Gorilla Glue    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Gorilla Glue
Page: [1] 2   next >   >>
Login
Gorilla Glue - 10/22/2012 9:44 PM
hellcat56
Score: 101
Last Login: 6/19/2013
Status: offline
What will get gorilla glue off fingers????
Hide Signatures
       Post #: 1
RE: Gorilla Glue - 10/22/2012 10:03 PM
Moggy
Score: 100
Last Login: 5/27/2013
Status: offline
Try acetone
_____________________________
Piece of Cake
Spitfire Brotherhood #121
Hide Signatures
(in reply to hellcat56)
       Post #: 2
RE: Gorilla Glue - 10/22/2012 11:32 PM
invertmast
Score: 193
Status: online
Xacto knife, 80grit sandpaper
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to Moggy)
       Post #: 3
RE: Gorilla Glue - 10/22/2012 11:41 PM
R8893
Score: 100
Status: offline
laquer thinner
Hide Signatures
(in reply to invertmast)
       Post #: 4
RE: Gorilla Glue - 10/23/2012 1:29 AM
deatonbt
Score: 100
Last Login: 6/20/2013
Status: offline
Time
Bloch MV-152
Hide Signatures
       Post #: 5
RE: Gorilla Glue - 10/23/2012 1:34 AM
All Day Dan
Score: 156
Status: offline
hellcat, use those medical exam gloves next time. I never touch the stuff without those on my hands. Dan.
Dan
Hide Signatures
       Post #: 6
RE: Gorilla Glue - 10/23/2012 1:45 AM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: All Day Dan
And with those on your hands, you most certainly won't be touching the stuff.
You can get a box of something like 100 gloves at Harbor Freight for almost nothing.
Good flying wit ya today
Hide Signatures
(in reply to All Day Dan)
       Post #: 7
RE: Gorilla Glue - 10/23/2012 10:33 PM
Me410
Score: 100
Status: offline
I have done a fair bit of building over my 25 years in the hobby, but I have never used Gorilla glue.
Always use Sig Aliphatic resin or Titebond, and of course CA and 5min epoxy.
So can any of you builders out there tell me what application you use this stuff for, and why.
Hide Signatures
(in reply to da Rock)
       Post #: 8
RE: Gorilla Glue - 10/23/2012 11:17 PM
All Day Dan
Score: 156
Status: offline
ME410, I know it doesn't fly, but the Gorilla glue made it much easier. Dan.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Dan
Hide Signatures
(in reply to Me410)
       Post #: 9
RE: Gorilla Glue - 10/23/2012 11:26 PM
splinterz25
Score: 105
Last Login: 6/4/2013
Status: offline
 Gorilla glue comes off w/ mineral spirts and elbow gresse and I too never used it untill just awhile a go and it's very good for tough app's where you cant really clamp very tight but need it to never come off or need to have a gap filled because of it expanding properties you just have to be carefull not to make a real mess (YOU DON'T NEED MUCH)
Bruce
JACK OF ALL MASTER OF NONE
Hide Signatures
(in reply to Me410)
       Post #: 10
RE: Gorilla Glue - 10/24/2012 1:07 AM
deatonbt
Score: 100
Status: offline
On a balsa sheeted foam core wing where I did not do a good job of sanding the dihedral at the center, I glued the wing halfs together at the correct dihedral and let Gorilla Glue fill the gap.  I have also used it to glue an ABS radial engine front and back together where the Gorilla Glue filled the cavity in the engine; it added strength and weight.  I have not had good success with using it to glue hardwood to a fiberglass fuselage in a gas plane; the joints eventually vibrated apart.
- Brian
Bloch MV-152
Hide Signatures
(in reply to Me410)
       Post #: 11
RE: Gorilla Glue - 10/24/2012 1:34 AM
BubbasanJohn
Score: 110
Status: offline
Nice Bomb Pylon!!!!
Hide Signatures
       Post #: 12
RE: Gorilla Glue - 10/24/2012 6:28 AM
All Day Dan
Score: 156
Status: offline
Here's another use. Dan
Click for fullsize
Dan
Hide Signatures
(in reply to BubbasanJohn)
       Post #: 13
RE: Gorilla Glue - 10/24/2012 12:57 PM
nine o nine
Score: 105
Status: offline
I find that a butane torch turned up to a blue flame works well to remove the glue. Mitch
Hide Signatures
       Post #: 14
RE: Gorilla Glue - 10/24/2012 4:34 PM
OldScaleGuy
Score: 120
Status: offline
The best way i have found is not to use that stuff to begin with.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to nine o nine)
       Post #: 15
RE: Gorilla Glue - 10/24/2012 5:09 PM
raptureboy
Score: 183
Status: offline
If it is wet use mineral spirits. If it's hard then use sandpaper or solvent such as acetone,laquer thinner etc. I find it has it's place for filling in gaps and for gluing foamies back together and for attaching hinge points or nylon hinges it's great. I first coat the hinge joint in vasilene and then apply just a little water to the control surface holes and the trailing edge holes. Next take a tooth pick with a little glue, and I mean a little, and then rub it in the hole insert the hinges and line it up and let it set. In about 1/2 an hr check it again and work the hinges some, don't try to wipe off any glue that foams out yet, when it gets hard you will be able to take a #11 blade and pick the excess right off and your hinges will function just fine, and they will not pull loose, even in a crash. Don't ask
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 16
RE: Gorilla Glue - 10/24/2012 5:29 PM
Lifer
Score: 153
Status: offline
Plus 1 on raptureboy's comments. It's the best glue have found for hingepoints. Most solvents will remove it when still wet.
Hide Signatures
(in reply to raptureboy)
       Post #: 17
RE: Gorilla Glue - 10/24/2012 5:36 PM
Me410
Score: 100
Status: offline
Interesting stuff, I may give it a try, thanks for the info.
Deatonbt:
For any wood to fiberglass I use a glue by PermaPoxy called  5 Min Plastic Weld. The key ingrediant is " Methyl Methacrylate "  I think.  It's stinky stuff and you don't want it on your skin I would think.
But it works great, and you can use it for plastic to wood, plastic to plastic also.
Tom
Hide Signatures
       Post #: 18
RE: Gorilla Glue - 10/24/2012 6:22 PM
airega1
Score: 108
Last Login: 6/14/2013
Status: offline
quote:
ORIGINAL: raptureboy
Man Please, all that work for installing hinge points? use 5, 15 or 30 min epoxy, let it cure and even if it gets to the hinge joint you can snap it free, 30 years of installing hinge points always with epoxy and never a failure. Gorilla glue, dampen the surface, apply, watch for foam, pick it away, what a joke!
Man! that thing does not like Dwayne!
Hide Signatures
       Post #: 19
RE: Gorilla Glue - 10/24/2012 6:37 PM
KaP2011
Score: 115
Status: offline
quote:
ORIGINAL: hellcat56
Banana Peel?
KaP2011
AMA #408493
Hide Signatures
       Post #: 20
RE: Gorilla Glue - 10/24/2012 7:30 PM
raptureboy
Score: 183
Status: offline
Takes no more time and I don't have to hurry up because the epoxy is setting up on me while I'm trying to line up the hinges, and just so you know epoxy will not stick to nylon hinges very long wise guy! Thats why I mix it on plastic container lids and use nylon spatulas, just flex it and it pops right off. If you've got nothing good to say then keep it to yourself Really why do guys like you have to get in a thread and try to make yourself and your ideas sound so superior.
Hide Signatures
(in reply to airega1)
       Post #: 21
RE: Gorilla Glue - 10/24/2012 8:46 PM
joebahl
Score: 132
Status: offline
He was stating his opinion about using the stuff and or how he does things,i use it and i think its only good for foam and it is very messy . It;s getting to the point around here if you dont agree with some folks start telling you to shut up. I listened to what he had to say ,wether i agree with him or not and that was it .Every one has a different way of building things and mine is not the ONLY WAY. joe
Hide Signatures
       Post #: 22
RE: Gorilla Glue - 10/24/2012 8:57 PM
MTK
Score: 203
Status: offline
Yeah I thot the same thing....Why poo-poo any glue? They all have their strengths and if one builds at all, he will learn which glue is best for the application at hand. Hinge points and Gorilla are well matched. Roughened hinge points and epoxy or slow ca also work well together. No biggie either way
To the OP, +1 for the gloves. Anytime a job is going to get messy, I opt for the gloves too. But once I get GG on my hands and it turns black from grime, I sand it off the skin. I try hard not to get too much solvent on my bare hands. Skin absorbs solvents
Regards,
MattK
Hide Signatures
       Post #: 23
RE: Gorilla Glue - 10/24/2012 9:09 PM
TestPilot-101
Score: 100
Status: offline
http://www.gorillatough.com/index.php?page=aid-glue
Hide Signatures
       Post #: 24
RE: Gorilla Glue - 10/24/2012 9:19 PM
3136
Score: 135
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: airega1
If it is wet use mineral spirits. If it's hard then use sandpaperwww.rcuniverse.com="" src="" /> or solvent such as acetone,laquer thinner etc. I find it has it's place for filling in gaps and for gluing foamies back together and for attaching hinge points or nylon hinges it's great. I first coat the hinge joint in vasilene and then apply just a little water to the control surface holes and the trailing edge holes. Next take a tooth pick with a little glue, and I mean a little, and then rub it in the hole insert the hinges and line it up and let it set. In about 1/2 an hr check it again and work the hinges some, don't try to wipe off any glue that foams out yet, when it gets hard you will be able to take a #11 blade and pick the excess right off and your hinges will function just fine, and they will not pull loose, even in a crash. Don't askwww.rcuniverse.com="" src="" />
Ha ha, if you can snap the excess free from the joint how much of a bond do you think it is making inside the control surface?
I use GG on hinges. Rapture explained it in great detail but it doesn't take long to do at all.
regards Mark
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
