Mach1 question before upcoming build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> Mach1 question before upcoming build
Page: [1]
Login
Mach1 question before upcoming build - 10/23/2012 5:03 AM
pilotx
Score: 101
Last Login: 5/23/2013
Status: offline
hello to all I am about to start building the Mach 1. I have purchased a short kit and foam cores from Eureka Aircraft and the plans from MAN(I think) anyways i also have a Midwest products plan for the same Mach1, after recieving my order from National balsa all the wood is here to begin. I have been looking over both plans and i find the the Eurekc plan(MAN) is Longer in length when macthing up the fuse sides from the wing to tail in about 1" longer than shown on the Midwest plan. is it better to be longer here or shorter? i can change it to match the Midwest plan or proceed with the Eureka/MAN plan.
this is my first Pattern plane and I love the look of most of the pattern planes..
any help would be great
thanks in advance..
< Message edited by pilotx -- 10/23/2012 7:57 PM >
_____________________________
-Tracey aka Pilotx
CORSAIR Brotherhood # 62
Hide Signatures
       Post #: 1
RE: Mach1 question before upcoming build - 10/23/2012 5:34 AM
Roguedog
Score: 105
Last Login: 5/25/2013
Status: online
pilotx,
I would say longer woud be better.
Hide Signatures
(in reply to pilotx)
       Post #: 2
RE: Mach1 question before upcoming build - 10/23/2012 7:29 AM
stuntflyr
Score: 137
Status: online
Longer is better.
Chris...
Hide Signatures
(in reply to Roguedog)
       Post #: 3
RE: Mach1 question before upcoming build - 10/23/2012 7:49 AM
RonMcCormick
Score: 100
Status: offline
Remember moving every thing 1" back will move the CG a lot. consider the weight of your engine and pipe or not. Not very much room for moving stuff around on the M1. The plane flew great the way Norm designed it. Talk to people who made it 1" longer see what problems they had with CG if any. You don't want to add dead weight to get the balance. M1 flies great when weight is controlled. Just my opinion, you will have fun building and flying this Classic.
Ron McCormick
AMA 53109, CPA 6, NSRCA 726
Hide Signatures
(in reply to stuntflyr)
       Post #: 4
RE: Mach1 question before upcoming build - 10/23/2012 12:20 PM
AllTheGoodNamesAreTaken
Score: 118
Status: offline
The original RCM plan is longer. Midwest shortened it. They also changed the construction technique from a basic box fuse, to a laminated lumber yard.
Don''t just stand there, go get some glue!
Hide Signatures
(in reply to RonMcCormick)
       Post #: 5
RE: Mach1 question before upcoming build - 10/23/2012 7:03 PM
pilotx
Score: 101
Status: offline
So if I get this right, the MAN original plan is the desired and correct way to build this plane, and the Midwest shorter version was done to kit the plane.
So I will build as per original plan? I did notice the block by block laminating process that is the Midwest Products plan, to me seems the sure way to build HEAVY and I dont want that...
< Message edited by pilotx -- 10/23/2012 7:58 PM >
-Tracey aka Pilotx
Hide Signatures
(in reply to AllTheGoodNamesAreTaken)
       Post #: 6
RE: Mach1 question before upcoming build - 10/23/2012 7:10 PM
RFJ
Score: 109
Last Login: 5/24/2013
Status: offline
quote:
the RCM original plan
That would be MAN. Published in the June 1973 issue.
Ray
Hide Signatures
       Post #: 7
RE: Mach1 question before upcoming build - 10/23/2012 7:33 PM
pilotx
Score: 101
Status: offline
RFJ: yes this plan and the original build article from Model Aviation News. and I am comparing to Midwest Products plan.. the MAN plan is correct to the part's from Eureka Short Kit
-Tracey aka Pilotx
Hide Signatures
(in reply to RFJ)
       Post #: 8
RE: Mach1 question before upcoming build - 10/23/2012 8:58 PM
burtona
Score: 100
Status: offline
Kit manufacturers often make changes to accomodate the box sizes they can get or have on hand. J & J pattern plane kits being a notable example.
Hide Signatures
       Post #: 9
RE: Mach1 question before upcoming build - 10/23/2012 10:29 PM
pilotx
Score: 101
Status: offline
OK guys, after looking at these plans closer I have found that the(Midwest Products Co.) plans are 3/8inches shorter over all and looking at the wing, it is moved 3/8inches Aft, the C.G. is also moved although it is moved forward 3/8inches.
Question is how does this change the plane, did Midwest improve it or do the MAN plans offer a better plane, or no difference at all?
Sorry for asking all the questions. I just don't want to start off one way then find out that I had a chance to correct it.
Oh one more thing what glue to use to skin the wings and stab? A fellow builder friend suggested 3M Super77?
-Tracey aka Pilotx
Hide Signatures
(in reply to burtona)
       Post #: 10
RE: Mach1 question before upcoming build - 10/23/2012 10:54 PM
hrrcflyer
Score: 121
Status: offline
Hey Pilotx,
Will you be doing a build thread on your Mach 1? I don't remember seeing one here on RCUniverse since I've been a subscriber.
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
       Post #: 11
RE: Mach1 question before upcoming build - 10/23/2012 11:45 PM
pilotx
Score: 101
Status: offline
Not sure yet but will definitely think it over I'm not sure how committed I will be to keeping it up to date. I hope to have this close to glassing before Christmas. we'll see
I also have a Mustang to put the finish on. both of which I want to have complete by spring flying season 2013.
< Message edited by pilotx -- 10/24/2012 4:20 AM >
-Tracey aka Pilotx
Hide Signatures
(in reply to hrrcflyer)
       Post #: 12
RE: Mach1 question before upcoming build - 10/24/2012 1:13 AM
PatternPilot
Score: 125
Status: offline
Needs to be the old formula of 3M Super 77 or it will eat the foam.. I usually get a case from Canada and split it with a few other builders.
cpa#2
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
       Post #: 13
RE: Mach1 question before upcoming build - 10/24/2012 1:40 AM
5skyhawk172
Score: 121
Status: offline
Brings back a lot of memories.  Built the Midwest kit back in '75.  Super Tiger blue head 60.  Pro Line radio . Goldburg retracts.  Also built a Mach 8 40 size version.
Hide Signatures
(in reply to PatternPilot)
       Post #: 14
RE: Mach1 question before upcoming build - 10/24/2012 1:50 AM
THERCAV8R
Score: 105
Last Login: 5/21/2013
Status: offline
Hi, The midwest kit/plan is a very different than the plane Norm Page designed. The plans from MAN are much closer to the model Norn Page won the Masters with than the kit even though the completed model looks the same. I have a set of plans directly from Norm. One of the differences that you have not seen is the real Mach 1 has a foam core Fin that the airfoil is thicker on the right side than the left to counter act the torq so the plane tracks stright. The other differences you have noted. The wing is also very different on the plans built model than the kit.
Hide Signatures
       Post #: 15
RE: Mach1 question before upcoming build - 10/24/2012 1:53 AM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: hrrcflyer
Hey Pilotx,
David
David,
Leo has an M1 build thread along with his Sequel thread. Both models remain to be finished according to the latest news (I was in touch with Leo recently). Here's his M1 thread:
http://www.rcuniverse.com/forum/m_8532968/tm.htm
David
Hide Signatures
       Post #: 16
RE: Mach1 question before upcoming build - 10/24/2012 10:36 AM
drac1
Score: 100
Last Login: 5/20/2013
Status: offline
Definitely MAN plans. Longer is better for a pattern ship. It wouldn't hurt to move the wing back slightly if it looks like it will be a bit tail heavy.
I used Bolly laminating resin for years, but I think it is no longer available. I now use Z Poxy finishing resin, which works well.
There is no such thing as too much power.
Hide Signatures
(in reply to doxilia)
       Post #: 17
RE: Mach1 question before upcoming build - 10/24/2012 3:59 PM
Quikturn
Score: 118
Status: offline
I have a Midwest Mach 1 kit with a partially built fuselage. I got a chuckle out of it being a flying lumber yard. It is a complex looking fuselage build but hopefully it won't be too heavy when all said and done. I think a lot of it gets sanded away to achieve the rounded contours. I don't think they were very concerned with weight back then. Classic pattern ships fly fast.
Good luck on your build. Pictures would be appreciated.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
(in reply to drac1)
       Post #: 18
RE: Mach1 question before upcoming build - 10/24/2012 5:20 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: pilotx
The few of us left who still build our stuff prefer either epoxy or Pro-Bond/Gorilla PU glue. Bonding is permanent with either one of these. For the small wing of vintage models, it won't take more than 1/2 oz each panel. The epoxy or polyurethane glue is applied sparringly to the sheeting. I prefer epoxy since it gives much greater working time before kicking off. But I never use the stuff you get at the LHS.
Go to US Composite site and buy their laminating epoxy. It's inexpensive and works well with about a 50 min pot life. Pro Bond or Gorilla begins to kick off in about 25 mins so you'd have to work faster
I used the 3M product only once and wasn't pleased when too much of the skin lifted after a few dozen flights. Probably didn't use enough spray. Spray makes it an easy application but you'd have to spray enough of it to work right.
Before applying any adhesive to either sheeting of foam, use a tack rag to remove dust residue.....Good luck
Regards,
MattK
Hide Signatures
       Post #: 19
RE: Mach1 question before upcoming build - 10/24/2012 6:10 PM
countilaw
Score: 219
Status: offline
Epoxy is better than  contact cement because you can move the sheeting around to get it placed right.     With contact cement,  you  get one chance to lay it down and get it right.     However, if you like  Contact Cement,   Home Depot has a water based contact cement in quart cans.   It works extremely well.  It is white,so if you use it,   put some food coloring in it so you can see how much you are applying to the white foam core.
There used to be a product out called,    "Southern Sorgham"   it was great stuff.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to MTK)
       Post #: 20
RE: Mach1 question before upcoming build - 10/24/2012 6:13 PM
Bax
Score: 169
Status: offline
A well-built, ready-to-fly Mach I will weigh just about 8 pounds. That includes a .61-size engine, muffler, and retracts. They fly very well at that weight. Of course, a bit lighter might be better, but heavier is not.
Get yourself the very small Stanley block plane. It's about 1" wide and 3" long. This will be used to contour the fuselage to the point it's looking nice and round. Smooth it with sandpaper. Start with 120-grit and continue to 220, 320, and maybe to 400 before you paint or cover. The smoother the balsa, the better the final finish. You won't need to go much finer than 320 or 400 for the sandpaper.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to MTK)
       Post #: 21
RE: Mach1 question before upcoming build - 10/24/2012 6:47 PM
Quikturn
Score: 118
Status: offline
Good to know Bax. Thanks!
Hide Signatures
(in reply to Bax)
       Post #: 22
RE: Mach1 question before upcoming build - 10/24/2012 9:42 PM
MTK
Score: 203
Status: offline
Bax,
The OS33GT you fixed for me early this year has worked incredibly well. I have about 11 gallons of avgas through it now, some 60 hours of operation.
Some kind of engine. Stronger than a YS 175, turning the same props at higher revs
Thank you!!
Regards,
MattK
Hide Signatures
(in reply to Bax)
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
