Removing Cooked on Varnish from an engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Removing Cooked on Varnish from an engine
Page: [1] 2   next >   >>
Login
Removing Cooked on Varnish from an engine - 10/28/2012 2:28 AM
poorbs
Score: 100
Last Login: 1/22/2013
Status: offline
I have a very nice engine that has some varnish cooked onto the head, and wonder what the best way is to remove it without damaging the fins. A very long time ago, I remember helping a friend clean up one of his engines, and the stuff we used was really foul smelling. Any suggestions? Thanks
Hide Signatures
       Post #: 1
RE: Removing Cooked on Varnish from an engine - 10/28/2012 3:15 AM
jeffie8696
Score: 120
Last Login: 6/18/2013
Status: offline
A product for cleaning dishes called Dawn Power Dissolver
_____________________________
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to poorbs)
       Post #: 2
RE: Removing Cooked on Varnish from an engine - 10/28/2012 3:16 AM
earlwb
Score: 599
Last Login: 6/19/2013
Status: offline
I like to use Dawn Power Dissolver to remove the cooked on varnish from the glow engines. The stuff works pretty good. You can scrub it with a old toothbrush too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 3
RE: Removing Cooked on Varnish from an engine - 10/28/2012 3:22 AM
Campgems
Score: 143
Status: offline
+3
It comes in a blue squeez spray and you may find it with the oven cleaners, or with the dish soap.  Not all stores handle it.  I think I found mine at the Ace Hardware store.
Wear rubber gloves, it will raise hell with your skin.  It may take a couple applications, but it does a very good job of getting the baked on castor off the engine.  Follow the instructions on the bottle.
Don
Hide Signatures
(in reply to earlwb)
       Post #: 4
RE: Removing Cooked on Varnish from an engine - 10/28/2012 3:25 AM
jeffie8696
Score: 120
Status: offline
If you leave it on too long it tries to melt your engine.
Hide Signatures
(in reply to Campgems)
       Post #: 5
RE: Removing Cooked on Varnish from an engine - 10/28/2012 3:37 AM
blw
Score: 655
Status: online
Trying it on a spot for a few minutes to check for discoloring is a good idea. I know that I've forgotten about it on a Saito for 45 minutes without problems. It's god stuff.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to jeffie8696)
       Post #: 6
RE: Removing Cooked on Varnish from an engine - 10/28/2012 6:47 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
If you're not in a hurry the ol' crock pot and antifreeze might work better over night?
Hide Signatures
(in reply to blw)
       Post #: 7
RE: Removing Cooked on Varnish from an engine - 10/28/2012 10:32 AM
PWF63
Score: 100
Status: offline
I've found that using a small jewellers  ultra sonic bath works well using warm water
and a splash of grease remover in the water.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 8
RE: Removing Cooked on Varnish from an engine - 10/28/2012 10:43 AM
Old Fart
Score: 158
Status: offline
I like that baked on bronze colour they take
Watch out for the ground eh?
Hide Signatures
(in reply to PWF63)
       Post #: 9
RE: Removing Cooked on Varnish from an engine - 10/29/2012 1:24 AM
countilaw
Score: 229
Status: offline
quote:
ORIGINAL: Ernie Misner
This method does work,   BUT,   if you leave it in the pot too long,   the  Ethylene Glycol will turn the  metal  grey and  any polished parts such as the head will  loose that shiny look.
Dawn Power Cleaner will do the same thing if left on too long.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 10
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:19 AM
w8ye
Score: 318
Status: offline
I have a beautiful gun metal gray OS 61 four stroke out in the garage. The owner had boiled it in automatic dishwasher soap.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to countilaw)
       Post #: 11
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:31 AM
blw
Score: 655
Status: online
Those ultra sonic cleaners work great. I got all of the burned castor tar off of a muffler with mine. I used some dishwashing liquid in the water.
Yeah, I also like that burned look too, OF.
I once needed to wash my hands after doing something on my truck. Couldn't think of anything good, so I used that gritty, powdered dishwasher soap. My hands were so dried out that I had to use hand lotion every half hour for weeks.
Coach Pat Dye
Hide Signatures
(in reply to w8ye)
       Post #: 12
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:41 AM
croatiablu
Score: 125
Last Login: 6/14/2013
Status: offline
Get yourself a cheap crock pot.  Fill it with enough Antifreeze to cover your parts in the bottom.  Use the older conventional antifreeze NOT 50/50.  You may want to make a strainer because the stuff gets incredibly hot.  Put your parts (not rubber) into the mix and let it stew for a couple of days.  You will have brand new looking motor parts when done. I have done entire motor blocks this way.  The parts come out looking like they are brand new.
CB
quote:
ORIGINAL: poorbs
Hide Signatures
       Post #: 13
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:45 AM
PLANE JIM
Score: 171
Last Login: 5/31/2013
Status: offline
Hobby King has a real nice Ultrasonic cleaner for less than $25-it works well -cleans without harsh chemicals and does not dry your skin out -easy to store as well and cleans other items as well besides model engines.
"IF YOU HAVE TOO MANY AIRPLANES -FLY BOLDLY AND REDUCE YOUR NUMBER"
Hide Signatures
       Post #: 14
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:48 AM
blw
Score: 655
Status: online
Amazon is a good place to compare and check the reviews.
Coach Pat Dye
Hide Signatures
(in reply to PLANE JIM)
       Post #: 15
RE: Removing Cooked on Varnish from an engine - 10/29/2012 2:54 AM
KaP2011
Score: 115
Status: offline
quote:
ORIGINAL: countilaw
Frank
I can vouch for that statement. I've found that 4 to 6 hrs works for most varnish. If you have a small brass wire brush you can speed the process to just a couple of hours for most engines.
KaP2011
AMA #408493
Hide Signatures
       Post #: 16
RE: Removing Cooked on Varnish from an engine - 10/29/2012 3:53 AM
w8ye
Score: 318
Status: offline
You cannot boil the antifreeze and the parts must be completely submerged at all times or you will get graying.
Original AMA #31261
Hide Signatures
(in reply to KaP2011)
       Post #: 17
RE: Removing Cooked on Varnish from an engine - 10/29/2012 4:55 AM
countilaw
Score: 229
Status: offline
Harbor Freight  carries a  sonic cleaner that is  cheap but well made.   You can order on line or go pick one up and use it that day.    Works good on cleaning old jewelry too.
Frank
Hide Signatures
(in reply to w8ye)
       Post #: 18
RE: Removing Cooked on Varnish from an engine - 10/29/2012 5:27 AM
Ernie Misner
Score: 130
Status: offline
How does an ultrasonic cleaner work?
Hide Signatures
       Post #: 19
RE: Removing Cooked on Varnish from an engine - 10/29/2012 5:32 AM
oldtyme
Score: 158
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: poorbs
A friend of mine put me onto a product named TAL-STRIP. You can get it in a lot of auto parts stores although it is most used in the aviation industry. It is called a "coating remover". My friend used it to clean up a well used OS91 4-stroke and it looks brand new!
AMA 16066
Hide Signatures
       Post #: 20
RE: Removing Cooked on Varnish from an engine - 10/29/2012 8:34 AM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: w8ye
+1 or    clothing detergent and hot water
Hide Signatures
(in reply to w8ye)
       Post #: 21
RE: Removing Cooked on Varnish from an engine - 10/29/2012 1:55 PM
raptureboy
Score: 183
Status: online
I did an old os 90 in the antifreeze in the crock pot and it did turn it all gray, it was completely covered and I did not boil it so I think it depends on the engine. I have a little enya from the 70's I did and it's fine.
quote:
ORIGINAL: w8ye
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to w8ye)
       Post #: 22
RE: Removing Cooked on Varnish from an engine - 10/29/2012 3:05 PM
Quikturn
Score: 118
Status: offline
IMO, a slow cook in a crock pot with antifreeze is the best way as mentioned several times before. I also use Dawn Power Disolver but the antifreeze method does a better job. Not sure why some people experience graying of the finish (I don't) but at least you'll have a clean engine to work with. If you want to brighten it up at that point, I've heard a copper cleaner will work.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
(in reply to raptureboy)
       Post #: 23
RE: Removing Cooked on Varnish from an engine - 10/29/2012 3:19 PM
BarracudaHockey
Score: 280
Status: online
Anti freeze in a crokpot, on LOW
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Quikturn)
       Post #: 24
RE: Removing Cooked on Varnish from an engine - 10/29/2012 3:31 PM
TimBle
Score: 162
Status: offline
anitfreeze is not a good idea. Antifreeze contains additives which when allowed to boil off can have serious health effects.
ethylene glycol (One component of antifreeze) vapours can cause respiratory ailments.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Removing Cooked on Varnish from an engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.451RCU1
