the Wasp
VT, USA Status: offline
yes mine has a 73 inch span and it had a G38 in it,, well people tell me it was to heavy but I'm not sure, it must have weighed around 15 (1/2 ??) pounds, but I didn't think it was to much because you see many War Birds in the 80 inch size that weigh in the 22/24 pound range,, in the air if the right wing dropped a bit the plane would want to fall to the right, if the left wing dropped a bit the plane would want to fall to the left, it was better at full throttle but not much, and he a head wind and the nose wanted to go up, it just didn't track well as a plane should,, it had good Elevator and good Aileron,, once I fix the wing I will get a much lighter engine, I think I can loose a good 30oz with an OS 160 or MVVS 160.. Jim
