RE: Cons for installing redundant receiver batteries ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Cons for installing redundant receiver batteries ?
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Cons for installing redundant receiver batteries ? - 10/24/2012 9:47 AM
David Gladwin
Score: 110
Last Login: 5/19/2013
Status: online
Goose, doesn't really surprise me that the F16 has so many power supplies, FBW+ no power= no control and I guess some of those backups are designed to cope with battle damage and still get you home, or even stay in the fight !
Sid, entirely agree but I could go further and say even small GT models should have dual batteries. My little Savex L39 with a Wren 44 is so light I can lift it with one finger, but it, too, has twin Rx batteries !Weight gain is insignificant. Its a bit of a tester too, one battery is a Duralite Lithium Ion the other is a Lipo, both seem to discharge at about the same rate. Both feed the Weatronics 8 channel Smart receiver via Mini Hobby Turbo regulators and JR HD switches, and the log shows DEAD stable voltage, 5.4v, on the rx bus.
Just as interest my larger models are all fitted with Weatronics 12-22 receivers for probably the ultimate in secure power supplies:
1. Twin batteries, one main, one standby.
2. Automatic load test of BOTH batteries on EVERY switch on (7amps for .5 second) An audio visual warning is triggered if the volttage drop exceeds the value YOU set, dependant on battery health and capability, on the software.
3. 8 Regulators distributed ober the servo outputs, all rated at 5 amps continuous, very large heatsink.
4. Battery connection is an electronically "latched contactor" so that switch failure/disconnection leaves power connected.
5. Real time audio/visual alert of battery voltage drop/changeover via the telemetry downlink.
Difficult to know how that could be improved on in any significant way. But, never say never, well hardly ever ..... !
Morning coffee finished , back to my SG Hawk.
Regards, (and thank you for your supportive comments , guys, nice to know I am not just a lone voice in the wilderness)
David.
Hide Signatures
(in reply to gooseF22)
       Post #: 101
RE: Cons for installing redundant receiver batteries ? - 10/24/2012 12:19 PM
BaldEagel
Score: 118
Status: offline
Yeah thanks for your support everyone its nice to know that everyone has followed my lead and are using twin A123's
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to David Gladwin)
       Post #: 102
RE: Cons for installing redundant receiver batteries ? - 10/24/2012 8:35 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
Ok,... Im out of popcorn...
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to BaldEagel)
       Post #: 103
RE: Cons for installing redundant receiver batteries ? - 10/24/2012 10:25 PM
BaldEagel
Score: 118
Status: offline
Hide Signatures
       Post #: 104
RE: Cons for installing redundant receiver batteries ? - 12/6/2012 5:56 PM
abelard
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
I have been using A123's since they first came out
Possibly not much longer...
http://www.xconomy.com/boston/2012/12/06/a123-goes-on-the-auction-block-heres-how-it-got-this-bad/?single_page=true
Hide Signatures
       Post #: 105
RE: Cons for installing redundant receiver batteries ? - 12/6/2012 6:03 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
Nothing to do with our hobby batteries
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to abelard)
       Post #: 106
RE: Cons for installing redundant receiver batteries ? - 12/13/2012 10:12 PM
BlueBus320
Score: 100
Status: offline
quote:
ORIGINAL: David Gladwin
4. Battery connection is an electronically ''latched contactor'' so that switch failure/disconnection leaves power connected.
David.
How did you set up an auto load test on every switch? I'm doing a setup now & would like to set this up. Also, the dual swithch guys with chargeports. Are you charging your batteries inside your models through the charge ports?
thanks
Call Sign blocked.
Hide Signatures
       Post #: 107
RE: Cons for installing redundant receiver batteries ? - 12/14/2012 1:12 AM
roger.alli
Score: 104
Status: online
quote:
ORIGINAL: BlueBus320
David.
thanks
What David is referring to here (point 2). Every time the receiver is switched on, the Weatronics 12xx receivers do an automatic load test of the batteries. This is a pre programmed function of these receivers.
Roger
Hide Signatures
(in reply to BlueBus320)
       Post #: 108
RE: Cons for installing redundant receiver batteries ? - 12/14/2012 2:02 AM
BlueBus320
Score: 100
Status: offline
oh, ok thanks
Call Sign blocked.
Hide Signatures
(in reply to roger.alli)
       Post #: 109
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
