 AM
John Redman
Score: 117
Last Login: 5/19/2013
Status: offline
Hey David, very interesting. I am not crazy electrical savvy so I rely on sources in this area. My source for this one was Bob Wilcox who is an electrical engineer by trade and knows electronics inside and out. I just followed his instruction back in the days of nicads. I have always trusted him intently in this area and his guidance has never let me down.
Either way, I will totally agree that no turbine powered model should be flown with one radio system battery.
_____________________________
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
(in reply to VF84sluggo)
       Post #: 26
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 4:17 AM
PaulD
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: gooseF22
I prefer wolverine for a switch if not using switched regulators or a Powersafe rx..
I did some of the Flight testing and bench testing of the Wolverine design.. with 4 10 am mofsets, I can tell you that thing is robust.. I ran an electric motor thru it at 40 amps twin deans in and out.
That's interesting. I've become a BIG fan and user of these switches but had never heard any independent test data/results like this. I also have run set-ups with dual batteries and 2 switches but like the extra safety and security of the Wolverines.
Thanks for sharing that.
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
(in reply to gooseF22)
       Post #: 27
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 6:52 AM
GTMUSTANGCS
Score: 100
Last Login: 12/6/2012
Status: offline
how do you connect another battery to a receiver when it only has one "B" port?
Hide Signatures
       Post #: 28
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 7:58 AM
NZjet
Score: 100
Last Login: 5/20/2013
Status: online
quote:
ORIGINAL: GTMUSTANGCS
You can connect it anywhere along the reciever, not just a battery port. You can use a y lead off a servo port if required.
I have always run a simple 2 nicad 2 switch setup and never had a failure. usually one at the top and the other at the bottom of the reciever
Hide Signatures
(in reply to GTMUSTANGCS)
       Post #: 29
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 9:29 AM
Stobe777
Score: 100
Last Login: 5/17/2013
Status: offline
The real question is: why don´t we have 2 batteries also in the transmitter? : )
TP.
MBA Tornado + Merlin 90, CARF MiG-15 in the works.
T-Rex 800E flybarless. Multirotors. Futaba 18MZ.
Hide Signatures
(in reply to NZjet)
       Post #: 30
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 11:39 AM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: Stobe777
TP.
That is something that is being missed, the battery in the TX can go as easily as in the Aircraft, in fact probably easier, as normally the batts are AA size NIMh, where as in the aircraft they will normally be big sub C's (if not using a lipo) which are about ten times more resilient than a AA battery.
I think it would be great selling point for Manuf to incl a battery backup system in their transmitters, a simple button cell like their memory battery that will give say at least 15mins of use in the event of a main battery failure.
Saying all that two batteries are yes safer than one, but in 30 yrs of flying RC I have never had a battery fail in a TX or RX.
Batteries are probably the single cheapest item in our Aircraft, Maintenance & replacing them regular is the key, I change mine now every year, my favourite batteries are 2100nimh 4.8v vapex instants (same as eneloops) for my normal prop models cost £6.95 and 4300ma Nimh Sub Cs 4.8v for my Jets and Large models cost £14.00.
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to Stobe777)
       Post #: 31
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 12:14 PM
rcfun2005
Score: 100
Status: offline
"A couple of battery chare that I have used in the past are the Smart-Fly Battshare and the Fromeco Woverine switch. The Wolverine is a dual switch with a built in battery share circuit. It's also similarly priced to a pair of JR Heavy Duty switches so it's not particularly expensive."
so for a "basic" lower cost setup , sounds like the woverine switch provides the dual switches and the battery isolation circuit , win win...
thanks
Hide Signatures
(in reply to Xairflyer)
       Post #: 32
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 12:36 PM
rcfun2005
Score: 100
Status: offline
and,,,
so where is good place to order the Fromeco Woverine switch ?
looks like the fromeco web site is out of stock.
thanks, again, Joe
Hide Signatures
(in reply to rcfun2005)
       Post #: 33
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 1:14 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: Stobe777
TP.
Because its easy to glance at your transmitter to tell the voltage and its not subjected to vibrations and landings like a model (unless you drop it of course)
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 34
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:25 PM
PaulD
Score: 105
Status: offline
quote:
ORIGINAL: rcfun2005
and,,,
thanks, again, Joe
Dreamworks has lots:
http://dreamworksrc.com/catalog/advanced_search_result.php?osCsid=cf19785e1a241b6dee38d4c19681528d&keywords=Wolverine&categories_id=&inc_subcat=1&manufacturers_id=&pfrom=&pto=&dfrom=&dto=
PaulD
Hide Signatures
       Post #: 35
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:28 PM
planedriver_2
Score: 100
Last Login: 5/15/2013
Status: offline
Couldn't you use two batteries, two switches, two regulators, into a Y to your B/7 or whatever power port you have and if one fails the other is ready to supply the system with the needed voltage to keep from having a bad day.
I had a set up similar to this and seemed to work fine for me in that large airplane. If anyone has a better way i would like to know. It's been a while since the set up was in one of my airplanes so i could be wrong about how it was. I think it's the way it was.
I will be doing something similar very soon for another larger plane..... I will be back to watch this progress to maybe learn something new or better.
Planedriver
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 36
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:30 PM
planedriver_2
Score: 100
Status: offline
with a Y
Hide Signatures
       Post #: 37
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:39 PM
Dr Honda
Score: 100
Status: offline
Why add regulators? I know that "Good" brands are generally reliable.... but it's just adding a failure point. I know of a big Viper that went in because the PowerBox was suspect. (I think it shouldn't have flown) Also... regulators waste power, and inject potential RF noise.
Simple is better... more reliable... and cheaper. There are no issues with using 2 batteries, and 2 switches. PERIOD!!
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to planedriver_2)
       Post #: 38
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:45 PM
Xairflyer
Score: 105
Status: offline
I agree when you use a regulator you are adding a fail point into your system the whole idea is to increase reliability
www.jmaireland.com
Hide Signatures
(in reply to Dr Honda)
       Post #: 39
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:57 PM
ash 26
Score: 100
Last Login: 5/3/2013
Status: offline
quote:
ORIGINAL: Xairflyer
quote:
ORIGINAL: Stobe777
TP.
My old Multiplex 3030 had that aready 20years ago
Hide Signatures
       Post #: 40
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 2:58 PM
rcfun2005
Score: 100
Status: offline
seems like isolation circ would be important ? depending how first batt goes bad , it could draw down the 2cd batt volt without isolation circ .
agree , regulator not required with a123 type batt
Hide Signatures
       Post #: 41
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 3:18 PM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: ash 26
Do they still have it?
www.jmaireland.com
Hide Signatures
(in reply to ash 26)
       Post #: 42
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 4:00 PM
BlueBus320
Score: 100
Status: offline
Wow, thanks for posting, this is a very important thread. Being out of turbines since 2005, I've missed A LOT!!! (123's, regulators, lipo's, even 2.4ghz..bad time to go on hiatus). I usually don't even recognize all the fancy shiny stuff guys put into their birds now a days. I'm setting up a jet now & caught this thread at the right time
Think I'll go with double 123's and a Wolverine
Call Sign blocked.
Hide Signatures
       Post #: 43
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 4:03 PM
BlueBus320
Score: 100
Status: offline
If the wolverine fails, do you loose both ports? It seems like it may be better to go with 2 individual high quality switches.
Call Sign blocked.
Hide Signatures
(in reply to BlueBus320)
       Post #: 44
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 4:52 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: BlueBus320
It can.... and you will be better off just using 2 good switches. I know most of these Regulator/safety Switch companies advertise that when they fail... they fail "ON". But lets face it... if electronics fail... you don't know what's going to happen. In no way am I saying they are bad switches... but I'm all about keeping it simple, and cheap.
FYI... Since you've been away... "A123" is just a brand. The type of battery we are normally talking about is a LiFe battery. (Lithium Iron) It's like a LiPo, but it's normal output is 6.6v for a 2 cell pack. So... They output the same as a 5 cell NiCd pack. And because of that.... You dont need a regulator.
Tony
Hide Signatures
       Post #: 45
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 5:09 PM
BlueBus320
Score: 100
Status: offline
Thanks Dr Honda!.. I was hoping someone would chime in quick, as I am Finishing up my cart with Dreamworks as we speak. From my research on the Wolverine this morning, it appears that the 2 switches share a common circuitry board, so I agree 100%. 2 switches seem to be the only way to truly have 2 independent power sources.
Call Sign blocked.
Hide Signatures
       Post #: 46
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 5:34 PM
rcfun2005
Score: 100
Status: offline
"2 independent power sources" but if you plugging them into one reciever bus ,,, your 2 sources are now connected on the one bus ... so depending on way a cell fails it can draw down the other batt being connected on one bus with no isolator circ...
so what is going to be the failure your protecting against ? ....
no right answer ... just pros and cons both ways...
interesting
Hide Signatures
       Post #: 47
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 5:57 PM
airraptor
Score: 130
Status: offline
dont have to run A123 when the LiFe's are just as good. I only LiFe's in all my planes now.
The Wolverine is one of the best switches on the market...................
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 48
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 6:02 PM
ash 26
Score: 100
Status: offline
quote:
ORIGINAL: Xairflyer
quote:
ORIGINAL: ash 26
yes still do it have it in my MC 4000
Hide Signatures
       Post #: 49
RE: Cons for installing redundant receiver batteries ? - 10/19/2012 6:26 PM
BaldEagel
Score: 118
Status: offline
According to Fromeco (the manufacture) its failure mode is on so everything stays connected.
There are major difference's between A123's as the standard, P04LiFi, LiIon and LiPo, the genuine A123's are capable of being charged at 10amps without a problem and can discharge at up to 80Amp, The P04's that have been copying the A123 chemistry, (useless when they first came out) although improved in recent years they do not come close to the performance of the genuine A123 and do not use the Nano Phosphate technology, this also applies to the LiIon's out there, LiPo's are a different ball game all together, easily damaged, soft case and if miss treated or incorrectly charged they are prone to catching fire, I suggest you do a bit of research on the different chemistries to get yourself up to speed.
Mike
EDIT: have a look at post 18 on this thread: http://www.rcuniverse.com/forum/m_11265939/tm.htm explains in detail the difference between A123's and the P04's.
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
