Charging Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Stinson SR-10 - RTF
Seller:  cybrmax
Details:   $165.00   |  5/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Charging Question
Page: [1]
Login
Charging Question - 10/19/2012 5:04 PM
flyboy138
Score: 100
Last Login: 1/17/2013
Status: offline
I'm new at this electric stuff and need a little help ,I have some Rhino 610, 20C, 3 cell, 11.1v batteries for my foamy that I need to charge what should I set my amps at?What is max amps I can set my charger at without hurting my battery?
< Message edited by flyboy138 -- 10/19/2012 9:39 PM >
_____________________________
3D RULES
Hide Signatures
       Post #: 1
RE: Charging Question - 10/19/2012 7:09 PM
rtec
Score: 100
Last Login: 1/22/2013
Status: offline
Hi, Most LiPo batteries like to be charged a 1C so in your case that would be under 1 amp. .610 to be more accurate. Most charges will not let you really pick .610 of an amp but, most will do 100ma increments. So I would chose .6 on the charger in BALANCE mode for a 3S battery 11.1V which will end up on the balancer at 4.20vdc x 3 fully charged or 12.6V total don’t let the battery get under 3.3V or ~70% below its capacity of .610
Another words, if when charging this battery your charger puts in more than 427ma you are draining the battery to low and risk damaging the cells of this battery.
Have fun
Bob Scrip
Hide Signatures
(in reply to flyboy138)
       Post #: 2
RE: Charging Question - 10/19/2012 10:39 PM
flyboy138
Score: 100
Status: offline
Would .610 be the highest amp I could go.Would 1.2 amps be to much?
< Message edited by flyboy138 -- 10/19/2012 11:09 PM >
3D RULES
Hide Signatures
(in reply to rtec)
       Post #: 3
RE: Charging Question - 10/21/2012 3:44 AM
rtec
Score: 100
Status: offline
 Hi,
I looked up your battery. Rhino 610 and according to the hobby king web site it says it can be charged @ 2C which means 2X.610 or 1.220amps.
So yes you can charge at 1.2A
Keep in mind that this is not true for all LiPo's and charging a LiPo to fast could make it but into flmes.
Also batteries that are chargered at more than 1C tend not to balance at well but that is easily fixed by charging it at 1C rate again or hooking it up to a balancer.
Bob
Hide Signatures
       Post #: 4
RE: Charging Question - 10/21/2012 3:58 AM
flyboy138
Score: 100
Status: offline
Ok Thanks Bob I charged them at .6 but they took like 40 minutes each to charge I will try 1.2 and see what kind of times I come up with when I fly the foamy tomorrow.I do charge them in balance mode.
3D RULES
Hide Signatures
(in reply to rtec)
       Post #: 5
RE: Charging Question - 10/21/2012 4:23 AM
rtec
Score: 100
Status: offline
 40mins to an hour is considered normal that's why I have several chargers and several batteries.
When I fly my extreme flight 78 inch extra 300 I use 2 4400 5S 40C batteries for each flight.
So I have 10 batteries and 6 chargers in the mix
Bob
Hide Signatures
       Post #: 6
RE: Charging Question - 10/21/2012 4:26 AM
flyboy138
Score: 100
Status: offline
Wow Bob them are big batteries.Is it the bigger the batteries the longer they take to charge???
3D RULES
Hide Signatures
(in reply to rtec)
       Post #: 7
RE: Charging Question - 10/21/2012 1:44 PM
rtec
Score: 100
Status: offline
 Hi,
No the time stays the same because you are charging @ 1C so the charger is putting out more current.
All charging should take about the same time. When charging at rate.
The only time it takes longer is when the charger being used can not put out the 1C rate.
Example: I use some 5800ma 6S batteries, which means the charger has to putout 5.8AMPS at 25.2Vdc so since your input voltage is generally around 12V the charger has to make up the differance and to do that it needs more current. More then double, so, we need 5.8 for charging, plus the higher voltage which is double the input voltage whicH doubles the current so we need 11.6Amps plus what the charger needs to run , starts to add up quick.
Bob
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
