Best place to buy Walbro carb kits..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Best place to buy Walbro carb kits..
Page: [1]
Login
Best place to buy Walbro carb kits.. - 10/18/2012 6:58 PM
foodstick
Score: 182
Last Login: 5/24/2013
Status: online
I wonder if anyone had a good recommendation for an online source for Walbro carb parts, I need a few diaphragms, some have dried up on the planes.
Hide Signatures
       Post #: 1
RE: Best place to buy Walbro carb kits.. - 10/19/2012 2:38 AM
Scota4570
Score: 115
Last Login: 5/18/2013
Status: offline
find a local old time saw shop that will sell you just what you need. Most of the stuff in the rebuild kits is not needed.
Hide Signatures
(in reply to foodstick)
       Post #: 2
RE: Best place to buy Walbro carb kits.. - 10/19/2012 4:06 AM
av8tor1977
Score: 665
Status: offline
Generally all that is needed is the regulator diaphragm, and I buy them by the "10 pack", wherever I can find them online cheap. Usually most of the other gaskets can be re-used.
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Scota4570)
       Post #: 3
RE: Best place to buy Walbro carb kits.. - 10/19/2012 7:18 PM
foodstick
Score: 182
Status: online
I might be interested in the 10 packs online, I have multiples of the same engines. I haven't ran across that before.. any chance you recall a vendor?
I will search some more, but so far I had found single kits, and was looking for the diaphragms..
addendum
ok, I did some searching and found the multi pack kits, they appear to have a different part number on them than the carb body, will the part number be on the old diaphragm when I pull it out? or is there a cross reference chart for the parts numbers used in each carb?
Any help is much appreciated...I don't think I have a single old diaphragm laying around to look at... I will take one apart when I get a chance...and see.
Hide Signatures
(in reply to av8tor1977)
       Post #: 4
RE: Best place to buy Walbro carb kits.. - 10/19/2012 7:51 PM
Tidnab
Score: 100
Last Login: 5/22/2013
Status: offline
Gizmomotors has 10 packs for $20 http://www.gizmomotors.com/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=244&category_id=16&option=com_virtuemart&Itemid=56
Hide Signatures
       Post #: 5
RE: Best place to buy Walbro carb kits.. - 10/19/2012 8:07 PM
av8tor1977
Score: 665
Status: offline
The diaphragm is the same for all WT series Walbro carbs, and many others. (The link above shows which models/series have the same diaphragm in common.)
AV8TOR
Hide Signatures
(in reply to Tidnab)
       Post #: 6
RE: Best place to buy Walbro carb kits.. - 10/20/2012 5:04 AM
foodstick
Score: 182
Status: online
Common part awesome, that works for me !
Hide Signatures
       Post #: 7
RE: Best place to buy Walbro carb kits.. - 10/20/2012 7:10 AM
rangerfredbob
Score: 115
Last Login: 5/23/2013
Status: offline
the only difference is the carbs with the primer bulb on the regulator side have the pass through port on the gasket, other than that all the WA and WT regulator diaphragms are the same.
Hide Signatures
       Post #: 8
RE: Best place to buy Walbro carb kits.. - 10/20/2012 11:19 PM
Nosedragger
Score: 113
Status: offline
there are 2 diaphragms used in WT,WA
pump diaphragms and metering diaphragm, no such thing as a regulator diaphragm in these carbs.
2 bucks each? I get them for half that.
Hide Signatures
(in reply to rangerfredbob)
       Post #: 9
RE: Best place to buy Walbro carb kits.. - 10/21/2012 9:49 AM
av8tor1977
Score: 665
Status: offline
Most people call the metering diaphragm a regulator diaphragm here in the forums. Where do you buy them?
AV8TOR
Hide Signatures
(in reply to Nosedragger)
       Post #: 10
RE: Best place to buy Walbro carb kits.. - 10/21/2012 12:41 PM
Tidnab
Score: 100
Status: offline
Are the ones you get for half the price of the ones in the link above,Walbro ones or aftermarket ?I've found that the aftermarket ones don't last as long.
Hide Signatures
       Post #: 11
RE: Best place to buy Walbro carb kits.. - 10/21/2012 3:01 PM
Nosedragger
Score: 113
Status: offline
The thing is if you do a search on regulator diaphragm it won't turn up as many results as if you used metering diaphragm.
Hide Signatures
       Post #: 12
RE: Best place to buy Walbro carb kits.. - 10/21/2012 8:16 PM
av8tor1977
Score: 665
Status: offline
Good point.
AV8TOR
Hide Signatures
       Post #: 13
RE: Best place to buy Walbro carb kits.. - 11/9/2012 3:24 AM
Flathead
Score: 100
Last Login: 5/11/2013
Status: offline
I just picked up 10 diaphragms from fosto tools on E-BAY for $11.99 and they pay shipping check it out "FLATHEAD"
Correction:   fausto_tools
- Moderator
< Message edited by w8ye -- 11/9/2012 11:49 PM >
Hide Signatures
       Post #: 14
RE: Best place to buy Walbro carb kits.. - 11/9/2012 5:38 AM
foodstick
Score: 182
Status: online
Ordered a set
Hide Signatures
(in reply to Flathead)
       Post #: 15
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Best place to buy Walbro carb kits..
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
