kool power and after run oil    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> kool power and after run oil
Page: [1] 2 3 4 5   next >   >>
Login
kool power and after run oil - 10/25/2012 12:59 AM
sweatybetty
Score: 100
Last Login: 5/19/2013
Status: offline
i use kool power fuel and the jug says that no after run oil is needed for storage. i understand that after run oil wont hurt, but will the kool power work do the same?
thanks all    sb
Hide Signatures
       Post #: 1
RE: kool power and after run oil - 10/25/2012 1:40 AM
JPMacG
Score: 123
Last Login: 5/16/2013
Status: offline
I don't think you will get an answer to that question. There are just too many variables. You will find some who say they have rusted using Coolpower and some who say they have not.
To be safe I would use after run oil, or switch to a fuel with some castor oil content, or even better, both.
< Message edited by JPMacG -- 10/25/2012 2:58 AM >
Hide Signatures
(in reply to sweatybetty)
       Post #: 2
RE: kool power and after run oil - 10/25/2012 2:08 AM
SrTelemaster150
Score: 229
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: sweatybetty
thanks all    sb
I run Cool Power in Saito 4-stroke engines & do not use after run oil throughoiut the flying season.
I do inject ATF into the case as well as the valve ports & turn the engine over to distributel the oil @ the end of the flying season or whenever I expect to store the engine for an extended period.
In a 2-stroke, where raw fuel is drawn into the bottom end, I would use an ARO regardless of the fuel used.
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 3
RE: kool power and after run oil - 10/25/2012 2:10 AM
1320Fastback
Score: 126
Status: offline
Ditto above except mine are 2 Strokes.
During season no ARO, when planes get stored I then add ARO.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 4
RE: kool power and after run oil - 10/25/2012 2:47 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Please use a generous amount of after run oil if your engine will be sitting for a while (like over a week maybe, whatever you are comfortable with). Your bearings will thank you. I just today had to replace rusted bearings in a customers truck and he had clearly been using full synthetic with no ARO. However with no castor it made the cylinder come out very easily.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to 1320Fastback)
       Post #: 5
RE: kool power and after run oil - 10/25/2012 3:45 AM
1QwkSport2.5r
Score: 155
Status: offline
+1 on ARO when using full-synthetic fuels like Cruel Power. The Polyalkylene Glycol oils absorb moisture, and they tend not to stick to metal for very long when not in use. This stuff breaks down long before Castor will.
My ARO brew is 95% ATF Dexron III or IV, and 5% Seafoam motor treatment. Works great for removing crusty carbon inside the engine, and keeps the piston ring from sticking.
I dont put ARO in my engines unless they are going to sit longer than a month. I use little to no nitro, so I rarely worry about 3-4 weeks sitting idle without doing anything on an engine.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to jeffie8696)
       Post #: 6
RE: kool power and after run oil - 10/25/2012 3:58 AM
sweatybetty
Score: 100
Status: offline
thank you all!
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 7
RE: kool power and after run oil - 10/25/2012 3:27 PM  1 votes
Sport_Pilot
Score: 233
Status: offline
Do not use after run oil immediately after flying, unless you are using an oil that will mix with methanol, such as castor or synthetic oil.  Other oils will not mix with the fuel remaining, and any moisture in the fuel will be trapped between the after run oil and the metal surface.  This would only accelerate any corrossion.   Burn off the fuel and wait several hours with the piction at bottom dead center to allow the fuel to evaporate before adding the after run oil.  Otherwise you would be best to follow Morgan Fuels advise.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 8
RE: kool power and after run oil - 10/25/2012 6:16 PM
tiffitech
Score: 110
Status: offline
I think leaving 4-strokes w/o ARO is more dangerous as on 2-strokers.
The Oil in the crankcase is only blow by there, saturated will all kind of ugly
combustion products like nitric acid. No one needs this stuff there...
Bought this for cheap on ebay, is ok now...
Regards,
Holm
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 9
RE: kool power and after run oil - 10/25/2012 6:22 PM
kenh3497
Score: 115
Status: offline
I have a "new" Super Tiger 61 with 5 tanks of fuel through it. I crashed the plane it was on. I was burning 15% Cool Power Heli fuel. I was not able to get to the engine for two weeks after the crash. The bearings were rusted and need replacement In fact the rear bearing was frozen it was so bad. Now bearing quality could have had something to do with this also?????
Ken
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to tiffitech)
       Post #: 10
RE: kool power and after run oil - 10/25/2012 6:31 PM
tiffitech
Score: 110
Status: offline
Bearing quality? It is more a question if you have stainless steel bearings or not. IMHO the stainless steel is
to soft to last, but it wouldn't rust that easyly.
Regards,
Holm
Hide Signatures
(in reply to kenh3497)
       Post #: 11
RE: kool power and after run oil - 10/25/2012 7:01 PM
Propworn
Score: 188
Status: online
At the end of the day after you have drained all the fuel from the tank reconnect the glo driver and with the throttle at idle spin the motor over until there is no more bark that way you have run all the fuel out of the engine. Left over fuel in the engine is the biggest cause of rust as you know it attracts moisture. A little bit of after run oil down the carb for 2 strokes and a bit in a syringe into the crankcase vent and a quick flip by hand is all that is needed. Be careful if you intend to spin your engine with an electric starter that you do not use too much after run oil you don’t want to cause a hydraulic lock. Lots of stuff out there sold as after run oil or home made concoctions. Personally I don't like to put anything into my engines that normally isn't intended to be used in an engine. I use Klotz Technoplate pure synthetic I purchased at the hobby shop. It mixes with both nitro fuels and gas and a $7 bottle will last a heck of a long time as after run oil.
Dennis
Hide Signatures
       Post #: 12
RE: kool power and after run oil - 10/25/2012 9:34 PM
Sport_Pilot
Score: 233
Status: offline
Nitric acid is not really a problem, but yes four strokes are a challange.  I should say also you don't need to wait long for the afterrun oil on a four stroke.  I suspect that that one was from a plane that crashed into a lake or pond.  The only engine that was near that bad had crashed into a pond, and underwater a few days before they fished it out.  And it wasn't as bad as the example you showed!
Hide Signatures
       Post #: 13
RE: kool power and after run oil - 10/25/2012 9:38 PM
Sport_Pilot
Score: 233
Status: offline
throttle at idle
And then spin it again.  Just because the engine won't run doesn't mean there isn't any alcohol in the engine.  Then wait a few hours for the rest of the fuel to evaporate.
One quick flip will not spread the oil around, use the starter and spin it up again.
Hide Signatures
(in reply to Propworn)
       Post #: 14
RE: kool power and after run oil - 10/25/2012 9:52 PM
RC-Bearings
Score: 105
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: tiffitech
Regards,
Holm
The stainless alloy used in bearings, 440C, is hardened to the same range as AISI bearing steel, about 59-62 Rockewll C. Stainless steel bearings will last just as long if properly taken care of, and a LOT longer if you use a rust prone fuel or are in a humid environment.
Steel and Ceramic bearings for model engines
5% discount for RCU members. Code: rcu
Hide Signatures
       Post #: 15
RE: kool power and after run oil - 10/25/2012 9:56 PM
RC-Bearings
Score: 105
Status: offline
Most of the complaints I see from rusting heli bearings comes from Cool Power users. Stainless steel bearings will take care of this in 99% of the cases. As far as ARO goes, you need to use something that is DESIGNED fro that purpose. The best stuff I have seen yet is just about any brand of air tool oil. It us used to keep moisture away from metallic parts.
Hide Signatures
       Post #: 16
RE: kool power and after run oil - 10/25/2012 10:04 PM
rgburrill
Score: 126
Status: offline
I used air tool oil (KMart brand) for years after every weekend of flying.  I had engines sit for several years and still had no problem.  I would, as suggested above, run the engine dry of fuel with the electric starter before using the air tool oil, though.
Hide Signatures
(in reply to RC-Bearings)
       Post #: 17
RE: kool power and after run oil - 10/26/2012 8:32 AM
tiffitech
Score: 110
Status: offline
An Engine wouldn't get much better if it is fitted with stainless bearings and a normal crankshaft or gears like the enya above.
The parts shouldn't rust at all, bearings are only one part of the engine. So since you must take care of what happens to the rest of the engine I see no reel need for stainless bearings.
I run my engines with castor and don't have such problems at all, but I've oiling up the Enginges after run wit a stuff that is called Ballistol and that is available here in Germany.
It is called weapon oil here too and is a thinnish white oil. I prevents the engines from getting stuck from the castor and the engine parts for oxidation.
The seller of the enya above was the son from of a passed modeller and sold the stuff he found in the basement.
He say'd this engine was laying there for years. No one knows what really happened to it.
I've bought this motor for 60 Euros and got 50 back after sending the pictures to the seller.
This was three or four years before..
You should read the Ballistol-Story on their website (trough google translator?) , it was made for the Army of the german Kaiser in 1904 and is
made until today..
Regards,
Holm
Hide Signatures
       Post #: 18
RE: kool power and after run oil - 10/26/2012 2:49 PM
ArcticCatRider
Score: 115
Last Login: 10/26/2012
Status: offline
I am a big fan of after run oil, and just use ATF. After flying, I run the engine out of fuel, spin it a few times with the igniter attached, and repeat over the course of a few mintues.
Then, I rotate the crank to close the port, and fill the whole carb throat with oil. I turn the crank to drain it, and repeat about halfway. Then I tilt the plane (or car) so the crank is tilted up and the oil all runs to the bottom back of the motor. I wait a minute for this to happen...then tilt it forward. Wait a minute...then start rotating the prop as the oil fill in the front bearings. Finally I flip the prop a few dozen times.
I don't ever use a starter on the motor after loading it up with ARO. Also, on my first start of the day I use a chicken stick to start the motor to prevent any damage from hydro lock.
The method is a little time consuming, but does a good job thoroughly loading up the bottom of the motor with oil
Club Saito Member #657
Carl Goldberg Ultimate 10-300 Brotherhood #52
Hide Signatures
       Post #: 19
RE: kool power and after run oil - 10/26/2012 4:46 PM
jeffie8696
Score: 120
Status: offline
I have had good luck with synthetic motor oil like Mobil1. I know from experience and research that it has acid neutralizers and it is clingy as hell. I flush out the engine with fresh fuel and it starts right up. I have like 60 engines so a lot of them tend to sit around a long time before getting a turn on the front of one of my planes.
My Escapade has had (so far) an Irvine 36,46,53, OS46SF and currently has a Magnum 52FS. I was planning to install my Saito 62 but on inspection of the airframe I think I should replace it, its getting really beat up after all the flying it has done.
Hide Signatures
(in reply to ArcticCatRider)
       Post #: 20
RE: kool power and after run oil - 10/26/2012 5:04 PM
RC-Bearings
Score: 105
Status: offline
The difference in NORMAL operation is that it is very difficult to cause rust on the hardened gears and crank in an engine. That engine looked like it was filled with water for a long time and the residual oil emulsified. Under NORMAL conditions, the hardened steel parts wouldn't rust but the bearings certainly would. The forums are full of pictures of spotlessly clean interiors with rusted bearings. Stainless steel bearings would prevent 99% of those failures.
quote:
ORIGINAL: tiffitech
made until today..
Regards,
Holm
Hide Signatures
       Post #: 21
RE: kool power and after run oil - 10/27/2012 2:13 AM
Ernie Misner
Score: 130
Last Login: 5/20/2013
Status: offline
Has anyone besides me had trouble with ARO's in OS engines? It seems to swell up their silicone? based O-rings and the needle valve becomes very hard to turn.
Hide Signatures
       Post #: 22
RE: kool power and after run oil - 10/27/2012 2:29 AM
Propworn
Score: 188
Status: online
quote:
ORIGINAL: Ernie Misner
Most ARO are petroleum base and don't react well with silicone. YS engines recommend only synthetic oils that is why I only use the Klotz Techniplate pure synthetic as ARO.
http://klotzlube.com/techsheet.asp?ID=54
Hide Signatures
(in reply to Ernie Misner)
       Post #: 23
RE: kool power and after run oil - 10/27/2012 2:37 AM
flyinwalenda
Score: 157
Status: online
I put oil in regardless of the type of fuel used. I oil them up after  the day is over and I fill them up for storage. I would never take a chance not using it. .
I use Marvel Mystery Air Tool Oil.
Brian Ray
Hide Signatures
       Post #: 24
RE: kool power and after run oil - 10/27/2012 2:39 AM
Ernie Misner
Score: 130
Status: offline
Interesting that Klotz oil mixes with gasoline or methanol. They say the red color gives it a racey smell? Unlike castor oil I assume. It doesn't say a word about rust inhibitors though.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> kool power and after run oil
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
