Saito 100 needle problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 100 needle problems
Page: [1]
Login
Saito 100 needle problems - 10/21/2012 1:29 AM
AdamPrime
Score: 100
Last Login: 5/1/2013
Status: offline
 Hello I am new to 4-strokes and am having a bit of an issue with a Saito 100. I am using a Kelco custom exhaust on a Hangar 9 Spitfire with a blade 13x8 prop. I am having issues trying to get the engine tunned.  The issue that I am having is the high speed needle valve doesn't seem to have an effect on rpm. It peeks out around 10,300 rpm. When I turn out the needle valve it richens up but the rpms dont seem to change. 1 full turn will cause a 100 rpm drop. As it is richened the exhaust gets smokey and sloppy so it seems it is running rich but the rpms don't seem to change. When I shut it down there is oil and resuide covering the plane as you would expect from a rich engine. I have tried different fuels 15% synthetic and castrol blend and 30% all synthetic. I verified no issues with fuel lines and the Carb has no obstructions. As all of my previous experience is with 2 strokes I don't know if I am doing something wrong. I just dont know how to tune it if propperly if the rpms dont change.    Thanks   Adam
Hide Signatures
       Post #: 1
RE: Saito 100 needle problems - 10/21/2012 1:51 AM
w8ye
Score: 318
Last Login: 5/24/2013
Status: offline
Open up the low speed needle a little and try the high speed again
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to AdamPrime)
       Post #: 2
RE: Saito 100 needle problems - 10/21/2012 1:54 AM
blw
Score: 655
Status: offline
It sounds like your low speed needle valve is too rich.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 3
RE: Saito 100 needle problems - 10/21/2012 6:45 AM  1 votes
Ernie Misner
Score: 130
Status: offline
Is it possible that with that custom exhaust that you are not getting enough pressure to the tank somehow? I've had that happen and richening the HS needle didn't have much effect. Keep us posted, thanks,
Ernie Misner
Hide Signatures
(in reply to blw)
       Post #: 4
RE: Saito 100 needle problems - 10/21/2012 12:16 PM
Old Fart
Score: 158
Status: offline
Adam i'd set your low speed needle back to factory settings and peak the hsn, i think w8ye is saying you are to lean on the LSN.The prop figures at peak sound really too.
Watch out for the ground eh?
Hide Signatures
       Post #: 5
RE: Saito 100 needle problems - 10/21/2012 8:31 PM
blw
Score: 655
Status: offline
Well, that's embarrassing for sure. I meant too lean. Good grief.
Coach Pat Dye
Hide Signatures
(in reply to Old Fart)
       Post #: 6
RE: Saito 100 needle problems - 10/22/2012 2:55 AM
AdamPrime
Score: 100
Status: offline
I took a look at the low speed needle and it was turned in substantially. I think more than 4 full turn out to get it back to factory settings. I had my flying clubs "Saito expert" help me set it up originally and that is where he set it. I think that the low speed needle combined with the custom exhaust could be the problem. It does have a pressure tap but the scale exhaust system has 6 outlets so I am sure that it gives less pressure to the tank then the stock muffler.  I also think a contributing factor was the fuel lines used to have a siphoning effect. When I was breaking in the engine, I had to clamp off the fuel lines to keep the carb from filling with fuel when the engine wasn’t running. The siphoning mysteriously stopped and that was around the time I started having issues with the needle. I suppose the siphon effect was pushing more fuel in. Why the siphon stopped, I do not know.                Adam
< Message edited by AdamPrime -- 10/22/2012 3:52 AM >
Hide Signatures
       Post #: 7
RE: Saito 100 needle problems - 10/22/2012 5:58 AM
Ernie Misner
Score: 130
Status: offline
The further the carb is closed or the LS needle leaned, the less siphoning will occur.
Hide Signatures
       Post #: 8
RE: Saito 100 needle problems - 10/22/2012 1:04 PM
Old Fart
Score: 158
Status: offline
Hi ernie if the fuel tank is high in relation to the carb with a saito single inverted then you need to completely have the throttle barrel shut or it will continue to dribble fuel..the tank not me i hope
Hide Signatures
(in reply to Ernie Misner)
       Post #: 9
RE: Saito 100 needle problems - 10/22/2012 1:11 PM
Old Fart
Score: 158
Status: offline
Never sweat on a cheerfull post,i've got a good idea about embarrassing tho what about a you tube vid(shoulder cam of course)of our mate hairy knuckle dave riding a fatboy down his favourite stretch of straight road stark naked and a guitar strapped to his back.What movie theme music would be playing while all that went on guys
Hide Signatures
(in reply to blw)
       Post #: 10
RE: Saito 100 needle problems - 10/22/2012 4:02 PM
blw
Score: 655
Status: offline
Keep in mind that the factory setting for the low speed needle is sloppy rich. This is intended for the initial break in run on the engine.
If you have it that rich, you can watch all the smoke as you advance the throttle. If your high speed is set nearly right you can see the smoke begin to disappear near 80% throttle. This shows where the low speed stops having effect.
Coach Pat Dye
Hide Signatures
       Post #: 11
RE: Saito 100 needle problems - 10/23/2012 5:38 AM
Ernie Misner
Score: 130
Status: offline
Right on Old Fart. If you have a switch on your tx set up for engine kill / carb fully closed position, you can shut the power off on the plane while it is in that position and you shouldn't get any siphoning.
Hide Signatures
(in reply to blw)
       Post #: 12
RE: Saito 100 needle problems - 10/23/2012 6:35 AM
fredscz
Score: 102
Status: offline
While your at it change the prop as a 13x8 is way too small for a Saito 100. I agree with some of the other posters that your low end is probably too lean so after you change the prop richen up the low end and try again.
fred
Life''''s tough......It''''s even tougher if your stupid!! " J. Wayne
Hide Signatures
       Post #: 13
RE: Saito 100 needle problems - 10/23/2012 8:23 AM
w8ye
Score: 318
Status: offline
I had assumed that he was running A 3 blade 13 x 8?
Original AMA #31261
Hide Signatures
(in reply to fredscz)
       Post #: 14
RE: Saito 100 needle problems - 10/23/2012 1:15 PM
Old Fart
Score: 158
Status: offline
Yeh i assumed that too.Anything over ten on that size prop sounds good to me,don't know whether it's a wide blade or not,adam ain't far off the mark.
Hide Signatures
(in reply to w8ye)
       Post #: 15
RE: Saito 100 needle problems - 10/23/2012 5:07 PM
AdamPrime
Score: 100
Status: offline
 Yeah it is a 13x8 3 blade. I also tried a 14x9 3 blade. Seemed to struggle in flight with the 14.
Hide Signatures
       Post #: 16
RE: Saito 100 needle problems - 10/23/2012 5:28 PM
Scar
Score: 126
Status: offline
quote:
ORIGINAL: AdamPrime
My Saito 100's are happy with a 15x6.
My low speed needle wound up flush with the throttle lever face, nothing protruding past the lever. Results may vary.
Good luck,
Dave Olson
The true soldier fights not because he hates what is in front of him, but because he loves what is behind him GKChesterton
Hide Signatures
       Post #: 17
RE: Saito 100 needle problems - 10/23/2012 9:28 PM
Ernie Misner
Score: 130
Status: offline
I have a Saito 100 coming for a 3D profile plane. Will it pull a 16x4 APC Wide prop? That's the same prop my Saito 125 pulls though ... ?
Hide Signatures
(in reply to Scar)
       Post #: 18
RE: Saito 100 needle problems - 10/24/2012 1:19 AM
Scar
Score: 126
Status: offline
quote:
ORIGINAL: Ernie Misner
I think you'll find a 15X4W a better fit, after you get the engine broke in.
Just my opinion.
Dave Olson
Hide Signatures
       Post #: 19
RE: Saito 100 needle problems - 10/24/2012 1:24 AM
Ernie Misner
Score: 130
Status: offline
Yeah, that makes more sense. The wide series props can be quite a load. Thanks.
Hide Signatures
(in reply to Scar)
       Post #: 20
RE: Saito 100 needle problems - 10/28/2012 11:05 PM
AdamPrime
Score: 100
Status: offline
Ernie Misner
It looks like it is a lack of muffler pressure is causing the problem. I switched back to the stock muffler for trouble shooting purposes. It cleared up all the issues I was having. I left the needle at the positon I had set it with the scale exhaust. With proper exhaust pressure it wouldn't even run without continuous glow heat. I leaned it out to the point I had it running at 6000 rpms wot pulled off the muffler pressure and it surged to over 10,000. I guess I will have to switch to a perry pump of something to provide fuel pressure at the needle since the scale system doesn't provide enough pressure.  Thank You Everyone for your help.   Adam
Hide Signatures
       Post #: 21
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Saito 100 needle problems
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
