How Do I Gear My Traxxas Slash 2wd Brushed?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> How Do I Gear My Traxxas Slash 2wd Brushed?
Page: [1]
Login
How Do I Gear My Traxxas Slash 2wd Brushed? - 10/26/2012 9:25 PM
-JBLKING-
Score: 100
Last Login: 5/23/2013
Status: offline
 I have a stock Traxxas Raptor 2wd Brushed, basically a slash platform, and would like to know what the stock gearing it is in right out of the factory. I am a novice and would like some help learning how to match up pinion and spurs for the desired result. Currently i am curious as to what setup i can use to improve my acceleration as i think that is lacking at the moment. Any input is appreciated, Thank you!
_____________________________
-JBLKING-
Hide Signatures
       Post #: 1
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/28/2012 7:53 PM
john01374
Score: 158
Last Login: 5/22/2013
Status: offline
Improving acceleration means lowering the gearing. The easiest way to do this is to drop one or two teeth on the pinion gear. Know that this WILL affect top speed. You will lose couple of MPH on the top end but the truck will take off much harder. Gearing is always a compromise Give up a little acceleration for more top end or loose a little top end to gain more power down low.
Hide Signatures
(in reply to -JBLKING-)
       Post #: 2
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/29/2012 1:22 AM
-JBLKING-
Score: 100
Status: offline
ok, i pretty much get the jist, thanks. but is the spur important in terms of adjusting performance?
-JBLKING-
Hide Signatures
(in reply to john01374)
       Post #: 3
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/29/2012 5:16 AM
phmaximus
Score: 627
Last Login: 5/25/2013
Status: offline
just wondering, what do u mean by lacking acceleration. what are u comparing it to?
does it have wheel spin?
I found 60g of weights under the ESC helped mine get the power down
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
       Post #: 4
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/29/2012 2:56 PM
-JBLKING-
Score: 100
Status: offline
When i mean lacking, i mean the current acceleration is not satisfying my taste hahaha. There is a moderate ammount of wheel spin, but i will address that with better tires and stiffer shocks. Any advice is appreciated, thanks!
-JBLKING-
Hide Signatures
(in reply to phmaximus)
       Post #: 5
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/29/2012 10:35 PM
phmaximus
Score: 627
Status: offline
U should of mentioned that before. Its not going to accelerate very fast while getting wheel spin
If u lower the gearing its going to be worse.
try throttle controll, m8
< Message edited by phmaximus -- 10/31/2012 11:49 AM >
Hide Signatures
       Post #: 6
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/31/2012 11:27 AM
john01374
Score: 158
Status: offline
quote:
ORIGINAL: -JBLKING-
JB - Lowering the gearing will increase the acceleration IF the truck has traction. To gain more traction you'll need to soften the rear suspension a bit to make it hook up and go. Softer tires will help in this area as well as you have already mentioned.
Hide Signatures
       Post #: 7
RE: How Do I Gear My Traxxas Slash 2wd Brushed? - 10/31/2012 12:14 PM
-JBLKING-
Score: 100
Status: offline
Ahh i did not know that. Id like to soften up the suspension to get more traction, but im also afraid of bottoming out too much.
-JBLKING-
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
